Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Dual-Cascade Project (56K warning)
    Jul 2003
    SoCal
    I bought this device at an auction, a used Flexi-Cool® Immersion Cooler, a self-contained, dual cascade system:
    This device is meant to dip a cold probe into a liquid and chill it. I thought that rather than use at as a chiller, both inefficient and unwieldy, I'd enlist Chilly1 to put one of his vaunted evaporator heads on it:
    So I sent it to Chilly, and he broke it open and sent me some pics:
    Chilly reported the following about the unit:
    - It has totally flammable gasses.
    - R1270 first
    - R1150 plus R290 second
    - Compressors are 8.5 CC danfoss R12 compressors.
    So I had Chilly put on one of his blocks (Chilly can add his worklog and pics later when he gets his technical issues worked out).
    Here's what arrived on a pallet:
    Notice that Chilly was nice enough to include a thermocouple, complete with fluke connector:
    First fire-up, took a few minutes for second compressor to turn on:
    For preliminary test results, see post #2.
    <----- REST IN PEACE, KIT. 1993-2007.
    Mar 2005
    realy nice dude!
    Jul 2003
    SoCal
    This unit is rated for about 110W. Not enough for my 560J, but just right for my X800XT PE. So, time to strap it on.
    Chilly sends all of his creations with a selection of mounting hardware:
    I of course chose the tiny oval meant for ATI cards.
    Time for seal string!
    Here it is with some seal string. The connector coating on the card was pre-existing for a peltier:
    Backside:
    Now add some Armaflex (lots of it):
    More Armaflex:
    Yet more Armaflex, leaving room for soft-mods. I don't know why I left the ram sinks on. They were hard to take off, so I said screw it. They get really cold when the unit is operating, so they are now cold sinks.
    Not to be overlooked or underestimated, the almighty cling wrap:
    And of course, dielectric grease for the AGP connector:
    Ready for benching:
    We're gonna need a bigger desk (the hose is 6 feet long, so I can stick the cascade in various places):
    Unfortunately, I haven't had a lot of time for benching, but preliminary numbers are -85C at idle, 736 benchable core on 1.83 volts, up from about 660 on straight water (742 fails in middle of 3DMark). Can Riva test at 780. I need to bump up the volts to about 1.9v and do some benching on a cold night to see what she can do. A Vapo and a dual cascade really heats up the room!
    After I am done benching the video card, I'd like to try it on a Pentium-M with one of those 478 adapters.
    Thanks to Chilly1 for his great work.
    Jan 2005
    WOW ! cool and scary
    by the way "cling wrap" ? sorry if its a dumb question
    Dan
    I am Xtreme
    Aug 2003
    seran wrap. self stick stuff used to keep food fresh.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Memory Addict
    Aug 2002
    Brisbane, Australia
    wow nice
    Nov 2004
    Southeast Michigan
    Nice Job JD!!! That is some crazy stuff!!!!
    920 DO @ 4200Mhz 210X20 1.35Vcore HT on, everything except Turbo enabled!!
    MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's
    Gigabyte GA-X58A-UD3R, 6GB Corsair XMS3 1680Mhz 8-8-8-24 1.666V, QPI-3780Mhz, NB-3360Mhz
    2 Evga 460 Superclocked EE's in SLI
    BFG EX1200Watt PSU
    Windows 7 Ultimate 64bit
    5.5TB Internal HD space!!
    2 Seagate external HD's totalling 2.5TB's
    HAF 932
    2600K @ 4.5GHZ 1.280Vcore
    16GB Gskill Ripjaws 1600Mhz 8-8-8-24-2T 1.5V
    1 Evga 570 SC, 1 Evga 260 SC (Physics)
    PCP&C 750Watt Mk II PSU
    Windows 7 Pro 64bit
    2x120GB Gskill Sniper SSD RAID0
    2x1.5TB WD Black Sata III RAID0
    HAF X
    Heatware
    Feb 2005
    Would it be possible to regas it for a higher capacity, 200W+?
    P4 2.8 SL6Z5 (m0) @ 3.5GHz (1.7v, dual primed)
    Mach2 ST
    Abit IC7-MAX3 (no mods)
    2 * 512MB Corsair XMS3200LLPT (CH5)
    Raptor!
    Nov 2003
    That looks great!
    Thanks for posting your insulation. I'll be doing the same.
    Did you put some nail polish or dialectric grase on the heat sinks and the area were the vmods go?
    P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
    Jan 2005
    Quote Originally Posted by afireinside
    I meant why ?
    Dan
    Sep 2003
    Nova Scotia
    Again i'll say, AWESOME! was this a cascade that you bought somewhere and then sent it to chilly's to be modded with his block? If so, was it expensive to buy the unit? I'd be interested in somethng like this for my cpu as my future plan is to have a cascade hopefully one day i've never seen a cascade setup that wasn't custom built.
    DGeNeRaT3
    Sep 2003
    Nova Scotia
    i guess i should have read the post instead of just looking at the pics and then asking if it was a commercial unit, that answers my question about it being sent to chillys to be modded with his block, sorry lol.
    DGeNeRaT3
    Nov 2004
    On a crazy college campus! (Nash, TN)
    Quote Originally Posted by ZL1
    I meant why ?
    Dan
    Adds another layer of insulation
    Want your news on the front page? Click here!
    Jan 2005
    Quote Originally Posted by matt9669
    is it a must ?
    Im just being curious as this is the first time I see it
    Dan
    Nov 2003
    is it a must ?
    Dan
    I don't think it's a must, but it could be useful. I will use it not only for extra protection but to keep dust away.
    You can also read this thread; it mentions the use of saran wrap
    Jul 2003
    SoCal
    Nope, just some clear tape, then cling wrap over that. I need to be able to see it so I can put the clips on - they invariably fall off during install into case.
    is it a must ?
    Well, my cling wrap gets some dampness on it, mostly where the sinks are. Better on the cling wrap than on delicate components. A pretty cheap and easy safety measure...
    Jan 2005
    Thanks guys !
    Im considering going phase (decided to skip water ) and Im trying to get all the info
    sorry if I went OT
  18. #18
    Xtreme Recruit
    Oct 2004
    Sweden
    very nice!
    Corsair Obsidian 750D - MSI Z77 MPower - i5 3570k @ 5.0GHz - NZXT Kraken X60 - 2x8GB 1600MHz CL9 - 2x Asus GTX 660 DCU II SLI - 2x Intel 330 180GB SSD @ raid0 - Cooler Master Vanguard 700W
  19. #19
    Apr 2004
    Barcelona, Spain
    Congrats
  20. #20
    Mar 2004
    So-Cal
    How did you get the chilly1 block on there without regassing? It looks realy nice
  21. #21
    Jul 2003
    SoCal
    Quote Originally Posted by JSU
    I assume Chilly did the old capture-the-gas into an evacuated cylinder or vacuum pump trick, then re-gassed it when he was done. I do not claim to understand the evil magic of the HVAC.
  22. #22
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    WTF is R1270
  23. #23
    Sep 2003
    propylene
  24. #24
    Mar 2004
    So-Cal
    o chilly1 regassed it! so why didnt you have him up the capacity?
  25. #25
    Feb 2004
    Netherlands
    Quote Originally Posted by berkut
    WTF is R1270
    boiling point of -47.7*C also known als care-45
