Results 1 to 16 of 16
Thread: can someone (OBP ? :) compare the msi k8n neo4 to the dfi nf 4?
    Dec 2004
    i really like to know whats the essential differences between the MSI k8n neo4 plat and the dfi lanparty nf4 ultra.
    I ordered the msi because it was the only board i knew which was a proven good overclocker...the time i ordered i didnt read anything about the dfi yet...and i dint want to order because of "hearsay"
    The dfi semms also much more expensive than the MSI.
    Gimme your input.
    Btw. planning: A64 3500+ wk 41, 2 xOCZ 3200 rev2, XP-90
    Banned
    Jan 2004
    Land of Buckeye
    The good for DFI is Vcore 2.1; Vdimm 4.0v
    so if you are die-hard overclocker, you might wanna take DFI
    MSI is also good,but vcore only 1.65 max; Vdimm only 2.85v but can use DDR Booster.
    Nov 2004
    Quote Originally Posted by Onepagebook
    NEO4 MAX 1.488~1.536V
    Dec 2004
    Quote Originally Posted by windwithme
    winnie: default voltage 1.4V
    ocz 3200 rev2 plat: 2.75 which is TCCD
    and i am running on air and plan to OC the A64 3500 to 2600/2700 with HTT 260 or 270...
    Do you i think the MSI would be problem ? Especially with a winnie which uses less voltage..shouldnt i be fine with the available voltages ?
    Banned
    Jan 2004
    Land of Buckeye
    bro..that's for winchester..
    normally, for fx55 and newcastle is 1.65v max
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    Quote Originally Posted by flexy
    The mobo is the most important part in your system, you never ever want to go cheap on it.
    For those of you about to post:
    Jun 2002
    which is faster clock for clock ?
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    Quote Originally Posted by craig588
    I did then I ended up getting another mother board. I had an ASUS A7V600-X and now I've got an Abit AN7...big difference in terms of preformance and overclocking
    jjcom
    Dec 2004
    craig, i really dont have a reason to believe the msi k8n neo4 is a 'cheap" motherboard. One reason i ordered was actually that some people (OPB etc.) already had this board running..and i didnt see any reason NOT to get it
    (Overclock wise etc..)
    Seems the only negative thing is the max voltages....but i dont see that as a problem for normal/moderate overclocking. People got as high as over 300HTT....and did not have any problems with it.
    I am/was really interested whether the MSI and dfi (in normal, real life use ) has some major disadvantage compared to the dfi..besides the max voltages ?!
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    yeah besides, theres mods for the Vcore correct? So you can always go higher
    jjcom
    Nov 2004
    Ontario, Canada
    to OPB, is booster way stabler than 4V VDIMM mod on DFI's board?
    Winchester 3500+ 0437
    Thermalright XP90+TT Silentcat 90mm
    2x 512M OCZ 3200 Gold VX 266 2-2-2-5 1T 3.9V
    Neo2 Plat ~1.3b6
    eVGA 6800U ~445/1150
    OCZ PowerStream 600W
    Lian-Li V2000b slightly modded
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    BigToe looked into this in the DFI board thread. Sounds like when you get the Vdimm from the 5v rail the Vdimm gets kinda unstable and the board gets rather hot.
    jjcom
    Nov 2004
    Ontario, Canada
    to jjcom you saying booster is kinda better?
    Neo2 Plat ~1.3b6
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by MarilynMX
    I believe it'd the same. not big difference
    OPB
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    Seems like if you want a higher Vdimm than maybe just upping your 3.3v rail is best, but if your going for a higher voltage than you would feel comfortable with, such 4v. than the 5v rail option is a nice one. Seems like if you kept the Mosfets nice and cool there would be less problems...but...Would a prescott be a good example here, its hard.
    jjcom
    Sep 2003
    Alpharetta, GA
    If you don't need/want SLI, seems like the MSI w/booster would be the way to go. On the vcore, 1.65v is more than you should be giving a Winnie anyway for air.
    Current system:
    Case: Modded Watercooled Jpac
    CPU: Intel Q6600 @ 3.5GHz [1.47v] - OCCT stable
    Mobo: DFI LanParty Jr T2RS @ 432fsb [1.37v]
    RAM: Crucial Ballistix Tracer 4*1GB DDR2 @ DDR1095 (5-4-5-15) [2.2v]
    HD: WD 300GB Velociraptor / WD 640GB Caviar
    GPU: HD 4850 Crossfire @ (700 | 2200)
    PSU: OCZ ModXstream 780w
