with intels price slash this week im thinking of getting a q6600, but i would like to know how they oc
so please post your results ... week voltage cooling .... 24/7 stable please
thanks
thanks
yar im interested in all the Quad Oc results has anyone got a link in this forum of Quad comparison ?
Because.......
Problem with these forums ..Look at the Commando thread for instance..you sit there for 2 frigging hours filtering thru crap thats not even related to the commando Motherboard..First page is good after that its a Slanging match between who knows this and who dosnt know jack crap ...VERRY ANNOYING.
Asus COMMANDO -Intel Q6600 @ 3.6Ghz 401x9 have sum test @ 445x9 4GHZ :-)
2x74 Gig Raptors Raid 0..GSKILL 6400 2x1Mb matchd Pair.-OCZ 550w Powerstream adjustable rails- XE2 Vapochill -pioneer Dvd.-2x160 Gig Hitachi ide drives..-Asus 7600 gs video card
http://www.hwbot.org/user.do;jsessio...C3?userId=8636
not sure about Q6600 B3 Retail, but my Q6600 B3 ES does 3600mhz at 1.45v 24hr orthos/prime/folding stable on Swiftech G4 Storm/Thermochill 120.3/MCP655 pump
http://www.xtremesystems.org/forums/...d.php?t=124174
I suspect Q6600 OC'ing has been rare to date because they have been priced so close the the QX6700 that no one in their right mind would buy one.
With the price coming down shortly, we should see some more quad-core overclocking around here.
Here's what I've found for recent quad-core overclocking on 680i boards which is what I'm leaning towards. Although, with these less than stellar results, I'm inclined to rethink that.
It would be great to hear from others.
680i Board / CPU / FSB / Multi / Clock / Vcore / Cooling / Link
DFI QX6700 360 x10 = 3600 @ 1.456 On Air: http://www.xtremesystems.org/forums/...&postcount=112
Striker Q6600 345 x9 = 3105 @ 1.5 On Water: http://www.xtremesystems.org/forums/...87&postcount=3
EVGA QX6700 350 x10 = 3500 @ 1.5 On Water: http://www.xtremesystems.org/forums/...65&postcount=1
EVGA X3220 377 x9 = 3393 @ 1.138 On ???: http://www.xtremesystems.org/forums/...73&postcount=1
EVGA Q6600 367 x9 = 3303 @ 1.375 On Water: http://www.evga.com/community/messag...9&whichpage=24
EVGA QX6700 400 x8 = 3200 @ 1.35 On ???: http://www.evga.com/community/messag...TOPIC_ID=30388
EVGA QX6700 350 x10 = 3500 @ 1.475 On Air: http://www.evga.com/community/messag...TOPIC_ID=30389
EVGA Q6600 333 x9 = 3000 @ ??? On ???: http://www.evga.com/community/messag...9&whichpage=23
EVGA QX6700 450 x8 = 3600 @ 1.45 On Water: http://www.evga.com/community/messag...83&whichpage=4
EVGA QX6700 362 x10 = 3620 @ 1.5 On Water: http://www.evga.com/community/messag...83&whichpage=3
EVGA QX6700 400 x9 = 3600 @ 1.51 On Water: http://www.evga.com/community/messag...83&whichpage=3
Abit QX6700 333 x10 = 3333 @ 1.405 On Water: http://forum.abit-usa.com/showpost.p...postcount=1137
Here are my results:
Q6700 ES B1/P5B D/1.59V/water 375x10
X3220 ES B3/Commando/1.57V/water 422x9
Q6700 ES B3/P5B D/1.5V/water 370x10
Q6600 ES B3/P5B D/1.47V/air 400x9
Q6700 ES B3/P5B D/1.47V/air 360x10
X3210 ES B3/Commando/1.46V/air 438x8
Q6600 ES B3/P5B D/1.47V/air 389x9
Q6700 ES B3/P5B D/1.37V/air 330x10
X3220 ES B3/P5B D/1.34V/air 367x9
Last three systems have been clocked down pending switch to Tuniq Tower 120 on order. All systems crunching WCG full load 24/7/365.
