Why You Want to Keep Your Input Rail to the Vmem Regulator Circuit 250mV, or more, above your Actual Measured Vmem Voltage
(Subtitle: Excerpts from a Looney OCer about Vmem Supply Voltages)
For several months now I've been suggested to people to make sure that the supply rail to their memory circuit on the DFI nF4 MB is several hundred milli-volts above whatever they plan to run their memory voltage at... and peeps are probably tired of hearing it by now
Well, I sat down this evening with some UTT memory, a good scope, and a BIG cup of java to look into another subject and along the way the java jumped up outta my cupand wacked me up side the head
, said "go ahead, show 'em why you've been prattled on about that dude." (I knew I made that pot of coffee too strong!
So along the way to doing some other things I grabbed a few o'scope shots that illustrate the point rather well and decided to pop up :worm: tonight and share. I'll agree that they aren't anywhere as near as interesting as a lot of other pics I've seen in these forums (especially the "scw thread"), but what the hey
Here we have Mr. Stability throwing out the first pitch with Vmem set at 3.0V in the BIOS:
Batting 1st, we have Vmem set at 3.0V +0.03V in the BIOS, playing MemTest T8 (left field):
3.0V +0.03V during Memtest T8
2nd up, we have Vmem set at 3.1V in the BIOS, playing MemTest T8 (center field):
3.1V during Memtest T8
3rd up, we have Vmem set at 3.1V +0.03V in the BIOS, playing MemTest T8 (right field):
3.1V +0.03V during Memtest T8
And batting cleanup, we have Vmem set at 3.2V in the BIOS, first in MemTest T8 (designated hitter):
3.2V during Memtest T8
and here wiffing at the ball trying to knock it out of the park, playing Windows:
What does it mean (besides that I'm loony as a bedbug)... well there are two morals to this story.
The first one is make sure you feed your MB properly:
If you use a "standard" 3.3V rail to supply your MB, don't go past 3.0V in the BIOS for Vmem.
If you use a "tweaked" 3.3V rail and the jumper trick to get higher voltages, keep the 3.3V rail at least 250mV higher than what you have Vmemset for in the BIOS. For example, if you are going to set Vmem to 3.2V, your 3.3V rail needs to be 3.55V or better.
And the second moral to the story is don't make your java too strong
We now return you to your regularly scheduled OC'ing session.
Peace![]()
), but what the hey
I kind of stopped looking at soft reading a while ago... I mostly use DMM these times
That's *my* concern too.
Very nice. Man, i wish you could get your hands on most of the PSUs around and review them with the appropriate knowledge for us the ignorant crowd. Thank you.
