With FX55 HSF, i think it's not so bad
K8NXP-SLI
Max screen 14° Ambient
K8NXP-SLI
lol I was right
I love XS
Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
I want a Penryn 3.33G 12MB & quad sli Nvidia G92
where is the 32MB screen?
a 100% french thread?
I love XS
Hide the 32Mo screen, very very bad score xD
2500K, 6970, Acer 245HQ
E8400@3.85 + Vdroop P5K
32M is coming but OS is always dead
maxmem + win2k3 + best ram frequency + superpi realtime priority
I love XS
Great Stepping!!Think i have to get one of these SPAWs.But i have also a good one:A 0445VPMW,3200 Athlon.Now i test it.I run prime with 2730 MHz for one hour now also on air with 1,52 Volts.Hope to hit 2,9GHz.
The only way to get rid of a temptation is to yield to it. Resist it, and your soul grows sick with longing for the things it has forbidden to itself.
i'm bluffed.
Je suis pas francais mai je peux m'y mettre mes felicitations misteroadster joli oc.
What memory sticks are you using ? What's the max PrimeStable ? ...
Nice one!
Can u please tell me the complete code on the IHS? Thx.
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
Pas mal mieux que certains frenchies sur nos forumOriginally Posted by Zyklon5
I'm using BH5 , i didn't primed it for the moment.
@Misteroadster:You dont want to increase the Voltage to 1,6 or 1,63?I think this one can hit 2900 MHz
yes, with an XP120 for sure.
More than 1,6 is useless, even worse.
Maybe useless,it depends on the chip i think.Same as XP:Some chips take only 1,9,more dont bring only one MHz more,another chip takes more than 2 Volts and gives its oerformance only with 2 to 2,2 Volts.Some are so and some are so.
then mister
here u go with ur chiller after ur article
I love XS
Take the IHS off carefully. What temps do you get now?
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
yes of courseOriginally Posted by cpulloverclock
don't need to do that , i ve got a 55 for the high perfOriginally Posted by IvanAndreevich
Whats a spaw?
SPAW are some letters of the stepping.
I'm actually running prime at 2805Mhz , i'm very impressed , it's the same frequency than my FX55 0445 Full temp : 51°
CBID tell me: generation 15, model 15.1, version 3.1, Prating 4409+.
BTW: i'm benching in opened case.
I love this winnie
