Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 85
Thread: Zalman7000 and other cpu coolers on x1800xt and GTX
  1. #26
    Feb 2005
    Turku, Finland
    Quote Originally Posted by bAdboLL
    Ok i have found a Zalman7000 now, but he only have the s478 adapter.
    Will it work on my GT?
    You dont need the zalman 7000 cpu adapter. You have the mounting holes in the cooler itself and you need couple of bolts, nuts, and washers to mount the cooler.
    Or VF700 mountings.
    Intell Core 2 Duo E6850 3,9ghz with water
    DFi P35 Blood-Iron
    G.skill 2x2Gb PK 5-5-5-12 1088mhz 2.2v
    Sapphire Radeon HD2900Pro 1024mb GDDR4
    Lian Li PC-V2000A
    BENQ FP937s+ 19" TFT
    Logitech UltraX USB keyboard
    Logitech G5 Laser mouse
  2. #27
    Jan 2005
    done some month before on a 7800 gt , it need a fix on the back of the card to report forces behind the gpu, with only screw the card is too heavily squized
    http://www.nokytech.net/forum/showth...light=enerv%E9
  3. #28
    Dec 2004
    Santiago, Chile
    I did it with my 7800GT.
    I had to cut some fins off the Zalman so it could enter the slot. Otherwise it will touch with the other PCI-e slot.
    Here you can see how to install it, you use the install process of S939.
    BTW it works increbible. Now my roof isn´t the temperature, is voltage, I need to voltmod this bastard.
  4. #29
    Feb 2005
    Turku, Finland
    GJ. Its as easy as driving a bisycle
    DFi P35 Blood-Iron
    Lian Li PC-V2000A
  5. #30
    I am Xtreme
    Dec 2002
    my sp-94 brought my load down to 40c BTW, thats from 60C on the VF-400, over 70c stock.
  6. #31
    Oct 2004
    Denmark
    It looks like the fan is very close to the other expansionslots?
    Have some tried it with a X1800XT, DFI SLI-D mobo using PCI-E 1?
    Asrock P67 Extreme 4 (B3)
    2500K@4600mhz (Scythe Infinity)
    2x4GB DDR-3 Corsair 1333 mhz
    Gainward GTX 570 Phantom @900/2250
    Enermax EG701AX
  7. #32
    Sep 2003
    Clayton, CA
    instead of cutting the fins... can't you just bend them to the side?
    -=Darkside=-
    3700 @ 3.0 :: DFI NF4 Expert :: 2g OCZ Platinum :: 2x 7900gtx SLI :: 2x74gb Raptors RAID 0 :: X-Fi/Z-5500
    -=Sintax=-
    3200 @ 2.4 :: GAK8NPro 754 :: 1g Mushkin BH-5 :: x850xt @ PE :: 2x36gb Raptors RAID 0 :: Klipsch 4.1
    -=LilGuy=-
    Dell Inspiron E1705 :: 2ghz Intel Dual Core :: 2g DDR2 :: 7900gtx :: 100gb 7600rpm
  8. #33
    Feb 2005
    Turku, Finland
    Quote Originally Posted by Semper Fi
    Theres so much fins that theyl eventually get involved with the fan. And i think its a little hard to bend that many fins. Correct me if im wrong.
    DFi P35 Blood-Iron
    Lian Li PC-V2000A
  9. #34
    Oct 2004
    Denmark
    Quote Originally Posted by Sume4
    It actually doesnt bend THAT much that there would be any issues. Its just that in BTX the fan is near the pci-e slot and ATX it interferes. Macci had a 7000B Cu on his x1800xt with normal DFI NF4 board and the fan went in the middle of the slots so there was no problem.
    I would really like to get this straight befire ordering the HSF.
    Sume4 I can se you are using the DFI SLI-D board. Is there any problems with the fan interfering with the other slots?
    Enermax EG701AX
  10. #35
    Jan 2005
    yes to much fins , in my case (asrock dual) i had to reduce the pales (don(t know in english sry) of the zalman too, but the temp is really incredible; i thank ther is something buggy:never go up to 31 °c @stock but not: after oc 500 /1190 ti went to 38 in load , tested in load in passive 2h 86° no shutdown but i think it's a bit too much
  11. #36
    Dec 2005
    Hm i dont get it really, i have now bought a Zalman7000.
    I will get it on Friday..
    But how the hell should i mount it? Does it really work with the VF700 mountings?
    And one more, how much lower temps did you guys got when swiching to this from VF700?
