Page 28 of 31 FirstFirst ... 1825262728293031 LastLast
Results 676 to 700 of 756
Thread: AMD Newark 3700+ @ 3105.1MHz Air-Cooled
  1. #676
    Love and Peace!
    Dec 2004
    hiding somewhere!
    i had a single stick of crucial value that did 263mhz at 3-3-3 without a hitch on the newark.. dunno how they're doing these days, or how 2 sticks would do
    Got a fan over those memory sticks? No? Well get to it before you kill them
  2. #677
    Sep 2005
    Quote Originally Posted by ozzimark
    Thanks for the reply ozzi, you don't happen to know which IC's that memory used do ya? Thanks in advance.
    Gigabyte Z68X UD3H-B3 | Intel Core i5 2500k | 2x4GB Patriot Viper Xtreme DDR3-1600 | XFX Radeon HD5870 | Seasonic X760 | HT Omega Claro Halo XT| Intel X25-M G2 80GB | Samsung F3 1TB | WD Caviar Black 2TB | Klipsch Promedia 5.1 Ultra | Samsung 2333T |
  3. #678
    Feb 2003
    I put another 10th of a volt on the 4000 Newark making it 1.68v and found another 70MHz on air to 3,293MHz.
    My ambient room temperature was 75F.
    v7
    Build in progress:
    DFI UT250 - 1015JJ Bios
    Newark 4000+ SLK948U
    2x OCZ400512ELGEVX - 3.2v
    ATI X850XT
    Sil Image 680 Raid-0 Maxtor 2x120Gig
    OCZ Power Stream 420
  4. #679
    Jun 2005
    very nice vector7, glad you picked up a good CPU.
    [SIGPIC][/SIGPIC]
  5. #680
    Feb 2003
    Quote Originally Posted by high5
    Thanks high5!
    You can't imagine how hard I looked for another 7MHz...
    Build in progress:
    ATI X850XT
  6. #681
    Mar 2004
    wow, that lil guy is doin pretty darn good vect. is that your 24/7 setup or just kill shots??
    SPECS::
    AMD Newark 3700+ DFI lanparty UT NF3 250GB 1x1GB Mushkin XP PC4000 3-4-3-8 WD Raptor 36 ANTEC TrueControl 550 GiGa 6600gt Lite On CD+R\RW Sony FloPy Kingwin Arctic LiquiD CooLer..((heavily modded by me)) Coolermaster Cent5
  7. #682
    Jan 2004
    Saskatoon, SK
    Fricken sick vector7, quite a chip you've got there.
    Anyone seen any other results out of the 4000+ yet?
  8. #683
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by vector7
    open a window, you'll find it
  9. #684
    Xtreme X.I.P.
    Nov 2002
    Shipai
    heres a tweak i used a few times:
    point a vacuum cleaner at the heatsink
    be carefull it doesnt get too close and damage the hardware though.
    in the end any vacuum cleaner is nothing but a very strong fan...
  10. #685
    Feb 2003
    Thanks for all the tips guys.
    I would open a window but with 50-60F nights here it wouldn’t help much, I know I tried it...
    Quote Originally Posted by saaya
    I wasn’t brave enough to put the vacuum hose in with all the fans spinning.
    So I’m still 7MHz short of 3300MHz.
    Quote Originally Posted by DmatkO
    The 3293MHz is a kill shot.
    To get 3293MHz I had to raise the vcore to 1.7v. On air it gets real warm real quick, idling around 110F. Water would probably get things out past 3300MHz and some serious cooling would make this chip soar.
    Here are some of differences I’ve seen between the Clawhammer-vs-4000+ Newark.
    The core on the 4000+ Newark is smaller than the Clawhammer. Maybe 25-30% making the idle temps warmer by around 7F. I’ve been trying to utilize the higher MHz speeds this CPU is capable of. But on air it's like walking a tight rope with voltage on one side of the beam and heat on the other.
    I have found that this chip scales upward easily on air:
    1.350v 2800MHz
    1.450v 3000MHz
    1.525v 3050MHz.
    It’s getting 3.1-3.2Gigs stable on air that’s the balancing act.
    I ran 3DMark at 3133MHz. At 3185Mhz I ran PiFast=40.08Secs & SPI 1M=29Secs. I ran all of these at 1.550v.
