Results 1 to 24 of 24
Thread: K8 3000+ 0448s**w 1.4v oc 2.7g pass
    Nov 2004
    K8 3000+ 0448SPAW 1.4v oc 2.7g prime95 pass
    My Friend jeffchen test
    A8N-SLI Deluxe
    G.SKILL TCCD-LD 256M*2
    Tt PIPE101
    I buy 0448spmw,not good
    May 2004
    East Bay, California
    wow, thats fantastic - and at stock volts. So the spaw are the good ones? (for that week of course)
    Feb 2004
    Houston, TX
    900 mhz overclock on stock voltages..That's an amazing chip.
    Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
    Gigabyte DS3 C1 F8i
    2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
    Asus EN6200 8 pipes enabled
    250GB Hitachi T7K250
    Fortron Blue Storm 500W
    Antec P180
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Yea that is sick dude. Try for 3ghz mate under 1.5volts.
    Oct 2003
    Massachusetts, USA
    Post
    thats just awesome.
    AMD XP-M 2600+ @ 2.4GHz (12x200) - 1.75v
    DFI NFII Ultra Infinity Rev. A
    2x1GB Crucial Ballistix Tracer PC4000 @ 400MHz 2-2-2-5 - 2.8v
    BFG 7800GS @ 475/1550
    OCZ Powerstream 600W (+3.6, +5.4, +12.6)
    Swiftech MCX462-V-->92mm Tornado-->MCX159-A
    nForce UDP 5.10
    Forceware 97.44 XtremeG
    Win XP Home SP2
    Oct 2004
    UK, Westbromwich
    holy truly amazing bro. id be happy is i could get to 2.7... ime stuck on 2.625 on 1.64V
    CPU: Phenom II X4 955 @ 4800Mhz
    Mobo: Gigabyte GA-MA790FXT-UD5P < Died
    GFX: Asus ATI HD6970
    Ram: OCZ 2x8gb corsair vengeance 1600
    PSU: Corsair HX650w
    HDD Crucial M4 SSD 128gb, 1tb spinpoin and WD green 1TB
    Dec 2004
    Perth, Western Australia
    What are the ones beside SPAW?
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Nice videocard there.
    These winchesters are doing BETTER and BETTER every month. 1 month + 100 MHz at least.
    0441 = 2.7 ghz
    0448 = will do 2.9 with voltage
    BTW, how did your SPMW do?
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Dec 2004
    all i can say is wow.
    lets see that thing with some more volts! :banana4:
    EDIT: also, is it just me, or are the 3000+ 939s doing better than the 3200+ on average, certainly seems that way at least....
    Xtreme X.I.P.
    Dec 2003
    maybe it's just me but it seems kind of unreal that this chip clocks 900Mhz higher than stock and doesn't need any more juice than default volts
    it's just my nature to doubt before i'm 100% sure if i'm wrong, then congrats to you :thumbsup:
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    bachus_anonym
    Very late week - o/c'ing gets better. Besides, this guy seems alright.
    Nov 2004
    someone buy 0448spmw 1.36v oc 2.7g pi 1m pass
    my 0448spmw only 2.4g
    Champion
    Nov 2004
    Hungary
    Who can do 2,7ghz on 1,36v?link?
    What can your cpu max speed?
    Xtreme X.I.P.
    Dec 2003
    not that this will matter a lot to many of you guys....
    i will start to believe that this chip "does" 2.7GHz @ stock voltage when:
    1. i see superpi 32M @ those settings,
    2. same as above @ MAX that this chip doesn on AIR.
    hypothetically... if MAX (superpi 32M stable) will be only 2800-2900Mhz ON AIR @ whatever voltage possible then i wil call threads like that (sorry if it's not allowed) atleast "misleading"
    EDIT: as the only way to prove speed and voltages would be making video of benchmarking session (at least with a webcam) i assume that this will not easy to acomplish...
    Nov 2003
    Copenhagen, Denmark
    Suddently I feel that my 2.7GHz @1.6v is not that good after all
    Cause this is just one hell of a chip u got there!!
    MSI K8N Neo2 (Korea 0508A2) | A64 3200+ Winnie 0446SPDW @2700MHz 1.60v | A64 X2 3800+ ADBFE 0626DPMW @Still testing - cooled by Big Typhoon| 2x512 Mushkin Extreme L2 @270MHz 2.5-4-3-7 2.5v | Leadtek 6800LE 1.3v@GPU (12x1.6) 450MHz/800MHz | 120Gb Seagate Sata w. NCQ | Chill Innovation 510a PSU made in Denmark! | Lian Li PC7 Plus EU + Additional Lian Li case gear all the way | 19" Hyundai L90D+
    Jul 2004
    Belgium
    Xtreme 3DTeam Member
    Jan 2004
    Dresden
    so how is it with 1.6v ?
  18. #18
    Sep 2004
    Now he needs a high HTT board to get max of this chip out
    That's an AMAZING chip
    Congrats
    AMD Athlon 64 3200+ NewCastle @ 240 x 10 = 2400 MHz @ 1.550 V
    MSI K8N Neo Platinum 1.52 Beta BIOS
    2x 512 MB DDR500 A-DATA Vitesta Hynix @ 240 MHz 1:1 2.5-3-3-7 1T 2.85V 24/7
    Sapphire Radeon 9800 Pro R350
    Enermax EG365AX-VE FMA 3.3V@32A 5V@32A 12V@26A
    DVD-RW TEAC
    Seagate 200 GB SATA + Maxtor 300 GB SATA
  19. #19
    Sep 2004
    What stores are these 0448's coming from?
  20. #20
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Me and my friend are going to scout local stores for a late week chip now. I need a server, so any chip will do there.
  21. #21
    May 2004
    대한민국 강원도 원주시 Wonju, South Korea
    I want to see what the E0 stepping chips will do... This is just a taste of what is to come.
    Let the upgrading commence!
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    2x8GB Avexir Raiden DDR4-3000 15-15-15-35
    Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
    512GB Samsung PM961 + 840 Pro 256GB + some TBs
    Corsair AX1200i
    X-Star DP2710LED @ 110Hz + 40" Samsung TV
    CPU and GPU under water: 9x120 rad + 3x120 + 3x120
    ...and an HTC Vive!
  22. #22
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    mcnbns
    I actually think 3 GHz on air will a common sight with those chips.
  23. #23
    Feb 2004
    Tallahassee, Florida
    I'm seeing 2.7 out of these chips fairly often now, which is why I really consider them the best price/performance available currently... incredible headroom on these chips. I tried to explain this to my fiancee, lots of hand waving... situation looks promising. Hopefully I'll get one soon.
    Posted by Rich - empyrean@ice.org
    CPU: 2600-M@11.5x220 - MB: DFI Infinity - GPU: 9800Pro@453/772 - RAM: 2x256 Mushkin L-II BH5 - HSF: Air@Volcano12
    Power Supply: Tagan 480W Hard Drive: WD Raptor 74GB- Monitors: 19" KDS Trinitron / 17" LCD
    SuperPI Challenge: 37 sec. 3DMark2k3: TBA- 3DMark2k1: TBA -Aquamark3: TBA
  24. #24
    Aug 2003
    Germany
    I've tryed an 0450UPMW yesterday, it gaves me an Bluescreen all the time
    at the 10K FFTs iteration with 2.0-2-2-5 1T and with 2.5-3-3-7 1T at
    the middle of the 12K FFTs(*)! I only have BH5s here, maybe with other Ram
    its an good Proz. but not with that... I think the IMC is the biggest crap
    i've ever seen!
    (* 2600 - 2700 1,4-1,5V)
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
