Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: 3000+ Winchester Impression
    Dec 2002
    Arrow 3000+ Winchester Impression
    This is my first A64 setup. I have been stuck on Intel for about 4 years. Here's the components I started with:
    A64 - 939 3000+ Winchester
    MSI K8N Neo2 Platinum
    2x512 OCZ PC3200 Rev2 Platinum
    Hercules 9800Pro
    Enermax EG465P-VE
    CoolerMaster SK8 w/ YS Tech 5000rpm 60mm
    Tons of new settings for me in this and took me about 2 days to finally work through the "newness". Well as for right now i'm running 9x280 @ 1.65v w/ 2.5-3-3-9 1t 2.85v and the system runs real nice.
    3DMark2001se: 24,849
    3DMark2003: 7209
    3DMark2005: 2902 (not 9x280)
    AquaMark3: 52,780
    And still tweaking..... I am attaching some pictures for your viewing pleasure. Keep in mind this CPU Heatsink was $7.
    C2D E6600 week 25, cooled by Scythe Mine, on EVGA 680i T1 (P28), 2x1gb OCZ PC8000, EVGA 8800GTS
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    hm, so i guess the winchesters dont OC better than 754 newcastles on air at least.
    cuz 2.5g-2.55 is what most newcastles get, so this is right on par
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    May 2004
    대한민국 강원도 원주시 Wonju, South Korea
    I'd like to see what that CPU can do under a decent H2O system.
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    2x8GB Avexir Raiden DDR4-3000 15-15-15-35
    Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
    512GB Samsung PM961 + 840 Pro 256GB + some TBs
    Corsair AX1200i
    X-Star DP2710LED @ 110Hz + 40" Samsung TV
    CPU and GPU under water: 9x120 rad + 3x120 + 3x120
    ...and an HTC Vive!
    Feb 2004
    texas
    i think it needs some more time...
    maybe the 3000+ jsut sucks at overclocking? kinda like a tbred a...
    i dont know, i just have my hopes (and my money) set on an FX57 next year, dont want to lose hope
    edit: ive got a great WC setup( for sale btw ), send the mobo and proc over here, ill test it
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by blinky
    yes, but one is 754, and one is 939 at nearly the same prices.
    Xtreme Mentor
    Jan 2004
    Quote Originally Posted by Kunaak
    yah i know that is true
    im just sayin cuz of all the people who say "oh the winchesters do 2.8g on air" just because they heard someone else say it, and they believe it like
    -edit-Blinky, keep political opinions OUT of this section - Charlie
    wants to sell you wood.
    Aug 2002
    London,Uk
    could be pointed out that an sk8 and a small 60mm fan aren't the best air cooling about though. So assuming it could do more on a better sink and it starts to look good. Also not every core, even from a good batch is good, we need more results(lots and lots more) to see if this is a good, average or even one of the worst overclocks we will see.
    i got a 3200+ sitting here, but not had time to do anything, also finding a none crap board would help. msi - sucks, abit- lots of issues booting-being stable poss faulty but also an ES chip , gigabyte- overpriced, underperforming crappy voltages and general lameness, asus-i sold it(dunno why in the end, ovp vdimm sucked).
    3000+ 939 in uk is £120, 3000+ 754 is £110ish, cheapest 1mb 754 i can see is a £220 mobile, so basically its a 512kb 754/939 in budget area, a dual channel 512 vs a single channel 512kb and the 939 is a clear winner in everything.
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
    Jun 2003
    Omaha, NE
    Is this the oh so famous Radelon from Motor City Online?!?!?!?!??!?!
    DFI SLI-DR
    x850 xt
    3000+ Venice
    320GB WD SATA
    160GB WD IDE
    xp-120
    2x512 twinmos speed premium UTT
    NEC DVD Burner
    Lian Li V1000
    OCZ Powerstream 520W
    Heatware
    ebay
    May 2004
    East Bay, California
    I'll also post some results here around tuesday/wednesday.
    Also, that 2cmd in your bandwidth bench is just an misreading right? you're running 1T?
    Aug 2002
    London,Uk
    sisoft "cmd" bit isn't about command rate, however much it sounds like it, or maybe it is and sisoft reads it wrong most of the time.
    Dec 2002
    Quote Originally Posted by mrnuke
    Oh yes it is..... I am Radelon from MCO.
