Dont you think vDimm from 3,3-4,0 will be enabled after setting some Expert Mode or something. Seems strange with a spectra that starts as high as 3,3 volt.
¤ Gigabyte GA-P35-DS4 ¤
¤ Core2Duo E6400] ¤
¤ Mushkin XP2 8500 2x1Gb ¤
¤ Gainward 8800 GTS 640MB @ 702//2200 ¤
¤ Water Cooled by DD ¤
¤ OCZ PowerStream 520W ¤
3DMark 2003 ==> 39203p
3DMark 2006 ==> 12295p
Oh the Vcore will be usefull
Im not a guru like OPP to make my own cascades, im sure i would try if i got a FAQ/walkthrough (wink wink hint hint ), so untill further notice it will only be a VapoLS, around June. My chip isnt the best, but it should do some 3400 @ 2.1Vcore
Cant wait untill Venice
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
I don't make my own Cascades. PCIce makes my cascades.Originally Posted by TS_PHI_PERRY_78
If I did make them, they would be the best
OPP
I've skipped over several mobos waiting to upgrade my A8V 1.02, this looks like a winner so far!
Intel E6700 @3700
Asus P5W64
Kitty Litter Water Coolertm
2 x 1gb G.skill 6400 HZ
"Some people couldn't get a clue if they smeared their body with clue musk and did the clue mating dance while sounding the clue mating call in a field full of horny clues at the height of clue mating season."
The Dual Xpress Graphics Function supports the following:
Two PCI Express x16 Graphics Cards"
Does this mean X800XT in Dual mode? :banana4:
$299USD and they'll sell out faster than believed possible......
C
WHAT ?Originally Posted by charlie
Well I know Im gonna have one, and I dont care what it costs.Originally Posted by charlie
¤ Core2Duo E6400] ¤
so i can select 3.5vdimm to VX ram and it will be okay without any extra coolingOriginally Posted by Jessfm
would ocz 520w PSU be okay for that ?
Insane board!! I do need to get a rid of my MSI now and buy a DFI+PCI-E card(s).
Intel FTW!
Beanna
Well im just looking for a place in sweden to preorder the mobo:
3500+ Winchester, OCZ PS 520W and a 6800GT is ordered. Just cant decide if i should change to a X850XT or not
¤ Core2Duo E6400] ¤
Now the question is, which boards are ye getting?
And it'll be worth EVERY penny.
The "Definitive" motherboard has arrived.............
Originally Posted by Nube
OCZ 520W better be OK with it, that's what I have
OPP
Looks like nF4 SLI-DR to me :/
What is UT anyways? Obviously NF4 SLi-DR is better than UT NF4-SLI-DR as its the top model :|
Ut mean the board only,like any other mb maker sell
the normal lanparty come with everything,cable,pc transpo,etc
hummm I got a X800XT being replaced thats AGP I could trade that in for a PCI X800XT
two questions
1. would a X800XT pci card work on this??
2. my 3700eb is stable on my A8V at 3-2-2 @ 247 and 3-2-3 @ 259 with 2.8ish volts. What would you guess my EB could run with 4v avil to it???
i7 6700K @4.8 ghz
XSPC RayStorm (very nice block)
Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
XFX-7970 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
Crossfire 30" decent monitor for IPS too bad SED tech died
Docsis2.0 Docsis3.0
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
1)The X800XT will work no problem.Originally Posted by iboomalot
2) I don't think EB will like that much voltage, wild guess says around 280MHz with about 3.5V.
OPP
I want to see what it will do with the same parts Opp had in the neo2 the bh-5, fx55+x800xt at the same clocks in 3dmark 2001
I wonder if it will be as fast, faster or slower .
What does: "Diagnostic LED connector" and "FronX" mean??
¤ Core2Duo E6400] ¤
The cheapest I can't affordOriginally Posted by TS_PHI_PERRY_78
Diagnostic LED connector is probably something like MSI's D-Bracket leds. FrontX is a front bay device with all the handy connectors (USB, audio) upfront...Originally Posted by Dirt
THANK YOU VERY MUCH FOR THE MANUAL
I'm sure that this will change the lives of many people...
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
Well..lets see about that. Specs are nice, but I have only seen 1 bench so far and it didn't give a clear picture. So we really know nothing about this board other than it has potential on paperOriginally Posted by charlie
The only thing that makes me cheer atm is the fact that Oskar has been involved in the design
With the risk to be laughed at... who is this Oskar fella?
D O S: Okey. I need the DFI UT nF4 SLI-DR then
¤ Core2Duo E6400] ¤
Oscar_Wu from some french forum right?
Dahl @ Techsweden.org
