Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Conroe E6850 on Air, stability test with Ultra_Low_Volt. ^_^
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    been tooo busy these days, finally got some time playing with new chips.
    Conroe E6850es
    Stepping 9 = E0
    all my E6850es in hand don't like much volts.
    defult vcore=1.22~1.24v
    < 1.48v maybe the best for E6850.
    but...seems overclks better.
    max fsb on Air = 533~570.
    can we say: E6850 is better than E6600 ?
    test results bellow are not the same chip
    mobo=asus p5b-deluxe wifi/ap no mod, bios=1004
    cooling=coolermaster fujin with 2*1700rpm 12cm fan.
    ambient=14c
    1.28v 400*9=3.6G sp2004
    1.34v 411*9=3.7G sp2004
    1.36v 418*9=3.76G sp2004
    1.42v 423*9=3.8G sp2004
    more resuls will come when I'm free
Name:	1.28v 400_9 sp2004.jpg
ID:	55243   Click image for larger version.
Name:	1.34v 411_9 sp2004.jpg
ID:	55244   Click image for larger version.
Name:	1.36v 418_9 sp2004.jpg
ID:	55245   Click image for larger version.
Name:	1.42v 423_9 sp2004.jpg
    Uni Hardware:
    http://www.unihw.com
    Team China
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    intel is very good in showing us ES samples with huge overclocking abilities
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Champion
    Nov 2004
    Hungary
    great chip..How was temperatures only 14c ambient?
    Why didn't answer for my PM?
    "We are competing, competing to win. And the main motivation is to compete for victory" - Ayrton Senna
    Jan 2003
    Knoxville, TN
    question: why do you run largefft to show cpu stability instead of smallfft or even blend?
    Main Rig:
    CPU Intel i5 2500K @ 4500mhz
    Mobo Gigabyte GA-Z68X-UD3H-B3
    Memory 4x4GB Corsair Vengeance DDR3 1600
    Video Cards Sapphire 5850
    PSU Silverstone ST75F Strider 750W
    Hard Drive OCZ Solid 3 60GB | OCZ Vertex 2 60GB | Samsung 103SJ's 4TB
    Cooling Thermalright Ultra 120 | 1 Yate Loon D12SM 120MM
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    Quote Originally Posted by over@locker886
    Explore the grocery sale and product range of Coles catalogue this week.
    I've answered days before, but...network really lag at that time, after failed deliever 3times, I gave up.
    check ur msg box
    to shimmishim:
    u can try, large FFT is the best stability test
    Uni Hardware:
    Team China
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    large FFT fits inside cache of this cpu, but did not in previous cpu's. Large is the way to go.
    Large FSB volts, or no, Victor?
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    Quote Originally Posted by cadaveca
    fsb=1.2v , all those test above
    Uni Hardware:
    Team China
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Shiny caps on the bottomof cpu, in the middle?
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    same as C2D
    Uni Hardware:
    Team China
    May 2006
    Herbert's House in Family Guy
    Quote Originally Posted by SaFrOuT
    QFT, when E6600 price drops to $225 in Q2 im getting it hten its AMD for me
    anyway, is 3.7GHz max OC?? can u go for suicide screen?
    E6600 @ 3.6
    IN9 32x MAX
    EVGA 8800Ultra
    750W
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Quote Originally Posted by VictorWang
    same as C2D
    LoL.
    No all C2D have same thing on bottom, even if arrangement is the same.
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    LoL.
    @.@ I've compared to my E6600 & X6800, all the same
    Uni Hardware:
    Team China
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    oh, then I got something for you. E6600 L628A and L631B. Very different on bottom, very different V-droop, very different clocking. Something makes the droop different, and allows the "B"'s clock higher.Maybe ES too.
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    my E6600 L629A531 & L629B381 is alllllllllllll the same as my X68 L617A851.
    Uni Hardware:
    Team China
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Interesting. Cpu temps did not increase when you increased voltage, either. But is very high temps for that voltage, although is in-line with "b" cpus.
    WOnder what's up with my "b", then.
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    pic #1 = chip #1, really hot one, like Bxxx chips
    pic #2,3 = chip #2, mid temp
    pic #4 = chip #3, normal temp as Axxx
    Uni Hardware:
    Team China
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    oh, so 3 different chips there? That's far different. temp readings 15c high then?
    So what makes this chip so special? If is three different chips, they are all seeming to scale very well. As this is almost uniform in appearance, it would hint that there is something physically differnt with these chips. Do you know what that difference is?
    Now I see Fujin for cooling... what fans?
  18. #18
    Jan 2005
    Is this a regular Core 2 Duo ? I don't see XE anywhere.Is it possible for the XE to launch at 3.33 ?
  19. #19
    Oct 2005
    istanbul/Türkiye
    nice low voltage clocks victor,, when will uni team bench it for max??
  20. #20
    Xtreme X.I.P.
    Dec 2004
    Shanghai, P.R.China
    Quote Originally Posted by hey
    we tried to challenge ur 601.9fsb with our 3pcs E6600, but failed
    600 is the max to us. 601 cannot have cpuz file.
    too busy these days, will try E6850 under LN2 as soon as I have time
    Uni Hardware:
    Team China
  21. #21
    Jan 2006
    France
    Do you have a max spi 1m on air ?
  22. #22
    May 2006
    Canada
    That is sweet how much is a e6850 anyway? o.O
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
  23. #23
    Sep 2006
    Seem like decent chips, but nothing special.
    Whats so great about them, 1333fsb?
    E6400 L628 @3.4 1.4V
    Ultra 120 Extreme
    2GB team Xtreem @ DDR2-850 4 4 3 10
    Abit Quad GT
    X1800XT flashed to XTPE 700/1600
    OCZ GameXstream 600W
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Dublin_Gunner
    nothing much besides probably higher default bus speed... probably a good thing for like server/database related work where they'd be running stock speeds.. higher default bus = higher default memory speed = more bandwidth for system. Would help I guess for mysql performance
  25. #25
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    When will it be released?
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