    Also.... in this setup the psu is holding me back, plus the fact that I run out of higher multipliers. If I had a 10 multi i'm pretty sure I could get this thing to 2.7 or 2.8 without a problem. I have an OCZ psu on the way should be here soon. I'll try and get more out of this setup today. Just got it on thursday so I'm still playing with it.
    This MSI board is a great board. You just need to find the quarks and work around and adapt to them. After that you find it's a really fast board.
    Xtreme Guru
    Jul 2004
    I don't think it's a fair comparison. Remember the 939 3000+ default speed is only 1.8ghz. The newcastle 3000+ is running at 2.0ghz. It already has a 200mhz advantage, so his overclock is really over 700mhz!! Which is a pretty damn good o/c regardless of his cooling.
    Feb 2004
    texas
    Quote Originally Posted by trans am
    I don't think it's a fair comparison. Remember the 939 3000+ default speed is only 1.8ghz. The newcastle 3000+ is running at 2.0ghz. It already has a 100mhz advantage, so his overclock is really over 600mhz!! Which is a pretty damn good o/c regardless of his cooling.
    2000mhz - 1800 mhz = 200 mhz (unless youre giving DC a 100mhz handicap)
    I agree with whoever it was that said we need more results, also once the DFI S939 comes out, well get less of a mobo bottleneck - hopefully
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by ocmyface
    I'm sorry, I've been up too long. 200mhz
    Mar 2004
    Toronto, Ontario Canada
    The only DFI s939 will be on nF4 chipset, which is PCIe only. Not really meant for the mainstream yet.
    Feb 2004
    texas
    wow, i completely forgot about that >
    at least it will still overclock well - knocks on wood
    will there ever be an AGP counter part?
    Jun 2004
    Quote Originally Posted by HKPolice
    Are you entirely sure about that?
  18. #18
    Xtreme Enthusiast p4z1f1st's Avatar
    Feb 2004
    that's wrong....nobody knows, WHICH nF4-chipset DFI will use...there are 4sorts:
    one with SLI (1x PCIe16 / 1x PCIe8) + sATA2
    one with one PCIe16-slot + sATA2
    one with just one PCIe16-slot + sATA1
    and a AGP-version
    (i'm not sure which of them has sATA2, but the SLI-one has)
    @ Radelon:
    i've a few questions
    1. is the IHS still on it?
    2. where do you come from (so, where did you buy it?)
    ----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
    ----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
    ----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
    ----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
    ----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
    ----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
    ----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
    ----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
  19. #19
    Jul 2003
    Eastern USA
    nice 720mhz overclock with a $7 heatsink
    i'd love to see what you can do with a xp-90, a high power 90/92mm fan, and a better psu. probably no more then 100-200mhz more. but still, an 800-900mhz overclock on top air cooling would be quite a feat, and i'd just get a 3000+(instead of planning on a 3200+ or 3500+) if you could show a result like that.
  20. #20
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    $7 heat sink and getting that man....what are your temps? What kind of $7 heatsink is that???
  21. #21
    Aug 2003
    England, UK.
    I think this is a decent clock considering cooling/psu and also the price of the chip. The bundle is only £170 inc k8n neo plat + 3000+ chip. I'm considering getting that instead of my spec in sig, and using 1gb of Ballistix PC4000... Dunno what cooler I'd get though
    I might check out what my current setup can do, if it can do say 2.7ghz, would it be worth changing?
    Rebuilding
  22. #22
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    no if you can 2.7ghz and the Windchesters are doing 2.6ghz or so on air here at first it wouldn't be worth it.
  23. #23
    Dec 2002
    Well I did some more tweaking and got it to 8x320 with OCZ PC3500EB 3-2-2-8 1t in 166 mode. This gave me 25,113 in 3dmark2001se which is awesome. Sandra was around 7500 buffered, superpi was 33s. I tell you what, give me a better psu, cooler and I'll really be rockin'.
    I've found a big quirk in this board which was holding me back before. TRAS 11 on this board hinders overclocks real bad, once I figured that out, it was off to the races.
  24. #24
    Xtreme X.I.P.
    Nov 2002
    Shipai
    guys, please post your results here
    http://xtremesystems.org/forums/showthread.php?t=43417
    thx
  25. #25
    Dec 2002
    Quote Originally Posted by jjcom
    Here's the
    CoolerMaster SK8
    Remember I put a YS Tech 5k rpm fan on there is the only difference. Heck I just used the stock thermal pad too. As for temps, we are talkin' 38C Idle and 49C load
