heard great results so far. 2.6-2.7ghz with stock coolers seems to be a common thing, thats 100-300mhz better than the average 130nm nc and ch's oc afaik.
please post your results!![]()
whats wrong?
anybody?
Maybe it´s because you wrote Wichester, i don´t think anybody has any of those![]()
Seriously though, likely there aren´t so many out yet.
I am curious also though, if you got one by all means let us know your results.![]()
Saaya dont know much about them are they the new 939 core?
Mine is a week 35 3200+. Top stable clocks so far 2300MHz w/default voltage and 2550MHz w/1.60v. I'm using a maze3 WB with a little giant 475gph pump and fullsize auto radiator.
The temps i'm getting aren't all that great, at max clock it gets upto 55c.
I did remove the IHS but had poor contact (maze3 WB's are big) so i lapped the IHS and applied AS5 to the core.
The IHS was indeed very concaved on mine so a lapping should show an improvment for most anyone.
All i have ATM is BH-5 and this thing hates it!
I'm going to order some TCCD today and i have the feeling it should help me out. I'll update when i get my new ram.
GA-P35-DS3L no more than 450fsb w/1333 chip
E6550 stuck at 3150![]()
V-DATA 2x1gb
MSI 7900GS 512 3Dmark score in near future
Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
Sascha, still wanting to get such a thing?
No stunning results yet... at least hereI am looking forward to seeing all the newer A64 stuff getting cheaper... then I will be able to get me something similar after xmas
yeah i want oneBAAAD
but then again, there are not many results yet...
i asked @ lowestonweb.com but they don't ship to germany
ARGH - 3000+ 60 in stock / 3200+ 176 in stock!!!!!!
I WANT THAT SH*T!!!!
----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
As your request, Saaya![]()
sigh... me wants so bad...
is that stable mate? we all need to see sum stable overclocks.....?? a few hours of prime at leastOriginally Posted by Onepagebook
Yep... too bad I've no money...![]()
[QUOTE=shigs]I hate and don't believe prime 95.Originally Posted by Onepagebook
lmao fair enoughOriginally Posted by Onepagebook
the first test is good for CPU-stress-testing only....the rest is f*cked up sh*tOriginally Posted by Onepagebook
I've got an MSI Neo2 plat on the way and a 3000+ Winchester as well i'll post up once i get it in.
E8400 @ 4ghz 24/7
DFI LP LT X48-T2R
G.Skill F2-8500CL5D-4GBPK
BFG 9800GX2
2 x 150GB Raptor X in RAID 0
One page book,
1. what cooling are you using and if it is TCCD or Phase Change, what can you get out of it on stock heatsink
2. What differences did you find between the 130nm and the 90nm, assuming you tried them both?
3. I saw it get its $#% kicked at MadShrimps by a 3200+ 90nm at 2.5 Stock (not a joke, link below)
http://www.madshrimps.be/?action=getarticle&articID=230
What do you say to that?
Extremely Curious about your 3500+ Winchester results - Perkam
perkam, it doesnt get its a** kicked , geez, calm down dude. it just shows that the 90nm parts are slightly faster than the 130nm parts, and yes id also like to hear what results you got with both chips kevin
do the 90nm parts scale better and the speed increases even more compared to their 130nm brothers when you oc them to 3ghz? do you have a 130nm score@3ghz you could run again with the same setup now but with a 90nm cpu at 3ghz and see how big the difference is? and it looks like the 90nm parts give memory bandiwth a boost as well!
thx for posting all your results, especially you kevin![]()
K8N neo hate Prime tooOriginally Posted by Onepagebook
Great, i have one on orderOriginally Posted by misteroadster
E8400 @ 4ghz 24/7
DFI LP LT X48-T2R
BFG 9800GX2
I switched out the BH-5 for OCZ3200 plat rev2. (3200+) 260x10 stable is in the bag now... I think i could bench higher but i'll wait a while and switch to a TDX WB and remove the IHS once again.
V-DATA 2x1gb
