Page 1 of 4 1234 LastLast
Results 1 to 25 of 95
Thread: Kakaroto G.SKILL PC4000 2GB HZ testreport
    Bandwidth Freak
    Dec 2003
    Just received two kits of this RAM. This ram is the extreme version of the 2GB HS which is rated at PC3200.
    Here some official specs:
    * Package : 2048MB kit (2x1GB) dual channel pack
    * IC Spec : Samsung
    * CAS Latency : 3-4-4-8 (PC4000)
    * Test Voltage : 2.6~2.8 V
    * PCB Board : 6 Layers PCB
    * Speed : DDR 500MHz (PC4000)
    * Type : 184-pin DDR SDRAM
    * Error Checking : Non-ECC
    * Registered/Unbuffered : Unbuffered
    * Quality Control : Comprehensive rigorously tested in pair at dual channel environment
    * Warranty : Lifetime
    I tested two kits to see if the the OC results are similar.
    Here some pics:
    This RAM also uses SAMSUNG UCCC IC's.
    I tested on two CPU's, a Venice 3000+ week 17 and a week 28 X2 3800+. Both average overclockers with at least memorycontrollers that can handle DDR600 with MP9x.
    Venice system:
    -DFI nF4 ultra-D BIOS 623-3 (official site bios)
    -Asus 450Watt
    X2 system:
    - DFI nF4 SLI-D BIOS 623 (Factory bios)
    - Tagan 480W-U22 2Force
    DDR500 3-4-4-8 1T stock tests
    3Dmark01, 3000+
    Everest, X2 3800+
    SPI 32M, X2 3800+
    Lets see what it can do when overclocking.
    What I have noticed is that this IC doesn't like high voltages. The sweetpoint is 2.5~2.65v.
    DDR540 3-4-4-8 1T 2.54v~2.58v
    SP2004, 3000+
    SPI 32M, 3000+
    DDR556 3-4-4-8 1T 2.54~2.58v
    SP2004, 3000+
    SPI 32M, 3000+
    Memtest86++ STD, 3000+
    Here 280Mhz 3-4-4-8 1T at same voltage!
    SPI32M X2 3800+
    3Dmark01, X2 3800+
    I also can memtest86++ 280MHz at 3-4-3-8 1T at the same voltage, but SPI 32M craps out.
    I think the average OC of this memory lies between 270~280 3-4-4-8. I see guess2098 with 3-3-3-3 OC, unfortunately I cannot achieve this timings on both CPU's.
    An important setting when going over 250MHz, is setting Read to write Delay on 3 or higher, 2 will nogo.
    Kakaroto,
    Feb 2005
    Belguim
    Great results kakaroto!
    I've been waiting for these sticks ,do you know when they will be in the shops in NL or B?
    Edit:I can pre-order them with B@W for 279€ (great price )
    http://www.bytesatwork.be/shop/produ...cat=474&page=1
    Aug 2005
    Ähm.. That SuperPI isnt correct.. U must let calculate 2 times SuperPi.. Every CPU must calculate one PI... When i try my ram it runs always, when i only test one of the 2 cpus.. but both of them.. no.. So plz make a dual superpi, then it is correct and then it is good.
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by WulleWuu
    Most of the time I tested on the Venice 3000+, which also can run 280Mhz 3-4-4-8 1T, no need to test dual SPI on X2 3800+ to show stability it is even little slower then on a single core.
    But if you want a dual SPI 32M i can do this when i have time, I am now running 24/7 @280 3-4-4-8 1T.
    Aug 2005
    Nice.. but my LEs dont want to run @ 250 Mhz with 2,5-3-3-7.... Do u have some ideas kakarote? I already tried ur guide.. but without success.. I need ur help, plz
    Bandwidth Freak
    Dec 2003
    Please PM me or post at the TCCD guide topic? This is off-topic. I will help you.
