arrrrrrrrgh dam thy weaker cpu0 core
what's best way to burn in cpu0 core ??? any success stories with helping along a weaker core to catch up to it's better half ???
with or without IHS?
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
with IHS as i never take it off too risky and looses resale value heh
This has worked for me several times. Use CPUBurn set to K7 and high priority. Run it on core 0 overnight. Leave machine off for 8 hours or so. Try SuperPi again. It should run longer. Continue till it completes SuperPI.
This has worked for me on claws, winnies, and my opty. Only difference is I run Prime for the testing instead of SuperPi.
I use this technique to lower voltage on my cpu's...
thanks Plywood99 never used cpuburn as i use cpuburnin which is different ... will try CPUBurn/K7 and see how it goes
eva be sure to bring us news on the burn in effect, and good luck to you! (fingers crossed)
Intel Conroe E6400 - Intel P965 - 4GB DDR2 - 8800GTX - 320GB Western Digital - Dell 2007WFP - Windows Vista Ultimate
Originally Posted by Plywood99
u use cpuburn at stock clock speeds ?
Intel Core2Quad Q6600 @ 3.6 | Thermalright Ultra Extreme
EVGA 780i SLi
8gb ADATA 4x2gb DDR2 800
Evga 260gtx core 216
Western Digital 300gb Raptor x 2 | Seagate 7200.11 1.5tb x 2
Klipsch 5.1 Ultra Promedia
Corsair 1000hx
Lian Li TYR PC-X500
Dell 3007fpw 30" Widescreen LCD
probably bad contact with the core0 then.Originally Posted by eva2000
my 1 core can do 2800 no prob .. other core needs alot of vcore to
EVGA 780i SLi
Corsair 1000hx
Lian Li TYR PC-X500
hopefully this will help with my 3800+ X2.
2.75 is stable on both cores, but @ 2.80, the first core craps out on superPI
PC 1
E6600 + Sonic Tower + 120mm Delta
2GB G.Skill HZ PC6400 RAM (s/n 0606)
Intels Bad Axe mobo - D975XBX - bios 1378
4 x 74GB Raptors - RAID-0
7950 GX2 on a 3007FPW 30" Dell
PC 2
P-D 805 + Corsair Nautilus 500
256MB Crucial PC5300
Asus P5B Deluxe
6800GT
this CPUBurn sure seems to stress the CPU hard, it's good and simple as well. I'm going to leave it running all tomorrow, and see if it has any effect.
Conroe E6300 ES
2x1gb Ballistix PC8000
Asus P5W DH Deluxe (1705)
Manli Geforce 7950GT 512mb
Hiper Type-R 480w
Samsung SP250
"What did the quantam duck say?" "Quark Quark"
the cool thing about burning in dual cores... is you can burn one core, and still use the PC while the other core is working away.
I been doing this for 2 days now, straight, haven't turned my PC off or anything, just set Affinity to core 1 in my case, and then let it go...
I use sisoftsandra for burning in a CPU though.
AFAIK, the OS is run on CPU0 - so that in itself can make that particular core more unstable during benches. I guess the ideal thing to do would be to split up the processes running in windows....
Not at stock. I set clock at just above stable. For instance say prime stable at 2800, but 2850 craps out after about an hour or so. Run cpuburn overnight at 2850. Shut down computer for a few hours. Now try prime again.Originally Posted by jetjaguar
On my opty 148 I could run SuperPi 32m and 3d benches at 3050mhz no problem, even gaming was not a problem. But Prime would crap out after about fifteen minutes with cpu set at 2900mhz. This is with voltage set at 1.61 in the bios.
I ran CpuBurn k7 set on high priority for two nights. Now cpu is prime stable, and passes occt no problem. So I drop voltage a bit and run prime, not stable. I repeat my burnin process till stable at lower volts.
Doing this I have went from 1.61v to 1.575v and cpu is rock stable, passing all tests. My goal of course is over 3ghz 24 hour prime stable at under 1.6volts...
nice Plywood99... guess i need to run it longer than i have now
still burning in cpu0 with cpuburn k7 while cpu1 completed 8.75hrs of cpuburn
It's one die...Originally Posted by shuRe
I've had my 165 a week now and still can't get over 2850mhz. Haven't tried prime since it failed after an hour and a half but it's been 100% stable over that. 2880mhz core 1 fails no matter what voltage, probably getting to hot. I've been running games and dual D2OL and prime and all kinds of crap 24/7 since I got it and haven't gained a damned thing.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
everything has its physical limit and no manner of torture will bring it higher.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
Man i hope for my sake ya wrong LOL
cpu0 = cpuburn K7
cpu1 = stressprime
Doing so cpu burn in to help cpu0 core along seems to be the weaker one of the two cores at the higher clocking end
changed to dual CpuBurn K7 @2700mhz
APC UPS reported system power draw with 2nd BFG 7800GTX card added = 355 watts
Opteron 170 CCBWE 0544XPMW cooled by Corsair Hydrocool 200EX
DFI NF4 UT SLI-DR R.AB0 623-2BTA bios
2x BFG 7800GTX SLI with 81.94 beta drivers
4x 80GB Hitachi 7K80 SATAII Raid 0 OS drive
1x 250GB Maxtor Maxline Plus II PATA
Pioneer DVD Burner
Floppy drive
650W Silverstone SLI PSU
burn in helped ?
retired computer enthusiast
don't know yet.. gonna leave it running for as long as i can before seeing if it helps hehe
wish me luck
There's little you can do (if anything) to make your weaker core to catch up with the better one.
Core 0 of my X2 3800 is at least 150Mhz weaker than core 1. I can prime core 1 at 2850 and core 0 only at 2700. Actually I don't know how good is core 1 because windows crashes before prime fails on core 1.
I've started with a Big Typhoon -> water -> no IHS+water
I gained 150Mhz on core 0, but the difference between core0 and 1 remained the same.
In fact it's a shame. You and I are unfortunate, because if ou disable one core at windows boot.ini, it will always disable core 1. So no way to disable the weaker core 0 to bench on core 1.
Originally Posted by krille
I'm not sure if anybody caught my post, but here it is again - lol....Originally Posted by s7e9h3n
have got any proof of that?
Besides, going through windows and disabling services everytime you just want to overclock a bit further than is 100% stable seems fairly pointless. Better just to run a burn-in. Which, incidentally, has done my core0 some good (now seems to be more stable (i.e. can run prime for half an hour, could only do 6 mins before) with 1.55v@2750mhz after just a few hours of CPUBurn)
Conroe E6300 ES
Hiper Type-R 480w
Samsung SP250
Eva2000, when I say I ran CpuBurn for two nights, I don't mean 48 hours straight. But 2nights each about 7-8 hours while sleeping, shutting system down while I go to work.
Just wanted to clarify...
