Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 120
Thread: Best Memory timings for X8x0 XT/PE -> HERE
    Worst overclocker evar!!
    Oct 2003
    Harrisburg, PA
    tested all working values (ie ones that didn't cause artifacts) at stock speeds. These are the best I have found, with them i gain over 5 full frames per second in nature at the same clocks vs. stock timings.
    TRCDRD: 7
    TRCDWR: 3
    TRP: 5
    TRAS: 13
    TRRD: 4
    TWR: 6
    TR2W: CL+2
    TW2R: 4
    TR2R: USE TWR RULE
    TR2R: 2
    WR_LATENCY: 1.5
    CAS_LATENCY: 7
    CMD_LATENCY: 0
    STR_LATENCY: WR LATENCY
    REFRESH_RATE: 0x75
    TRFC: 23
    I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
    Jul 2003
    Thanks for this eshbach
    How do the best timing affect overall speeds? Did they lower your clocks at all?
    Oct 2003
    Harrisburg, PA
    my max benchable memory clock is unaffected but i do start to get artifacts earlier.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    stickied!
    great work ehsbach! thx a lot for sharing
    what are the best timings to reach the highest mem speed? maybe loose timings help to reach high enough speeds to make up for the worse latency again?
    Good results....5 frames accounted for.
    Oct 2003
    Harrisburg, PA
    Quote Originally Posted by saaya
    stickied!
    thanks!
    i will work on this next and post when i have the info.
    AMD Fanboy
    Jan 2003
    San Luis Obispo, California
    tested on my x850xt.
    i noticed a very good boost in low detail tests in 01, and a few in high detail. 10fps in nature.
    a+ settings!
    Dell Studio XPS16... no desktop
    yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
    Overclocking X.I.P. Otaku
    Nov 2004
    Kiminomori, Chiba, Japan
    The settings gave me a big boost in nature and a bit in drag but I had to clock the memory down from 668 to 650 to be artifact free...
    Dec 2003
    Wow!
    How long did it take to figure this out?
    My nature vent from 258.8 to 265 on stock frequencies.
    GJ
    AMD Fanboy
    Jan 2003
    Quote Originally Posted by Moonman
    Wow!
    GJ
    how is your nature so much higher than mine!
    im at only 255 stock with these timings. eshbach gets 263... what gives!
    Dec 2003
    Quote Originally Posted by Evil_Spork
    I have catalyst 5.1
    2.7Ghz cpu
    245 Mhz bh-5 mem
    Is that it?
    Feb 2005
    Estonia/Tallinn
    Looks like a nice job , well done
    Oct 2003
    Harrisburg, PA
    actually 264.5 before timings and 269.6 after timings w/ stock 2ghz cpu and 200mhz ram.
    Yes, it starts to artifact earlier, but if you wanted to you might still be able to bench at 668 without it crashing.
    Xtreme Legend
    Dec 2004
    Sweden
    Gave me a boost from 661 to 678 in drago low and 276 to 286 in nature (580/600MHz stock cooling and voltage, FX-55@3200MHz). These timings sky rocketed the temp of the memory and gave me artifacts as early as 605MHz. So I did a quick setup of active cooling and managed to match the default timings in max-oc.
    Good job there eshbach!
    Mar 2005
    Brooklyn, NY
    hm.that's a nice result for tweakering.
    What heatsink is good for oc and low temp for X800XL?
    ATI silencer 5? zalman any good, not the 80D-HD one.
    -100C Club
    Oct 2004
    Australia home again !!
    Hmmm what program are you using to adjust the cards mem as ati tool 0023 or whatever the mem settings bit is corrupt??? this is with an x850xtpe
    Quote Originally Posted by s7e9h3n
    Hell, if it would unlock this godly 154, I'd put on a tutu and dance around like a ballerina
    Mach 2 Problems Click
    My Work
    Oct 2003
    Harrisburg, PA
    Quote Originally Posted by fatty
    for X850 you'll need the .24 version.
  18. #18
    Sep 2004
    I'm getting corruption (straight after applying settings) on my Asus X800XT.
    And some of the "optimal" settings listed here seem to be increasing the latency (e.g. for some..value (original) 6 to (supposedly optimal)7)
    Does the Asus X800Xt have a different BIOS?
  19. #19
    Oct 2003
    Harrisburg, PA
    Quote Originally Posted by Xassius
    Does you X800XT have 1.6ns or 2.0ns RAM?
    i think since XT RAM is rated at 500mhz it may have difficulty doing these timings.
    and based on my bios, only one timings goes up and it does actually boost performance setting it higher rather than lower.
  20. #20
    Dec 2002
    Jersey City, NJ USA
    wow I wish I had an x850 to test this out! Hopefully soon!
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
  21. #21
    Mar 2005
    Finland
    great tweaking. Is there any tool to tweaks geforce timings ?
    AMD 3500+, Geforce 6800LE@16/6 1.42v 459/955
    Geforce 6800LE power!
    #2 in 3mark01 29.3k #3 3dmark03 13654p 5626p 3dmark05
  22. #22
    Jun 2004
    The Netherlands
    I'm curently running my x850xt pe @ stock settings. Will the stock cooler allow me to run those memory settings without artifacts? Or do I need some better cooling?
    Edit: I have tried the memory settings and they are kickass!
    Testrig:
    AMD Athlon 64 3500+ Newcastle (stock)
    DFI NF4 Ultra-D
    G.Skill PC4400Le @ 200mhz 2-2-2-7
    Sapphire X850XT Pe 540/590
    Before the memory tweaks:
    3dmark 2001se: 260**
    3dmark 2003: 132**
    3dmark 2005: 6332
    After the memory tweaks:
    3dmark 2001se: 262**
    3dmark 2003: 134**
    3dmark 2005: 6417
    Nice tweaks, but when I scanned for artifacts with Atitool I had artifact @ stock settings, so extra cooling is a must have.
    Intel QX6700 - Asus Maximus Extreme - 4gb OCZ DDR1600 - Sapphire Radeon HD 4870 CFX - Samsung SP 1TB - OCZ eliteXstream 1000w -
  23. #23
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    I tried the tweaks on 3d05 and only gained about 45 points... within the margin of error. but atleast you guys are getting good results
    btw is there anyway to make it so that ur computer boots with these settings?
  24. #24
    Oct 2003
    Harrisburg, PA
    Quote Originally Posted by MaxxxRacer
    3d01 result?
    which card exactly and what bios?
    are you sure the timings applied correctly?
  25. #25
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Great performance leap !
    But... Damn its hard on the card..
    Tested at my "std" settings, the one I use normally... Reached 29960 marks i 01SE, and 288xx before, quiet a leap... But I wanted to test at my "bench" setup, couldnt even apply,... It seems my mem has to go 20 mhz down than topspeed, and then it doesnt pay - Got 200 marks less than without the tweaking - but hey - Just my card, great job mate
    Best regards
    1 2 know
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
