-= Xtreme CPU Benchmark =-
Version: 1B
Created by: AgentGOD
Homepage:
www.ultimate-filez.com
Remember to check forums/my website for new updates!
This program is a CPU/Memory benchmarking tool. It allows you to see your CPU's performance ratio levels (the RAM will also be crucial, as it allocates the calculations into your RAM).
My system has an AMD Athlon(tm) 64 3000+, overclocked to 2.73 GHz, 2 GB of Dual-channel DDR400 RAM.
I've scored 2469 XtremeCPU Marks, and took 68 seconds to complete.
Remember, only high end system may end up in the 3000-4000+ range, so don't be disappointed if you don't.
I'd say around 2000 is an average overclocked AMD system, and around 3000 are the extreme high-end ones on LN2 or DI.
How the program works:
It runs through a series of tests, 1: Integer sorting (in order), 2: Calculating factorials, 3: Floating point calculation, 4: Linear graphing, 5: Finding prime numbers.
It calculates the score according to your time. The lower time it took to calculate, the higher your score will be.
