Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Thread: OPB's DFI NF4 SLI-DR Basic Tests
    Banned
    Jan 2004
    Land of Buckeye
    hi all, I know some of you laready ordered DFI
    So, I did some test on my daily basis setting on this board.
    Hope it helps.
    Let's see some impotant settings under bios.
    These parameters are what I have been discussing with Oskar so far.
    from Advance chipset:
    " Errata 94 Enhancement"..if you are using winne, you gotta disable this!
    some OC:
    for me, 292fsb can only use 2.6v vdimm
    some Dram parameters
    Bank interleave..is here.
    go on:
    Test setup:
    MainboardFI SLI-DR, bios 1.25
    RAM: GSkill TCCD LE 512x2, 1g dual channel
    VGA: Asus 6800 ultra
    power: PC P&C 510 SLI
    cooling Mach II改R402a
    Monitor: apple LCD 23"
    HD: Seagate NCQ 80G Raid 0
    Sisoft serial benches,Vdimm, vcore fixed for 2.67v, 1.48v
    1.CPU:
    2.sismultimedia:
    3.ram..
    4.cache:
    super pi :
    1m:
    4m:
    CPUmark:
    Let's see some DDR600 performance
    CPUmark:430:
    **DC**
    ddr600 pi 1m:
    ddr600 pi 4m:
    **DDR600 "2.5-3-3-6
    some test on TCCD running 2-2-2-5..
    2.78v,DDR460 "2-2-2-5
    DC
    thanks all
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    nice LCD
    ...droooooool
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Xtreme X.I.P.
    Dec 2003
    OPB, so what's that "Errata 64 Enhancement" option for then?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice any windows app to see if bank interleaving is in fact enabled ?
    can you do a bank interleave on/off comparison benchmark of memory bandwidth ?
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by eva2000
    I will definitely do that later on
    Oct 2004
    SC, USA
    OPB. Good results with those setup. Your SMARTGUADIAN is showing ATX 12V as 11.9V. I beleive you are using PC Power & Cooling PSU which is adjustable. Try and adjust it to something like 12.5 +/- 0.2V. for a stable 12V rail. The 3.3 and 5V rail seems okay.
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    Memory Addict
    Aug 2002
    Brisbane, Australia
    smartguardian has never been accurate normal under reports by 0.2-0.3v probably same for DFI NF4
    Nov 2004
    On a crazy college campus! (Nash, TN)
    Always good to have your preview, OPB.
    Looks like in your testing the board favors FSB over tight timings - which GSkill sticks are you using for the DDR600 benches? Was planning on getting OCZ VX for my SLI-DR, but now I'm not so sure
    EDIT: I see you're using the TCCD LE's, my bad.
    Want your news on the front page? Click here!
    May 2003
    Hey... you mean at High memory FSB... you can't run more than 2.6v? Or you mean at high HTT, you can't run more than 2.6v?
    That sucks.. I was planning to run my CPU at 305x9, and use a memory divider on some UTT or OCZ VX at 166Mhz divider... but I would need vdimm to be high at those HTT frequencies.
    Dec 2004
    Perth, Western Australia
    I wouldn't buy VX if you can get TCCD and want to get high fsb. Simple as that
    Dec 2004
    It's easier to get low timing with VX than getting high FSB with the TCCD running slightly higher timing at 1:1 that is why VX are nice as well too
    Apr 2004
    Vietnam
    good work guy, OPB... Which BIOS use 4 LDT Vol setting ? Thx
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    THX - nice work dude. Cross Ya fingers for me - need 11 x 306 or 10 x 336.
    What about " Errata 94 Enhancement" when usin' FX-55 and no winnie ???
    On or Off ???
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Jan 2005
    AMD factory
    Any answer ???
    Previous system:
    Nov 2004
    Keller, TX
    OPB, just a question, is this your work bench computer, or your home pc?
    Dec 2003
    Hong Kong
    Errata 94 Enhancement? what is that?
    CPU: XEON W3540 & Gulftown Q3FE
    MB: Asus Rampage III Extreme
    RAM: Corsair GT2000C7 2G X 3 ADATA XPG+ 2200+ 2G X 3
    SSD: Adata S596 120G
    Display Card: Asus EAH 5870
    WaterCooling:
    Laing D5 Pump + Koolance D5 Top
    Radiator: KP 120.3
    CPU Block: HeatKiller 3.0 + EK full MB Block
    PSU: Antec TPQ 1200W OC
    Case: SilverStone TJ-07BW
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by HARDCORECLOCKER
    Any answer ???
    OFF
    DevilR, that's my personal use computer.
    Zanr Zij,
    I think either 1.25 or 2.01
    quicksilverXP, sorry to let you confused,
    I mean I don't have to use high vdimm to do that high fsb..
  18. #18
    Dec 2004
    Hampshire, England
    i think u need to get a good air cooler tbh, 200C a bit high
  19. #19
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by shuRe
    ya?
    dude, 256 showing as 0c actually!
  20. #20
    Jan 2004
    Sweden
    the windows hardware shows it wrong, think it is something like 228-250=-22 or something like thata you need to do to get the right temps in windows
  21. #21
    Jan 2004
    Manchester (UK)
    Nice results.
    Good for you to show us the bios options. Seems to have a load of options on mem...
    That LCD of yours rocks Im thinking of buying a new LCD. Is it a widescreen btw ? Sorry for off topic
  22. #22
    Jan 2005
    AMD factory
    Quote Originally Posted by TinTin
    Me also don't know - but now I know it has to be off (#17 )........
    Previous system:
  23. #23
    May 2003
    I'm pretty sure it's Apple's Widescreen LCDs.... either the 20 inch of the 23 inch... or if my eyes are deceiving me.. the 30 inch. That alone makes all of us hate you.
  24. #24
    Jan 2004
    Manchester (UK)
    You got it right quick...
    and then he arrives with these results which are just 'basic' tests
    j/k
  25. #25
    Dec 2004
    Czech Rep.
    OPB does it again...
    So what would you guys reccomend for my DFI SLI-DR: G.SKILL LE's or some VX???
    "Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
