01-22-2005, 05:08 AM
#1
VCORE mod for MSI K8N SLI mobo needed!!
Hi, vdimm is done by ocz ddr booster, but i NEED more voltage to the cpu!
Can it be done? Has anyone done it? Pics?
HELP!
01-27-2005, 03:04 PM
#2
Moderator
HELP!
Haven't tried myself yeat
Be carefull M8
Edit: now the picture is right.
__________________
Best OC Regards
Tom Holck
Denmark
The Homeland of nVentiv and Asetek
01-27-2005, 10:45 PM
#3
Be carefull M8
Yes this should be the mod altough it is extremely tiny ..... damn ...
Vdimm mod maybe ?
__________________
Cpu: Core i7 920 @ 4.6 Ghz 1.33V (24/7)
Mainboard: Classified E760 @ B3 X58
Memory: 6GB Kingston Hyper @ 1770Mhz 7-7-6-22 -> 1.65V 3
Graphics Card: HD5870 + Waterblock
Soundcard: Auzentech X-Fi Forte
Boot HDD: WD Velociraptor 300 GB
Stuff HDD: 4x 1TB Samsung HD103UJ @ Raid5 (Perc 5i + 512MB)
PSU: Corsair 1000Watt Modulair
Water Cooling Setup: WC Setup - Swiftech Apogee XT / EK 360 Rad / 3x Triebwerk TK-122 / MCP655 Pump / Swiftech Reservoir
All build in a Corsair Obsidian 800D
01-29-2005, 11:50 AM
#4
Moderator
This works:
VR 20k ohm, turned to about 14-12 k ohm.
It will give you a little under 1.85 volt. If you try going higher the OVP shot down. Then go a little back. Then you have your max corevolt.
__________________
Best OC Regards
Tom Holck
Denmark
01-29-2005, 02:59 PM
#5
This works:
Nice thanks tom this is far more easy to solder than pin 9  :banana4:
__________________
02-05-2005, 06:01 AM
#6
Sorry, I'm a bit of a noob when it come's to modding. But what am I actually supposed to do with that VR 20K ohm? Could somebody explain it a bit further for me?
Thanx
Edit->
Nevermind.. I took a look at my board and this is WAY to small for me to solder....
__________________
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt." -Rami Belson | Specs!
02-06-2005, 11:26 AM
#7
X.I.P.
Will try, since no bios released yet...
02-06-2005, 01:05 PM
#8
Are you sure about the 20k ohm VR? Anyway, I will be buying the 20k VR tomorrow and wait for your reply.. Could you also please explain how you came up with the 20k VR? This really fascinates me and I would like to know a little bit more in detail.
Thank you!
john
02-06-2005, 10:49 PM
#9
Originally Posted by JohnnySK
Are you sure about the 20k ohm VR? Using a multimeter I got 1,2m ohm on the C5 - isn't 20k too little?  Anyway, I will be buying the 20k VR tomorrow and wait for your reply.. Could you also please explain how you came up with the 20k VR? This really fascinates me and I would like to know a little bit more in detail.
Thank you!
john
Please post pics of your mod!
Thanx!
__________________
02-07-2005, 01:30 AM
#10
Just wanted to make sure that I will do the right thing..
I am supposed to unsolder the C5 capacitor and solder the 20k ohm VR instead? Or connect it parallel to the C5 capacitor? Just need this info and I will get going with the mod
Fast relies are welcome,I am just waiting for this info...
john
02-07-2005, 01:36 AM
#11
Xtreme Vmod mod
You connect one end of the VR to the pin marked on the pic and the other end to a ground point (e.g a screw/mounting hole)
02-08-2005, 11:08 PM
#12
Has anyone tried this mod, and does it work? If I do it. Should I just watch the voltage in bios while I turn the VR. Set it to max in bios, and then turn it until it shows 1.7v. That's the max I want to be able to give it. A bigger picture that shows me where to solder would be nice. The small picture is good, but I have no idea where on the mainboard it is.
02-09-2005, 06:52 AM
#13
Moderator
It works! right to 1.85 volt. Then OVP shoots down.
Yes, set the VR on max 20 k ohm boot and use bios corevolt or software in windows to ajust.
The area on the small picture is close to the CPU
__________________
Best OC Regards
Tom Holck
Denmark
02-09-2005, 07:03 AM
#14
Okay, Thanks Tom
I'm always nervous when vmodding
Will try this mod this weekend. Other then the low vcore, I really like this card. Will also (hopefully) get my second 6800Ultra this weekend. Looking forward to running some benchmarks
02-09-2005, 01:20 PM
#15
Okay, Thanks Tom
Good! Please post pics! I'm probably even more nervous then you..
__________________
02-10-2005, 02:19 AM
#16
Hi ppl.. so I've done the mod! Don't have any pics as I don't have a digital camera. Unfortunatelly, it doesent seem to work
Turning the 20k VR while in BIOS I get to around ONLY 2k and the OVP shuts down my PC - but I can't see any increase in voltage at all? Neither CPU-Z nor BIOS info screen show any increase in voltage.. Have I done something wrong?
Oh yes, be carefull when soldering - by mistake I unsoldered the C5
Well ppl, so can someone enlighten me what could be wrong? Other than that, the MB workx fine even after the solder job..
john
02-10-2005, 05:38 AM
#17
Hmm that sucks.. I just got myself a 20k VR today...
Edit:
@JohnnySK: Perhaps it is not connected to a good ground point?
__________________
02-10-2005, 08:40 AM
#18
Well the OVP does power-off the system so it must be doing something.. Any gurus can help??
02-10-2005, 11:06 AM
#19
Xtreme Vmod mod
have you tried reading the voltage using a DMM? You could also check with a DMM if the point you solder to on C5 is connected to pin 9 on the chip.
02-10-2005, 11:58 AM
#20
Yup,it's connected to pin9..tried that after I soldered the whole thing. Where from should I read the actuall voltage? Could you post a pic plz?
02-10-2005, 12:31 PM
#21
Xtreme Vmod mod
You should be able to get a reading from one of the inductor legs around the CPU socket. You could also try to get a reading from one of the MOSFETS, but the voltage might be slightly lower than the true Vcore. If your careful, you might be able to get a reading from pin 16 of the IC too.
TBH, after looking at suggested circuit diagrams in the datasheet for the voltage controller I'm a bit doubtful about the mod using pin9 (feedback) because it doesn't appear to be connected to the output voltage in any way. To me, Vsense (pin12) would be more logical to use becasue it is connected to the output voltage, but that might depend on cutting traces. It depends how closely the motherboard designers have followed the refence circuit diagram tho.
If it has been said that the mod works tho, I guess that it will work ok using the feedback pin.
02-11-2005, 09:24 AM
#22
Got it to work yet?
__________________
02-11-2005, 01:48 PM
#23
Just to clear things up...
Pin9 of the ISL6566 regulator is marked wrong in the pic above!
Here's the correct solder point and some shots of the finished mod.
__________________
DFI Lanparty Ultra-D - A64 3200+ - 6800NU - 2x512MB A-Data DDR566 - 2x160GB Hitachi S-ATA
02-11-2005, 02:09 PM
#24
And by the way, here's the 3.3V rail vdimm-mod:
__________________
02-12-2005, 07:56 AM
#25
Thanx buddy!
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
