Results 1 to 15 of 15
Thread: Gskill LA @235 with 2-2-2-5
    XIP
    Nov 2004
    NYC
    Heres tccd440 2x512 @3.1V
    Ebay Hater
    Aug 2004
    Denmark / UK
    Considering its 1GB kit its excellent, though your 1GB LA kit is probably the best on this forum
    In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
    Oct 2004
    Boston, MA
    I don't think his LE kit was too bad either, its in my system now, muhahah!
    File Server:
    Super Micro X8DTi
    2x E5620 2.4Ghz Westmere
    12GB DDR3 ECC Registered
    50GB OCZ Vertex 2
    RocketRaid 3520
    6x 1.5TB RAID5
    Zotac GT 220
    Zippy 600W
    3DMark05: 12308
    3DMark03: 25820
    Banned
    Jan 2004
    Land of Buckeye
    Go dumo, I think it can go 3 mhz higher.
    Mar 2005
    Would 243 FSB on 1Gig of LE wih a P4 be a respectable stable OC. 3.4GHz from a 2.8? I am going to try for the 3.5 after I move.
    XIP
    Nov 2004
    NYC
    This memory is flexible...I can run it @240 with 2-2-2-5 or @338 with 2.5-4-3-6 all 1:1.....Pick the timings
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    use large memory pages
    also try 2.5-2-2-5
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    May 2004
    Israel
    WOW
    ahhh this memory too expensive here 2000nis
    +400$ and more
    Israeli Defence Force
    Pentium 3 800@900 / TT Volcano 7
    Gigabyte 6VTXE-A
    384MB Ram PC100 (Hynix,Micron)
    Radeon 9700 Pro 392@360
    Evil Kitty
    Jun 2002
    Detroit, MI
    I agree that the LA is particularly flexible, but what's the point of running them at low mhz and tight timings when running them higher nets much more bandwidth? Although I am running Gskill in both of my DFI NF4 rigs with success at higher mhz, I would think there is better memory choices for low mhz and tight timings (like OCZ VX).
    Not criticizing, just curious as to whether there is any advantage at all to running the LA lower with tight timings.
    9900k @ 5.1Ghz
    Asus Maximus Hero XI
    32GB (8 x 4) Gskill @4000
    Strix 2080 Ti OC
    OS & Apps: Samsung 970 Pro 512GB
    Games: Samsung 970 Pro 1TB
    Storage: Crucial M500 2TB
    Seasonic Platinum 1000W
    Phanteks Evolv X
    XIP
    Nov 2004
    NYC
    Quote Originally Posted by mdzcpa
    Lower htt and high multi with 3.1V max vdimm for longer 3d benches (3d 01)..... 235x15 compares to 319x11....
    Aug 2004
    Manchester@UK
    is that Memtest, Prime stable or just SiSoft bench?
    XIP
    Nov 2004
    NYC
    Dont really care about memtest as long benched ok. It is not my 24x7 setup.
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Nice number again DUMO..........
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Evil Kitty
    Jun 2002
    Detroit, MI
    Quote Originally Posted by Dumo
    But you're giving up serious memory bandwidth. It takes closer to 250 to 265 at 2-2-2-5 to catch 300mhz+ with looser timings.
    You should be able to stable bench with 9MB in sandra.
    Still confused
    EDIT - Nice scores none the less Dumo
    9900k @ 5.1Ghz
    Strix 2080 Ti OC
    Phanteks Evolv X
    XIP
    Nov 2004
    NYC
    Combined with 2X512 Blue mushkin and the result is good even with 2T...
