Results 1 to 10 of 10
Thread: Tubing Questions
    Jul 2005
    Illinois
    Tubing Questions
    I did a search and everyone seems to be a bit fickle as to which tubing is "best". I my loop i will have 1 tight run from vid to NB. My main concern is a kink inline. I ordered masterkleer 7/16" tubing but after doing my search the only common theme is 1/2" tubing is better to prevent kinks.
    Basically, will the masterkleer work? or should i get 1/2" tubing instead?
    Mar 2004
    Murfreesboro,TN
    gerenal consensis is 1/2'' causes more turbulance than 7/16". I'm presently using 1/2" & I am happy with its performance, but might switch over later with my next upgrade
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
    Apr 2005
    Maine
    7/16" actually from my own experience has a tighter bend radius than 1/2".
    according to cathar there is no performance difference between the two either.
    Also take into consideration 1/2" is physically larger and heavier so it puts more strain on the blocks when i hangs from them.
    In the looks department 1/2" looks retarded compared to 7/16" and obviously cause its larger takes up more room.
    The difference between genius and stupidity is that genius has limits.
    - Albert Einstein
    Mar 2005
    Madison, WI
    I chose the 7/16" for a tighter fit on the barbs, "possibly" less turbulence, and better turning radius since I'm using a crossfire setup. It likely really won't make that big of a difference since you've already ordered the 7/16". I also agree that 7/16" looks a little better.
    Xtreme Guru
    Jan 2006
    Milan, Italy
    7/16 masterkleer ftw
    Quote Originally Posted by Bloody_Sorcerer
    flowrate is for losers!
    Quote Originally Posted by MaxxxRacer
    Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
    Jul 2005
    Atlanta, GA
    Quote Originally Posted by creidiki
    ditto. here's what i did:
    1/2" Home Depot tubing, boiled in hot water and shaped in the freezer to desired radius. this tubing goes from (T->pump-inlet) and (pump-outlet->GPU). couldn't get the 7/16" on the D5 pump (i'm sure it's possible but i'm not that diligent >.<). and then everything else is 7/16" masterkleer.
    and yea, the decrease in turbulence should yield you .0000001C temp difference for the better....... so basically just do it in places you need tight bends cuz the performance difference is immeasurable except in labs.
    "premature optimization is the root of all evil" - Donald Knuth
    <('_'<) <('_'^) (^'_'^) (^'_')> (>'_')> OMG ITS T3h POWER RANGERS!
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    recently switched to mastkerkleer and it rocks. its a total paint to get on some barbs (specifically the NPSM fittings Swiftech uses), but creates an excelent seal, and looks alot cleaner.
    Apr 2005
    Maine
    Cant beat the price of the masterkleer either, what is like 25 cents a foot at mcmaster. I got like 20 feet laying around.
    - Albert Einstein
    Aug 2005
    Question, then: what OD is best for masterkleer 7/16" ID tubing? 9/16" or 5/8"? Or does it matter?
    * DFI NF4 Ultra-D Bios 704-2BTA
    * Opty 144 323 x 9, CAB2E 0546 UPMW
    * 2x512 OCZ PC3200 Gold Edition
    * XFX 7900 GT 600/1800
    * WD 250gb SATA II HDD
    * Samsung 940b 19" 8ms LCD
    * OCZ Powerstream 600
    * DTek White Water block
    * Aquaxtreme 50z 12v pump
    * '86 Chevette Heatercore
    * 1/2" ID tubing
    Jan 2005
    Manchester, UK
    5/8" OD is the usual stuff people get, 9/16" kinks a lot more easily on tight turns.
    I have 1/2" ID 3/4" OD atm, and it's a total nightmare to route, I'm retubing shortly, I'll definitely be going to 7/16" to tidy things up a bit.
    CPU Temps: Forget MBM, if it don't crash it ain't too hot.