    Aug 2005
    I already send u a PM... and i already posted in ur tweaking guide
    Evil Kitty
    Jun 2002
    Detroit, MI
    Nice job M8! Good 411 on this new Gskill
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
    I am Xtreme
    Feb 2003
    Netherlands
    Great stuff mate.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Guru
    Aug 2005
    Burbank, CA
    i just baught these sticks from newegg, 280 shipped with tax, hopefully i can full off atleast 264 with mine, i wanna use 264x10 with my dual core, and what drive strength did u use, and data drive....
    Admin
    Feb 2005
    Ann Arbor, MI
    Good stuff! How about some 3-3-3-x and some more volts?
    Xtreme Mentor
    Oct 2002
    boston,ma
    Wonder howe far rhey will go at 3338
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    X.I.P
    Mar 2005
    kakaroto^^
    560 3-4-4-8 is ~~~ wooow! mine does 556 3-3-3-8 but 560 = no go ^^
    very nice oc
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by guess2098
    kakaroto^^
    very nice oc
    hehe mine 556~560 3-3-3-3 = nogo
    Apr 2005
    Atlanta, GA
    nice results! have you tried more volts?
    Intel C2D E6600 (L630B015)
    TT BigTyphoon || Zalman VF900 Fatal1ty
    Abit QuadGT
    2GB Corsair Dominator PC2-8500
    HIS X1900XT --> XTX
    Creative X-Fi Elite Pro
    OCZ GameXStream 700w
    Feedback:
    HEAT --- eBAY
    Sep 2005
    Italy
    Excuse if I interfere, i have bought the g.skill pc4000 2gb hz . But I have some problems to go above 250 mhz . I have tried many bios and timings, but the result does not change .
    Could you help me?
    [IMG][/IMG]
    [IMG][/IMG]
    Excused my English bad one.
    thanks to all
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by anomalos
    Could you help me?
    [IMG][/IMG]
    [IMG][/IMG]
    thanks to all
    what is your vdimm?
  18. #18
    May 2005
    Portugal
    Kakaroto sorry to bother you again but i´m a proud owner os a HZ 2Gb kit and i would like to see a A64 picture os the settings you are using,please.I´m with a few problems in stabilizing above 250.
    Intel C2D 8400
    Asus P5K/e wifi
    GSkill 8000PQ 4GB
    Corsair 620
    ATI HD4850
    WD 250 & 160 Hitachi SataII
  19. #19
    Champion
    Jun 2002
    lab501.ro
    I'm sure i've posted this somewhere, but here it goes:
    Optimal settings for high clocks
    3-4-4-6-1T 2.8V
    tRTW 4
    Drive strenght 3weak (5)
    Data strenght 1
    tREF 1032
    DQS increase 255
    Clocks damn well this UCCC
    I'll have the full BIOS setup for you tomorrow .
  20. #20
    Champion
    Jun 2002
    lab501.ro
    There you go, it is possible to tighten them a little though, especially on TRWT, Max Async and Read Preamble. These were random sticks and in no way handpicked/selected.
  21. #21
    May 2005
    Portugal
    Thanks Micutzu you´re a pal
    Intel C2D 8400
    Asus P5K/e wifi
    GSkill 8000PQ 4GB
    Corsair 620
    ATI HD4850
  22. #22
    Champion
    Jun 2002
    lab501.ro
    You're welcome . Testing was done with 704-2BTA BIOS on DFI nF4 rev.AD0 and X2 4800+ by the way.
  23. #23
    Oct 2005
    I can reach 290Mhz 3-4-4-8 2.6v. Maybe with a little tweaking i can get 295Mhz.
    Asus P6T Dlx
    i7 920 @3600Mhz 1.12v WC
    Transcend 6GB
    Gskill Falcon 64GB
  24. #24
    Dec 2004
    Excellent review kakaroto, nice touch testing 2 sets not just one.
    ATM I'm split between these and the PC3200 HS sets, I've seen the HS sets manage 250 at CL 2.5. do you think these HZ sets will manage CL 2.5 at there rated speed of 250?
    Cheers
  25. #25
    May 2005
    Portugal
    Micutzu ,no go here even with your timmings i´m afraid de memory controller of my Opteron is a crap.
    Intel C2D 8400
    Asus P5K/e wifi
    GSkill 8000PQ 4GB
    Corsair 620
    ATI HD4850