    The 4000+ Newark I have doesn’t mind voltage as I have had it up to 1.7-1.8v for short periods at or above 50C without problems. I found that at 3185Mhz on air 1.58v made the CPU load temps go beyond 50C to 53C. At this speed and heat benchmarks would fail after awhile. If I kept the vcore at 1.550v it would run longer at or just above 50C. If you could keep temps significantly below 50C you could probably then run intensive benches reliably at or above 3200MHz. You really need better than air-cooling to live beyond 3200MHz. I bought this chip as an upgrade from the 3400 Clawhammer. You should be able to run it at 3000-3100MHz with premium air-cooling all day. For me the Newark 4000+ was a worthy 500MHz upgrade not having to change board and vcard. I would like to see others put some serious cooling to one and find out what these chips are really capable of.
    v7
    Build in progress:
    ATI X850XT
  11. #686
    Love and Peace!
    Dec 2004
    hiding somewhere!
    well, it's 90nm vs 130nm..
    (if pic doesn't work, copy and paste this link: http://www.freewebs.com/cfeclipse/size.jpg)
  12. #687
    May 2005
    Camping your spawn :)
    Verry nice results indead, Making the move to another DFI board for my X2, this dam Asrock has been a pain in the ass with these dimms too, I hope I can eventually find a motherboard that likes em at 1T or even 1:1 so far the asrock 1:1 250-248
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
  13. #688
    Feb 2003
    Build in progress:
    ATI X850XT
  14. #689
    Jun 2005
    Portugal
    Very good chip, vector7. Congratz.
  15. #690
    Love and Peace!
    Dec 2004
    hiding somewhere!
    sexy. that thing owns my late 3700+ without a doubt
  16. #691
    Apr 2005
    Los Angeles, CA
    Nice!
  17. #692
    Jan 2005
    I want to get this 4000 but I am afraid that I may kill it with my Scythe Ninja...any ideas how to install it safely?
    *CPU: Xeon X5650 @ 4.3 Ghz | Cooler: Thermaltake Water 2.0 Extreme
    *Asus Rampage III Formula | RAM: 36GB DDR3 (Tracer LED + Hyper X Savage)
    *Video Cards: Gigabyte Aorus 1080ti
    Sound Card: Sound Blaster Z | PSU: Corsair HX1000W | Display: BenQ PD3200u | JVC RS520 projector
    *Case: CoolerMaster HAF X (932 side panel) | Others: Roccat Kone AIMO | Roccat Alumic | Logitech G15 |Cameras: Sony A7R3 | RX100 V
  18. #693
    Nov 2005
    Boston MA
    Very nice man, I have the same chip and I hit 3.13ghz easily on a stock air cooler. With water cooling I hope I can hit 3.3 ghz and maybe get it bench stable in the 3.2's. I think I got a good chip though, I am SPI32M stable at 2.88ghz at stock voltage.
  19. #694
    I am Xtreme
    Dec 2002
    Quote Originally Posted by shaolin95
    snap her in and bolt her down.
    these cores can take alot more then you think, ive never seen a cracked A64 personaly.
    i mean, be careful, but it should be able to take it.
  20. #695
    I am Xtreme
    Dec 2002
    yeah, good point, be sure to lay case flat and put even pressure on, i kind of considered that a given though, sorry.
  21. #696
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by Revv23
    i killed my newark pretty easily. it's not quite as strong as you would think, when you appy force at an angle. if you go straight down, it can take quite a bit... just don't get it angled at all
  22. #697
    I am Xtreme
    Jan 2005
    where the hell should I find a newark in Europe
    has anyone seen a shop that delivers in Belgium ?
    btw, how do the 4000+ oc in comparision with the 3700+ ?
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
  23. #698
    Banned
    Jul 2004
    Nice scores metalman and vector7, but at what speed are your chips OCCT stable and prime95 small ftts 8hour+ stable?
    I have burned too much money on flashy CPUs that do 3 ghz screenshots but arent stable above 2700 for everyday use..
    EDIT:
    vector7 is your CPU overclocked through BIOS or do you do it in Windows?
    If overclocked through BIOS, don't you get a lot of DETECTING ARRAY bootups?
  24. #699
    Feb 2003
    Quote Originally Posted by beta67
    The UT250 from the bios doesn't have booting up issues...
    Build in progress:
    ATI X850XT
  25. #700
    Nov 2005
    Boston MA
    3.33 @ 1.58v with my new watercooling settup, this chip may still have some more to give.
