Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: E6900 or E8000 ?
    Jan 2006
    Lithuania, Kaunas
    Question E6900 or E8000 ?
    Spec:
    E6900 4MB 3.20GHz 1066MHz FSB Q4 $969. us
    E8000 4MB 3.33GHz 1333MHz FSB Q4 $1199. us (95 Watts)
    As we see E6900 has 12x multi and E8000 has just 10x.
    E6XXX serie can reach ~400FSB so its 400x12 = 4800MHz and hopefully new mobos with changeable voltage arive soon.
    So is it worth to pay 230$ more for E8000 as we get lower clock?
    Mar 2006
    Oslo, Norway => Across the pond
    If Intel does to the E8000 as it has done to the 955 and 965 Extreme editions, it will have unlocked multiplier... so it could go higher than 12x
    Quote Originally Posted by Durzel
    You shouldn't be pro-AMD, or pro-Intel... just be pro-choice pro-the-best-CPU-currently-available.
    Jan 2006
    Lithuania, Kaunas
    yup, would be
    Mar 2004
    Fullerton, California
    Is the XE just a 10x 6700 with a faster stock FSB or is there architectural changes that would put the XE in the lead in terms of performance if both it and the 6700 were clocked the same?
    Jan 2006
    Lithuania, Kaunas
    Quote Originally Posted by urbanfox
    XE has different voltage, FSB and maybe unlocked multiplyer but architecture is the same.
    Feb 2004
    XE will be unlocked and is certified for use on a 1333FSB.
    It also opens up the overclocking features on Intel Extreme motherboards such as BadAxe.
    Admin
    Feb 2005
    Ann Arbor, MI
    It's Intel's best silicon. Hasn't history already proven itself with their top-end CPUs? (780>>770, 67x>66x, 965>>950(or is it 960 now?), etc.)
    If you want the best Intel CPU at both stock and end-OC, be willing to pay.
    Apr 2005
    Belgium
    Quote Originally Posted by Thorburn
    You can unlock those features with the Intel Integrator Toolkit for every intel CPU There is a How To here in the intel section for doing that
    intel Core 2 Duo E6600 @ 8x400MHz
    Asus P5E X38 bios 1201
    Corsair TWIN2X2048-6400 x2 4GB in total
    eVGA Geforece 9800GTX+ || Creative Audigy 2 ZS
    Adaptec AAR1430SA 4port Raid card
    Seagate Barracuda 7200.10 160GB 8MB SATA2 x2 (RAID0, OS drive) on Adaptec
    Seagate Barracuda 7200.10 250GB 8MB SATA2 x2
    Seagate Barracuda 7200.11 500GB 32MB SATA2
    Seagate Barracuda 7200.11 1000GB 32MB SATA2
    Seagate Barracuda 7200.11 1500GB 32MB SATA2 x4
    Coolermaster CM 690 || Corsair CMPSU-520HX
    Windows 7 Ultimate RTM x64
    Philips 200WB7ES 20" WS 1680x1050
    MacBook Pro 15" June 2009
    iPhone 3GS 16GB
    Jan 2005
    XE has 10-60 multiplier
    I am Xtreme
    Jan 2005
    who needs x60 anyway ? :p
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
    Mar 2006
    There are some confusion in the rumors about this one... some say it will be released in Q4, others that it will be the first one to hit the streets...
    ln2nl
    Jun 2004
    The Netherlands
    as an sample but not retail.
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Mar 2004
    Quote Originally Posted by WildEye
    Ye, I've read both and was confused as well.
    I'm really hopinh it's the latter though
    Mar 2005
    Molde, Norway
    I would say E6900, because after seeing Merom and Conroe compared to each other it seems like Conroe doesn't really gain a lot due to the higher FSB speed. It gains a lot more of a higher core speed.
    Jan 2006
    Lithuania, Kaunas
    Quote Originally Posted by savantu
    OMG
    sorry for stupid question but what influence to CPU has bigger multi? instead of higher clock ofcourse.. I mean why its not possible to make 60x multi?
    Mar 2005
    Molde, Norway
    Well, say you've got a motherboard that manages to run a XE cpu at 400FSB maximum, that's 10x400=4000MHz core speed. The FSB can't go any higher than 400MHz, but then you raise the multi to 11x400=4400MHz core speed.
    10x440MHz FSB will in most cases give more performance than 11x400MHz FSB, simply because the bus bandwidth is higher.
    I really don't know why one can't use 60x multi, I've never seen anyone try. A XE at 3.33GHz with 60x multi will be limited to 55MHz FSB, and I guess that's not enough to make the cpu work well. I'm just guessing here..
    Xtreme Recruit
    Dec 2005
    My take on this is why spend the big bucks on the XE when all you really get is bragging rights. Spend $300 on a 2.4 conroe, then oc it and you'll have a really fast machine. IMHO
  18. #18
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    with unlocked multi and Intel's BEST silicon... it's the CHOICE. If the multi was LOCKED, however... then the E6900 would be better for OC'ers.
  19. #19
    May 2004
    Quote Originally Posted by automagic
    So very true but then again some people want every last drop of power higher multis could bring and they have the overclocked wallets to match, so why not?
  20. #20
    Apr 2006
    No, you no longer need an EE for OC on intel boards. I used a 950 PD and I oced to 5 ghz (not stable)on a D955XBK. If it doesnt let you OC you just use Intel Integrator toolkit and unlock bios options
    ***Main System ***
    Intel Core 2 Duo E6400 2.13 Ghz @ 3.6 Ghz
    Abit IP35-E
    4GB DDR2 RAM
    XFX HD 5770
    3x 120 GB HD
    2x 160 GB HD
    Antec Trueblue 2.0 480 Watt
  21. #21
    Apr 2003
    Tallinn, Estonia
    is it sure a 3.2 conroe will be released this year?
    I was under impression that 2.9 will be fastest "normal" core2..
    at least for 2006
  22. #22
    Jan 2005
    2.4ghz Conroe for me, 4MB L2 cache, $309. Looks like it'll be a beast!!! Sure, 9x multi, but for $700 extra I could get extra videocards, much better RAM, a bunch of great hard disks, etc. I know, I'm violating XS spirit by saying this, but the extra just isn't worth it in that case... I'm thinking a Conroe 2.4ghz stock could hit a good 3.2ghz or so on air which would be sweet !
  23. #23
    Feb 2004
    Quote Originally Posted by cupholder2.0
    Didn't say you need it, just that it unlocks it
    Of course there are other ways
  24. #24
    Feb 2004
    The XE offers the ultimate performance for people who don't want to overclock or for those who want the extra flexibility to get the optimum performance from there system by being able to choose the most suitable combination of FSB and multiplier.
  25. #25
    Xtreme Mentor
    May 2005
    San Diego, California
    If you're going to pay that much anyway, go for the gold, XE
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
