DFI ULTRA-D
MUSHKIN
FX-57
DRY-ICE
DFI ULTRA-D
MUSHKIN
FX-57
DRY-ICE
presumably that is the RAM tht is under phase, and not the CPU?
That's a pretty bloody amazing ram clock, and what volts was it done at? How much of a gain did the phase bring you? and of course, any more stable than that? And superpi8m?
Conroe E6300 ES
2x1gb Ballistix PC8000
Asus P5W DH Deluxe (1705)
Manli Geforce 7950GT 512mb
Hiper Type-R 480w
Samsung SP250
"What did the quantam duck say?" "Quark Quark"
Awesom!
But, why is you cpu clock only to 2.6GHz?
Suma.
im guessing u pumped as much voltage as you could through them? that some amazing results man, like to see some bandwidth/latency results though. Also id agree with them and push your cpu clocks.
Fast mem how fast will the sticks go with air?
*EDITed by IFMU*
Signature Removed by XS Staff for not following XS Policies
Forum Policies
30.9 @ 2600Mhz is a great job
Woah i knew someone would do this sooner or later
Insane! (in a good way of course)
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
why not run it at 290 fsb @ 2-2-2-6 with asome overclock on yr cpu like 10x290 or 11x290
Phil
Originally Posted by eBoy0
Fat chance...i bet its mushy black lvl 2
Q6700
MSI P35
8GB OCZ
2xHD 2900 XT
PCP&C 1kw
Old skool BH5 is still damn good !!! Farkin Awesome results d00d :thumb:
Current Machine is my trusty Dell 8200 Lappy , while i make a decision
oooo000ooo thats madd.. well done
GA-EP3-DS3P | INTEL Q9450 @ 3.6 1.36v | TUNIQ TOWER| 2X2GB CORSAIR XMS2 | 5-5-5-15 | COOLMASTER M620 | GeCube HD3870 870/1371 | ChiMei 22" LCD 5ms | Thermaltake Armor Silver
Hardcorw. Good job!
YUP
That's hardcore alright, nicely done. Makes me think back to all the comments about Ram cooling doing nothing, maybe 2-3 mhz tops. Well I think you have just proven it was platform limited on NF2. It's another story on NF4 apparently.
Btw if you were in the Yellow slots it would have been higher
Is the board/Ram still alive?
That depends on the bios you are using. Usually -2 ones are much better in the orange slots and won't boot in yellow ones. Btw, -2 ones are used for UTT/BH-5.Originally Posted by G H Z
Mad cooling there, spl
I remember a while back when you were showing photos of the build process. We finally get to see results LvLII still rocks! I wonder, what those sticks were doing MAX before DI'ing them? What was the gain over conventional RAM cooling methods?
Jesus! DI on ram!
I saw LN2 for ram benchies, but it wasn't so "radically" done +) (sorry - dont know the right word in english)
nice
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
Cooled by:
Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
really awesome ^^
below 31s with 2600mhz is the best clock/time depending sp1m time i've ever seen ^^
did 31.6s with 2800mhz/260mhz ram (subzero problems that's why i couldn't get higher) so this is even 0.7s better - damn good bh5 ownage....why the hell you haven't broke the wr for amd systems with 290x12??? think that's no problem for you with this ram potential...never seen such a ram cooling been so effective...respect and congratz
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
SoF: With my Dothan 730 @ ~2340mhz I got ~29.8s super pi 1M.
<<zightx>>
<<Techsweden 3DMark Team>>
I think he's talking AMD, Dothan is a completely different animal.
Nice work. Now slap a container on that FX too and let's see some mad benches
I think RAM cooling is not a factor unless wou get subzero. but the it's great. That is what someone said, anyways. Froudeg, i think. He had waterblocks for mem, but it only workde very well when he used chilled water.
