Page 1 of 4 1234 LastLast
Results 1 to 25 of 88
Thread: Watercooled FX62 action!
    Overclocking Guru
    May 2002
    SoCal, USA
    I put my FX on water so I could play with some DDR2 and HTT clocks.
    Foxconn 590 mobo
    Corsair 6400C2,, 2Gigs
    1x 7900GTX on air stock volts
    OCZ 700W PSU
    Swiftech APOGEE CPU waterblock
    My FX runs good at around 3240MHz with 1.5V.
    At first I ran the Corsair memory at 3-3-3-5 1T around 814MHz, I thought the results were pretty good. But then I switched over to 2T and ran the memory at 4-4-4-5 2T around 1080MHz. Much to my surprise the 1080MHz results were better even though it ran at 2T.
    I have some benchmarks I’ll post up next.
    OPP
ID:	47624   Click image for larger version.
ID:	47625   Click image for larger version.
    May 2005
    Arizona State
    cool what are the temps?
    Q6700
    MSI P35
    8GB OCZ
    2xHD 2900 XT
    PCP&C 1kw
    Xtreme Enthusiast k0nsl's Avatar
    Feb 2005
    Scandinavia
    Do you like the Foxconn, Opp?
    -k0nsl
    When you were born, you were crying and everyone around you was smiling. Live your life so that when you die, you're smiling and everyone around you is crying.
    Dec 2005
    Brooklyn, New York
    Can you post a pic of highest *stable* clocks? Running SP2004 for 30 mins like coolaler did?
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    Overclocking Guru
    May 2002
    SoCal, USA
    Here is I get with Sandra and SuperPI.
    OPP
ID:	47627   Click image for larger version.
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by ZX7891
    Temps in the bios read around 31C, ambient is 23C.
    OPP
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by k0nsl
    -k0nsl
    Yes I like it very much, super stable and great overclocker for this Corsair, it's almost as if they made for each other.
    One thing is you can only increase the HTT in 2 MHz increments. They need to fix that.
    OPP
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Huge bandwidth, impossible to match on Intel desktop. Very nice.
    Whats the efficiancy reported in sandra?
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by thunderstruck!
    What is SP2004? I'd like to try it. Got a link?
    OPP
    Jun 2005
    Turkey / ANK
    1mb SPI result 2T? nice clock 1082mhz ram nice bandwidth did you test cinebench rendering? (cpu test)
    Q6600 1.390v 3.8G Vid: 1.2125 Thermalright Ultra-120 Extreme .DFI LanParty DK P35-T2RS. Crucial Ballistix Tracer 8500 2x1GB.. Seagate 410As Raid0 .. Sapphire HD4870 512mb & Cooling Thermalright HR-03 GT.. 19 LG 1950SQ .. Silverstone OP850 watt. Case Gigabyte Auro3D
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by FUGGER
    OPP
    Banned
    May 2005
    Belgium, Dendermonde
    is it rockstable at 3240MHz on 1.5V??
    that would be simply insane
    Jan 2006
    The Netherlands
    Quote Originally Posted by OPPAINTER
    OPP
    Stress program based on Prime95.
    http://sp2004.fre3.com/sp2004exe_060405.cab
    Intel Core 2 Duo E6400 ( Best personal 1M spi : 14.562s )
    Gigabyte GA-P35-DS3P F5
    OCZ Vindicator with 120MM Fan
    2 x 1024MB Crucial Ballistix PC8500
    2 x 512MB Transcend PC5300 /w D9GMH @ 651Mhz
    2 x 512MB Corsair PC6400C5 /w Promos @ 567Mhz
    Nvidia GeForce 7600GT 256MB GDDR3
    Corsair HX 520W
    I am Xtreme
    Feb 2003
    Netherlands
    OMG so many holes in the Storm mounting plate and still no matching holes.
    That bandwidth is awesome Opp, that SuperPi run is about the same as an FX 57 with BH-5 running 270 2-2-2-5.
    Any plans on watercooling the NB/videocard?
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Feb 2005
    Scandinavia
    Sweet man. Damn nice bandwith there too.
    I'm getting my AM2 setup by next week (Tuesday or Wednesday).
    -k0nsl
    OPP
    Overclocking Guru
    May 2002
    SoCal, USA
    I think it has more power then socket 939. This is pretty good 01 with the 7900 at stock clocks, Windows XP.
    OPP
ID:	47631   Click image for larger version.
    Xtreme 3D Team Member
    Jan 2005
    Wiltshire, UK
    Insane mem speeds - definatelly given you some kickass bandwidth results!
    Keep it coming, Opp!
  18. #18
    Overclocking Guru
    May 2002
    SoCal, USA
    -k0nsl
    How's this bandwidth. I did this a few MHz higher on the memory but was not stable for 3D.
    OPP
  19. #19
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by Zeus
    I will when I put it in my Case for 24/7 use.
    OPP
  20. #20
    Overclocking Guru
    May 2002
    SoCal, USA
    Video card at stock clocks.
    OPP
  21. #21
    Nov 2004
    Brighton, UK
    OPP
    hahahaha, like jarhead
    "i need to bench something sooooooon"
    Nice clocks, so is 2t as much of a gap as with 939? i understand it allows for much higher o/c but do you think this is the memory or controller/chipset issue?
  22. #22
    I am Xtreme
    Feb 2003
    Netherlands
    OPP
    Damn, it has a hell of a lot more power than S939!
    Can you post a compare link so that i can compare it to my S939 Opteron @ 3.2GHz with my 7900GT@ 700/1800 to see how much more powerfull it actually is?
  23. #23
    Overclocking Guru
    May 2002
    SoCal, USA
    I didn't save the result. I'll do another run and upload it to the orb.
    OPP
  24. #24
    Overclocking Guru
    May 2002
    SoCal, USA
    Here's 06 with stock 7900 clocks.
    OPP
  25. #25
    Apr 2005
    Thailand
    LOW CL Wanted Sirrrrr
    Overclocker from Thailand : www.vmodtech.com
