Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 220
Thread: [Denny] ATi HD2900XT 9.5" 1GB GDDR4 testing 56k warning
    X.I.P
    Mar 2005
    last week I got 2 ATi HD2900XT 9.5" 1GB GDDR4.
    those cards are specially make for S.I. high end gameing computer
    X.I.P
    Mar 2005
    testing on 3.6G 1st
    @default clock speed
    3Dmark01.......................63713
    3Dmark03.......................38777
    3Dmark05.......................21480
    3Dmark06.......................12769
    @overclock to 858/1153
    3Dmark01.......................65491
    3Dmark03.......................42680
    3Dmark05.......................22607
    3Dmark06.......................14255
    Sep 2006
    Stamford, UK
    This is 1 graphics card results right? And if so
    Still I think I'll wait for R650... no rush (unless of course Crysis comes out)
    FX8350 @ 4.0Ghz | 32GB @ DDR3-1200 4-4-4-12 | Asus 990FXA @ 1400Mhz | AMD HD5870 Eyefinity | XFX750W | 6 x 128GB Sandisk Extreme RAID0 @ Aerca 1882ix with 4GB DRAM
    eXceed TJ07 worklog/build
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    No crossfire yet? Sorry if I'm asking a bit much already.
    "You'll find happiness once you accept the inevitable or at least you won't be too pissed off" -- Me
    [SIGPIC][/SIGPIC]
    Dec 2004
    Southern California
    compared to the 512mb model is it worth the jump to 1gb?
    i9-10900k@5.3ghz//MSI MEG z490 Unify//32GB Gskill TridentZ b.die@DDR4666//RTX 2080ti(+150/+700) kingpin bios//Samsung 970 Pro//Corsair AX1200i
    Custom Loop: Dual DDCs->Dual EK XE360 w/GT's -> HK IV CPU -> HK IV GPU ->EK X3 Res controlled by Aquaero 6
    Dec 2002
    Quote Originally Posted by guess2098 View Post
    testing on 3.6G 1st
    That looks awsome.......what were the system specs??.........nm
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    X.I.P
    Mar 2005
    those scores are single card. CF score since i only can make it run @ 16+4, those scores are not that good. but i will post it later next week
    X.I.P
    Mar 2005
    512 vs 1024, i hope it would help. not really big gain tho. if you have any score please share with us
    testing on 3.6G 1st with QUAD CORE
    Quote Originally Posted by mascaras View Post
    @Danny
    VGA DEFAULT -- E6600 @ 3600Mhz :
    3dmark 2005 >> 20616 marks ) >> http://service.futuremark.com/compare?3dm05=3056950
    3dmark 2001 (LOD +3) >> 62790 marks >> http://service.futuremark.com/compare?2k1=9202801
    3dmark 2006 >> 11650 marks >> http://service.futuremark.com/compare?3dm06=2046685
    (this is dual core not quad core)
    Dec 2002
    i have scores but Im on Opteron 165......it really wouldnt fit in here.....
    AMD 1090T@4.0ghz
    12gb Gskill 1300mhz
    HIS HD5970
    4.61ghz water
    X.I.P
    Mar 2005
    test on quad core @ 4G, Asus P5K-D, GSKILL 2GBHZ @ 1000 CL4, TT 1200W PSU, TR 120-X
    @default
    3Dmark01.......................68753
    3Dmark03.......................39360
    3Dmark05.......................22842
    3Dmark06.......................12944
    @overclocking to 858/1153
    3Dmark01.......................69669
    3Dmark03.......................43351
    3Dmark05.......................23978
    3Dmark06.......................14439
    May 2005
    Italy
    3d05 and 06 is very good
    X.I.P
    Mar 2005
    Quote Originally Posted by gandalfone View Post
    i should turn off the ATi CCC minimap on 06 to get better score, but i forgot
    Muslim Overclocker
    May 2005
    Canada
    Stock 13k in 06 is awesome.
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
    Jun 2004
    no surprise that its faster then 8800 Ultra in 3d mark 05, but other
    3D marks its still little behind..nice work denny....
    Cat 7.5's used in these tests ?
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    Quote Originally Posted by Dynasty View Post
    Hey D! Have you retired from benching? I haven't see you post numbers in a while.
    Cats 7.5
    E6600@3.89Ghz - HD2900XT@890/1075
    3DMark06 = 13,479
    If I were to have a quadcore I could be hitting 15K, I just used the 3DMark06 Calculator and replaced my cpu score with Denny's and it came to 15008...LOL I will push it some more and will run CAS3 on the ram later on.
    [SIGPIC][/SIGPIC]
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    finally a product that will bring AMD to the market again
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Jun 2004
    Quote Originally Posted by nicepun View Post
    Cats 7.5
    3DMark06 = 13,479
    nice results nicepun......
    definitely not, just been very busy with work.....
  18. #18
    May 2005
    Quote Originally Posted by SaFrOuT View Post
    Possibly...depends upon it's gaming performance, and not it's 3dmark performance though.
    I'm curious on how much the extra ram will help with games actually, as I don't think any game currently can use that much ram.
    Quote Originally Posted by Leon2ky
    "dammit kyle what's with the 30 second sex lately?" "Sorry sweetie, I overclocked my nuts and they haven't been stable since"
    Quote Originally Posted by trinibwoy View Post
    I don't think his backside has internet access.
    Quote Originally Posted by n00b 0f l337 View Post
    Hey I just met you
    And this is crazy
    But I'm on bath salts
    And your face looks tasty
  19. #19
    Xtreme Mentor
    Jul 2004
    Ontario
    sigh, hasn't anyone learned with the 512mb release that 3DMark scores don't mean a single thing? Who really cares how many multiple thousands of points you can gain from using this card while gaming has the card choke under high settings. There was 1GB tests done before the 512mb card came out and it showed next to no gain at all in performance in games. No game will take advantage of 1GB so I feel it is all going to be wasted memory that won't be utilized. R650 is where we have to wait and hope for changes because 16 ROP/TMU's just isn't cutting it when compared to the 8800.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  20. #20
    Oct 2005
    if its the same core, it will still suffer the same horrible drop in fps at high AA. more bandwidth is better but 1GB memory probably wont do much good till Crysis or Bioshock.
    E6420 @ 3.2gHz
    Asus P5K Deluxe
    2GB OCZ DDR2-1066 Platinum
    Powercolor HD 2900XT
    OCZ 700W Gamexstream
  21. #21
    May 2005
    Quote Originally Posted by trajik78 View Post
    Both of those game engines(cryengine2 & UE3.0) support texture streaming, meaning they will use less texture memory, not more.
    Hey I just met you
    And this is crazy
  22. #22
    Mar 2007
    very nice scores
  23. #23
    X.I.P
    Mar 2005
    i forget to change to 7.5... i will try it maybe tomorrow or next week
    here is some 16x+4x weak CF testing, 1st card @ stock clocking and 2nd card @ 500/500 clocking (much lower than stock clock speed)
    3Dmark03.......................60120
    3Dmark05.......................26586
    3Dmark06.......................19390
    just like Kinc said, CF uses less CPU overhead
    also 01 doesn;t really benefit when CF enable
    according to coolaler
    3D06 701/1163 SLi.............19819
    3D03 685/1150 SLi.............69224
  24. #24
    Apr 2006
    Moscow
    very nice job
  25. #25
    Live Long And Overclock
    Sep 2004
    I'm loving the increase in 06 512 to 1gb
    Congrats.
    Perkam
