Results 1 to 6 of 6
Thread: Quick Review: G.skill Low-level pc3200 2-3-3-6
    Feb 2005
    G.skill has intoduced new memory, for the low-level segment. It's not for the die-hard overclocking scene, so don't expect high overclockresults
    specifications
    Here are my testresults on the low level 1gb (2x512DC) kit of G.skill.
    With prime95 I can set higher speeds to run stable then the following maximum errorfree memtest-runs.
    Result with cl2.5 timings:
    You can also see, that this memory is running best with a vdimm of 2.65-2.70 volt.
    At stocklatencies, this memory has got a maximum overclock of 18 mhz (+9%):
    This memory is pure a low-level product from G.skill, but can rise to ddr500 and above on cl2.5. When you are overclocking with this memory, it is very important to have a good airflow in your case:
    This memory was tested on the following system:
    Motherboard: MSI K8N Neo2 Pl. k0411 (korean nf3 week46)
    Cpu: Amd64 winchester 3500+
    PSU: Tagan 480watt
    Cooing: Air at the memory, watercooling at cpu
    May 2003
    Timings are 2-3-3-6? Looks familiar... you can't try bumping the voltage at all? Think VX or UTT (and their low prices as well).
    Bandwidth Freak
    Dec 2003
    Question
    Here some test on the DFI Lanparty UT 250GB single channel:
    Memtest 2x512MB
    Memtest 2x512MB
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by quicksilverXP
    No its def. not Winbond.
    The markerings are also different.
    http://www.xs4all.nl/~famchow/Memory...00%20chips.jpg
    I am Xtreme
    Feb 2003
    Netherlands
    Sorry to say but this stuff has got to be real cheap to justify it's low performance.
    Is Gskill introducing this new RAM because TCCD has come to it's end of live?
    Why is all good RAM so short lived?
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Feb 2005
    Quote Originally Posted by Zeus
    This is just a product for the low-level market. It isn't high-performance memory and has nothing to do with their Tccd-products. I don't know untill when G.Skill will produce dimms with the samsung tccd-chips, and what their future-plans are.
