I just got this non silicone HTC(High Thermal Conductivity) heat sink compound from AOS(its the same company that supplied Asetek/Vapochill and some generic stuff).
This product is pretty new since they just got a patent of it.
The specs..
It has over four times thermal conductivity of standard non-silicone heat sink compound....
@36C...17.4 BTU
Operating temp. range...-40C to 200C
If you see the compund AMD used on their A64 hsf..its about the same color and consistency.
Heres so far with 3500 Venice and FX's stock hsf...
Load temp stay @38C...
