i was thinking about doing the 3.3v vddr mod, i don't have a multimeter but its just soldering a wire right? i was wondering if it is safe to pump 3.3v into my ram 24/7, i know bh-5s can handle it but not sure about mine, tia
Not for tccd. Above 1.75V you wont see any performance increase
Edit: I meant 2.75V....
Originally Posted by Dumo
I see a performance improvement with 2.85v. I need 2.85v for my pdp to be stable at 268HTT. I was going to use an OCZ booster but it doesn't work and I still haven't had chance to find out why or RMA.
I was told that pdp use the voltage loving variant of TCCD. I was going to give it 3.3v myself and find out, but I don't want to do the Vmod.
£58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk![]()
Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
bobmanfoo
Just cause it likes 2.85V doesn't mean it will like 3.3V... only way to find out is to try or to find somebody who already tried![]()
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
Mine is tccd 431 that ran fast at low voltage. I can do 295 with 2.65VOriginally Posted by GazC
Do the mod and see how far you can go with cas 2. With my PDP I can do 220FSB 2-2-2 w/ 2.9v (my boards max) and 270FSB 2.5-3-3 w/ 2.7v. I'm sure I could go farther with cas 2 if I had more voltage. Go for the mod, TCCD is rated up to 3.6v, just make sure you have a fan blowing over your ram if you decide to go that high.
Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
Gigabyte DS3 C1 F8i
2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
Asus EN6200 8 pipes enabled
250GB Hitachi T7K250
Fortron Blue Storm 500W
Antec P180
Originally Posted by JDizzle
rated up to 3.6v?????? whoa dude where did u get that from....
It's somewhere on Samsung's website. I've heard it mentioned many times on the forums though.
Gigabyte DS3 C1 F8i
Antec P180
i ran G-Skill's TCCD @ 3.28 (Abit AV8 BIOS) and got 2-3-3-8 into the 260's.
that seemd to be the "sweetspot" (more or less V = less stability @ 2-x-x-x)
used a Booster
they got HOT! (both RAM and Booster) hotter than with VX or BH-5's...plan on using a fan
i "maxed out" @ 3.45V (but not for long) ...didnt really help any
JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe - - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master - - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
have my open and close loop ready and will ill give it a go after i get some more AS5, damn a64s use so mush as5,
Hah, I picked some up at Microcenter yesterday for $7. Let us know how it goes.
Gigabyte DS3 C1 F8i
Antec P180
I read somewhere that TCCD likes voltage when running Cas2...
I tried it today in Memtest, and sure enough...
230 @7-3-3-2, 2.85v, less Voltage I got errors at 230
Funny thing is with cas2.5 I get the least errors(and highest fsb) when set to 2.5v
Weird
Zen2 Has brought AMD back!
lol, i might have run into you out there, just picked me up a tube earlier and the vmod was a success, results:Originally Posted by JDizzle
2.85v
215mhz 2-2-2-5
243mhz 2-3-3-5
260mhz 2.5-3-3-6
280mhz 2.5-4-4-8
3.3v
230mhz 2-2-2-5
255mhz 2-3-3-5
270mhz 2.5-3-3-6
285mhz 2.5-4-4-8
can't get 290 stable for the life of me, seems to have hit a wall, but good results none the less, the chips get pretty hot with 3.3v even 2.85v was hot, but not anything a 92mm sunon can't handle, off to mess with some more settings, i'll try lowering the vddimm to 2.5 and see if i can hit higher fsb![]()
Looks good, I'll probably bump up the voltage once I get the DFI. What's your system look like?
Gigabyte DS3 C1 F8i
Antec P180
hey bobmanfoo, what is this open and close loop???? plus give me a link to doing this mod yeah??? right now im running @ 280 2.5-4-4-11 @ 1.85 volts @ 1T. If i can pull this vdimm mod i can prolly take it to 290!!!! so help me help me help me help me...
i could enable/disable the mod by having a bridge between the connections, in my case i modded a pair of molex plugsOriginally Posted by NonProphets
jdizzle- specs in sig
A64 3200+ 2.65ghz | 2x512 OCZ VX 265mhz | Connect3D x850xt PE 680/650 | DFI NF4-Ultra
can u post a pic or a link or something?
why so high voltage for tccd? this my tccd431 at 2.5-3-3-7 and 2.65V only
my pdp does react to voltage as well.
2.65-2.85v: 2-3-3-6 maxed out at 243
3v: 2-3-3-6 @ 252
maybe it can go higher wif a lil more voltage.
You are using half point multiplier so it's not really 1:1 @295. It's still very good though.Originally Posted by Dumo
oh sorry, http://xtremesystems.org/forums/showthread.php?t=41350Originally Posted by NonProphets