DDTUNG
XtremeSystems - we overclock and crunch you to the ground
I left the optimized files on three 3GHz P4 HTs. Ban me.
Hmmm looks like current generation boards cannot handle quad core overclocking.
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
what is B3 or B2?
what is ES ?
ES is engineering sample (given out by Intel to testers, reviewers, etc.). B2/B3 are the silicon stepping or rev. ES may be hand-picked or binned to perform better but I don't think anyone can verify that.
A question about the Q6600... Can you lower the multi on this chip (i.e. to x7 or x8?)
Rig:
Q6600
Intel BadAxe2
Tuniq 120 Tower
G.Skill HZ 4x1GB
BFG 7900 GS OC (558/675) now MSI HD 7770
WD Raptor 150GB (Primary)
2 x Seagate 320Gb 7200.10 (Storage; No RAID)
Corsair 620Watt
Samsung SH-W183 SATA drive
AuzenTech X-Meridian
Antec A900 Case
I have a Tuniq 120 Tower in my new pc. The size, in relation to others on the market, is directly proportional to the size of my penis. Therefore it is large.
and thick.
Like another said, I refuse to pay the current asking price. I am waiting on the price cut.
From what I've read here, and on the EVGA forums, overclocking a quad core (especially on a 680i) can be a real challenge and you may need all the flexibility at your disposal that you can get. For example, 425x8 might be easier than 377x9... it really depends on your CPU and board.
i believe the q6600 is locked at x9 just like the e6600
OC problems with Kents are either heat or chipset/FSB related. Lowering the multi won't help.
DDTUNG
Yeah on my DFI ICFX3200-DR with same Q6600 B3 ES at 7x and 8x multi with GTL ref adjustments manage 409-411FSB but at 9x it dropped to 340-350FSB.
only Storm?? also 655 is a bit low on pressure, but if u only have 1 block it should matter.. 355 with petra's top ftw
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
stepping på quad intel cpu?
stepping
:Intel @ 05 Q6600
Intel Core 2 QUad
Sl9um Malay
2.4ghz/8mb/1066/05B
L644G057 G4
B5?
cpu:qx9650@4ghz
ram: gskill pc8000qt 4*2gb
MB GB X48-DQ6
Gfx 9800gx2
Disk:2*1tb raid0
I assume a lot of folks are considering the Q6600 after the immanent price drop... what about the X3220 (same chip with Xeon branding)?
i got the retail version and have it so far @ 3.2GHz and 1.4v in bios on air
it's been folding for a few days.
i got it for a good deal thou. friend of mine wnated to buy the qx6700 and
bought this one. so he gave me a deal on it.
To my knowledge there hasn't been anything in the Intel roadmap regarding Xeon price cuts. This, of course, doesn't mean there *arent* going to be price reductions on Xeons. It seems a like it would be a little silly not to cut Xeon prices as there's no marketing benefit, that I can see, to keeping Conroe and Kentsfield Xeons at an unbalanced price point.
Look at the tyranny of party--at what is called party allegiance, party loyalty--a snare invented by designing men for selfish purposes--and which turns voters into chattles, slaves, rabbits, and all the while their masters, and they themselves are shouting rubbish about liberty, independence, freedom of opinion, freedom of speech, honestly unconscious of the fantastic contradiction; and forgetting or ignoring that their fathers and the churches shouted the same blasphemies a generation earlier when they were closing their doors against the hunted slave, beating his handful of humane defenders with Bible texts and billies, and pocketing the insults and licking the shoes of his Southern master.
--Mark Twain, The Character of Man
According to this, the same price cuts are to affect Xeon quad core... (but it is the Inq!)
http://www.theinquirer.net/default.aspx?article=38687
Also here... http://www.digitimes.com/systems/a20...hardware.co.uk
