Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: GSkill + K8N Neo4 Platinum =>DDR710 Dual Channel?!
    Nov 2004
    DDR710 256MBX2 1T CL3 4-4-8 2.85V
    Dec 2004
    Flying through Space, with armoire, Armoire of INVINCIBILATAAAAY!
    Impressive. 2x256 sticks? How about 4?
    Sigs are obnoxious.
    Apr 2004
    Vietnam
    I Think it can't @ 1T if U don't show A64Tweaker + Everest + CPUZ n Show timing on Sisoft Sandra.. . Because U can do some cheat that I can do... hehe sorry...
    Bandwidth Freak
    Dec 2003
    Nice results, although the bandwidth suck. 7.3K, with 310Mhz 2.5-3-3-5 1T you will hit more.
    Quote Originally Posted by Zanr Zij
    If you take a Good look at the screen, hint right.
    Quote Originally Posted by iddqd
    four will definitly give problems, 4x256 is worser then 2x512MB
    Nov 2004
    256x4 is bad
    Apr 2004
    Vietnam
    Quote Originally Posted by kakaroto
    Because U don't know the way ... sorry . Anyway very nice
    Nov 2004
    Original picture
    Xtreme Mentor
    Oct 2002
    boston,ma
    That is very impressive.
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Nov 2004
    Thats amazing. It's like PC-5600.
    May 2004
    Sweden
    My EB gets 7.3k sandra with 250MHz @ 3-2-2 1t.
    But ddr710 is still pretty cool
    Xtreme 3DMark Addict
    Sep 2003
    "Nice results, although the bandwidth suck. 7.3K, with 310Mhz 2.5-3-3-5 1T you will hit more."
    thats 3-4-4-8 timings for ya and thats why amd isnt interested in supporting ddr2, its too expensive and its high latencies would negate the advantage of 300+ fsb anyway. how stable is your ddr710 by the way?
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Xtreme Enthusiast p4z1f1st's Avatar
    Feb 2004
    pfff.....not impressive - with CMD 2T
    Quote Originally Posted by Moos3d
    with PC-5600 @ 1T you should get about 10k @ Sandra bandwidth....
    ----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
    ----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
    ----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
    ----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
    ----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
    ----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
    ----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
    ----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
    Feb 2004
    Houston, TX
    Quote Originally Posted by windwithme
    Is that 1t or 2t?
    Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
    Gigabyte DS3 C1 F8i
    2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
    Asus EN6200 8 pipes enabled
    250GB Hitachi T7K250
    Fortron Blue Storm 500W
    Antec P180
    Nov 2004
    Quote Originally Posted by JDizzle
    Is that 1t or 2t?
    thats what you get for loose timings! cas3 7.3k with ddr710 should be getting a lot higher
    Jun 2004
    Bavaria,Germany
    Yeah 2T kills all the nice performance you would get on 355...
    Nov 2004
    Il
    look on the far right screen, its says command rate, 1T.
    Feb 2004
    Is that 1t or 2t?
    really simple answer: he lies......
    every idiot gets >8k with ~290MHz @ DC.....so, now we just get <7500MB/s with horrible 355MHz ?!
    pfff...
    EDIT: ok, noe i relize the extreme low multiplier.....that could be the reason.....how we all know, the A64-MC gives lower bandwidth with lower multiplier.....
  18. #18
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    he really has 1T
    the reason bandwidth is so low is because his cpu is running at a low speed, pop a 3.4ghz proc in there and hed see 9k
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
  19. #19
    Nov 2004
    1T or 2T? The software shows in the picture
    There is comparative test of 1T or 2T to here
    http://www.xtremesystems.org/forums/...ad.php?t=48167
    I need it more hard , OSKAR _ WU has already reached DDR740 Level of 1T CL3 6-6-12
  20. #20
    Sep 2003
    its the timings dude, 3-4-4-8 suck, plain and simple. its still good at ddr710 but run ddr600 with better timings and watch the bandwith go up
  21. #21
    Xtreme Mentor
    Jan 2004
    Quote Originally Posted by Geforce4ti4200
    no its not dude, its his cpu speed
  22. #22
    Nov 2004
    K8 2.4G 1T DDR600 CL2.5 4-4-8
    K8 2.4G 2T DDR600 CL2.5 4-4-8
    2.7G 1T DDR600 CL2.5 4-4-8
    2.7G 1T DDR600 CL2.5 3-3-5
    2.7G DDR676 1T CL3 4-4-8
    1T OR 2T?
  23. #23
    Xtreme Mentor
    Nov 2004
    Elma, NY
    All that Sandra "theoretical bandwidth" is great - run some real world app benchmarks now and you'll see that 7GB vs 8GB memory bandwidth is overkill anyways
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
  24. #24
    Feb 2004
    Houston, TX
    Quote Originally Posted by dnottis
    Um..duh? Isn't that the whole point to this forum. It is called Xtreme...
    Gigabyte DS3 C1 F8i
    Antec P180
  25. #25
    XIP
    Nov 2004
    NYC
    Just do the short cut (with out sweat) I'm J/K With the same Gskill
