Hi.
You told about there would be nothing in the BNOBTC to modify your BIOS files?
For example CBROM32 is able to modify the modules inside the Abit AS8 BIOS file
Code:
CBROM32 V1.44 [07/19/04 Release] (C)Phoenix Technologies 2001-2004
******** as8_17.bin BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
0. System BIOS 20000h(128.00K) 137C3h(77.94K) AS8_17.B00
1. XGROUP CODE 0FF20h(63.78K) 0B1D2h(44.46K) awardext.rom
2. ACPI table 03D49h(15.32K) 01794h(5.89K) ACPITBL.BIN
3. YGROUP ROM 0FD20h(63.28K) 04556h(17.33K) awardeyt.rom
4. GROUP ROM[ 0] 06620h(25.53K) 02BDBh(10.96K) _EN_CODE.BIN
5. PCI ROM[ A ] 06BC7h(26.94K) 04AFCh(18.75K) A.BIN
6. GV3 018FDh(6.25K) 00AECh(2.73K) PPMINIT.ROM
7. PCI ROM[ B ] 0D000h(52.00K) 07C3Ch(31.06K) RTSROM_M.LOM
8. PCI ROM[ C ] 0A000h(40.00K) 05CF6h(23.24K) RTGBPXE.LOM
9. PCI ROM[ D ] 0D600h(53.50K) 080F4h(32.24K) RAID_OR_3003.BIN
(SP) NCPUCODE 0C400h(49.00K) 0C400h(49.00K) NCPUCODE.BIN
Total compress code space = 5B000h(364.00K)
Total compressed code size = 58D4Eh(355.33K)
Remain compress code space = 022B2h(8.67K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
PGA478 2E 0F29 | PGA423 2C 0F25 | SLOT1 04 0F43 | SLOT1 0D 0F41
SLOT1 12 0F41 | SLOT1 02 0F37 | SLOT1 14 0F34 | SLOT1 0E 0F34
SLOT1 08 0F34 | SLOT1 0B 0F33 | SLOT1 0A 0F32 | SLOT1 0B 0F31
SLOT1 05 0F31 | PGA478 12 0F30 |
For example following BIOS logos could be extract:
The logos can also be replaced or removed, if you wish so.
( BIOS logo to PNG conversion and highest possible lossless PNG optimization & file size reduction by:
Borg Number One - borg_no [dot] one -at- gmx [dot] net
Thanks go to GIMP, PNGCRUSH and PNGOUT )
Changing/modifying the BIOS setup menue with the different versions of:
ModBin(6) is currently not possible,
because they bring error messages like: "Stack overflow!".
