Thanks noob! I thought that it wouldn't work but I was hopping!! What kind of psu would I need and where do I get one that would work??
whoa, server time error.
post order should be 3,4,1,2.
ebay under aws983s, heatware under Mr. Tinker.
What size tec would I need to use on a 6800gt? I have the dd nv68 and was thinking about putting a tec on it. I have a meanwell s-320-12 running a 226 on the cpu! What size would I need to run on the video card and can I run it on the meanwell as well as the 226???? Thanks for everyones help and suggestions
The size of tec that you can possibly run with the 226 will not be enough for the 6800NV. Therefore its time to get a new psu or to do something different.
If you have a cooling question or concern feel free to contact me.
man this thread got really messed up!!
Ebay's a good place.
Search for...
"Switching 12v" and skim thru
Originally Posted by n00b 0f l337
what would be best 12v 6a or 12v 4a?? I liked the one here http://cgi.ebay.com/High-Capacity-12...QQcmdZViewItem
Thanks again for the input!
the more amps, the better. 6a is not going to cut it.
Originally Posted by Mr. Tinker
hum thanks Tinker I don't really see anything but 4 and 6 amps! I will have to keep looking! That is ok I don't really have the money right now anyways! I am just looking at what I would like to do in the near future!! Thanks to you both!
I don't think 226 is two small my 6800nu is running an 80watt@7v for about 21watts and it will keep my card just warm enough not to cold bug running at 425core 1.2v 12p/6v
LOL I like that "bananal"
search for a meanwell s320-12 300watts, 8.8-13.4v, 25A
Current 24/7 settings
Delidded L628B e6400@ 3.6ghz 1.38v
3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
x1900xt 690/780
menlatin I have a s320-12 but how do I know what the watts are on it! I do know mine is 25A! Thanks for your help
320 is wattage,
12 is voltage.
320 / 12 = amperage!
26.66 amps.
Closer to 15 if I remember the meanwell's.
your right n00b I am checked the amps with a meter and it was close to 15!! I didn't know the 320 was the Wattage thanks for the info!!
n00b what size/type power supply do you recomend!!
It will be around 15 amps or so until you apply a load.
Should then be around 25 amps once your running something.
That powersupply should work just perfect.
but I want to run 2 tecs and water pump off of the same power supply!!
Is that possible?