  12. #37
    Feb 2005
    Turku, Finland
    Quote Originally Posted by mbm
    I got the SLI-DR Expert which has a different layout But ive seen a picture by Macci where the card is on "normal" DFI NF4. The fan goes in the middle of the slots on that version.
    DFi P35 Blood-Iron
    Lian Li PC-V2000A
  13. #38
    Oct 2004
    Denmark
    hmm just got the Zalman7000alcu.
    First of all. It doesnt fit 100% with the mounting holes on the PCB.
    And I dont think im going to cut anything off the heatsink, because the way I see it, the fan will hit the PCI-slots?
    Waste of money. I also got some nice copper heatsink for the ram. No use of them either.
    Enermax EG701AX
  14. #39
    Dec 2005
    I have now mounted the cooler on my card and it works great!
    Loadtemp before: 61-61 (With VF7000)
    Loadtemp now: 46-47
    Here are some pictures!
    Thanks for the tip!
  15. #40
    Jun 2003
    Netherlands
    Quote Originally Posted by POGE
    I wanna see you get a big typhoon on it.
    I'll post pics of that tonight (well, when I don't forget to that)
    | Core 2 Duo E6600 @ 5304MHz | Biostar TForce P965 Dlx | XFX 7800GT | 1GB Crucial Ballistix PC5300 CL3 |
    SPi 1M: 9.953s
  16. #41
    Mar 2005
    TX, USA
    Did you try mocking it up to see if it would hit the PCI slots? I'm curious to see if this will work with the regular DFI Ultra-D/SLI boards before I order anything.
    2600k@4.9Ghz 1.42V | Asrock Ext 3 Gen 3 | Custom H20 | 16GB PC3 1600 | 7970@1375/1600
  17. #42
    Oct 2004
    Denmark
    Quote Originally Posted by Elfear
    I didnt but im almost sure the fan will hit the PCI slot.
    Enermax EG701AX
  18. #43
    Dec 2005
    The fan will not hit the pci-slot, i am almost sure of that.
  19. #44
    Feb 2005
    Turku, Finland
    bAdboLL sweet pics you got there. That XFX card is nice because of that side thingy supporting the card from bending.
    I ran 3Dmark06 today with clocks 796/910mhz with NO artifacts \o/ 800+/910 could be nice
    .... I had my window open and its -22c outside. Oh and cpu running 3.1Ghz with aircooling.
    DFi P35 Blood-Iron
    Lian Li PC-V2000A
  20. #45
    Oct 2004
    Denmark
    If you see the last pic in #28 you will see the fan goes below the slot.
    Some say the fan will go between the slots? On almost every mobo the are resitors etc. between the slots??.
    The PCI slots are also a bit higher than PCI-E slots. So I just couldnt se how it would fit in my mobo (DFI SLI-D)
    On the DFI SLI-D EXpert there are more space between the PCI-E slots. This is maybe the reason for Sume4 to have succeeded.
    I would like to hear from someone with a DFI SLI-D if they have mounted the Zalman?
    Enermax EG701AX
  21. #46
    Dec 2005
    Sume4, what gives the best OC result? With or Without delta on 7800GT?
    I only have the 1.5V bios mod but i couldnt OC any higher with this cooler than with my vf700 =/
    Even though the temps lowered by ~15c in load. Thats with a 20 mhz delta, maby i should try with 0 delta again?
    Now when i have good cooling, 1.6 or 1.7V hardmod should be pretty safe right?
  22. #47
    Mar 2005
    TX, USA
    You should be fine at that voltage. ViperJohn says he runs his aircooled 7800GTs at 1.6V and his watercooled GTs at 1.66V. That's for 24/7 use so you could probably go higher for strictly benching.
  23. #48
    Jan 2006
    Crete-Greece
    Hey Guys,I was wondering If i can mount an COOLERMASTER MINI AQUAGATE 120 to my x1800xl...Any Ideas???Do you thing that the heatsink can be fit on my ati core???
    24/724/7
  24. #49
    Dec 2005
    Netherlands
    Zalman CNPS9500 CPU cooler on a XFX 7800GTX with pics...
    http://www.xtremesystems.org/forums/...ad.php?t=86526
    NC™
    Lian Li V2000+ Modded
    Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
    Asus Rampage Extreme 2
    OCZ 3x2GB DDR3 1600 Platinum
    EVGA GTX460 768MB 850/1700/2100Mhz SLi
    EVGA 8800GT SSC 730/1800/2000Mhz
    Corsair HX850W
  25. #50
    Jun 2003
    Netherlands
    Thermaltake Big Typhoon on a XFX 7800GT
    SPi 1M: 9.953s
