Would like to know just how far you can push em?
I can make 228 at 2.9v.. wondering if they like more volts or not?
Thanks for you input
___________________________
E6400 @ 466x6 2.8Ghz 1.325v
Asus P5B Deluxe Wifi
2 x 1GB DDR667 @ DDR932 2.4v 5 5 5 15
512mb HD3870 @ 865:2600
Depends on the chips you have. Theoretically they would have Mosel Vitelic 5ns (that usually max out at ~230) ar Winbond CH-5 (which given enough voltage max out at 240-270, depending on how much votage and how lucky you are).
To recognize look the chips, without getting rid of the heatspreaders and the warranty, look at ths pics below :
Winbond chips :
http://www.xtremesystems.org/forums/...chmentid=28275
Mosel Vitelic chips :
http://www.xtremesystems.org/forums/...chmentid=28273
Hynix chips :
http://www.xtremesystems.org/forums/...chmentid=28272
Samsung chips :
http://www.xtremesystems.org/forums/...chmentid=28274
Thanx for de info scorp, help too me. I have another question:
Mosel or CH-5 is compatible at the same time with TCCD, over Athlon 64 machine?
For example, in four slots, 2x256MB TCCD and 2x256 Mosel or CH-5, what about timings?
I have a kit 2x256MB LC G.Skill.
It may work, depending on other factors, but I wouldn't reccomend it. 4 dimms on the A64 don't play well. Your RAM overclock would probly turn into an UNDERclock. just a Limitation of the on die memory controller, Venice should help fix this issue but its unknown how well it will work even then
jjcom
thanks mate will check it out when i get home
