built my 1st attempt at wc with tons of help from reading the forums here and from trans am who came over and helped (to be honest, trans did most of the work while i watched and tried not to get in the way). pics on the way when i can borrow a camera.
based on recommendations here and a few other sites, i got:
aquaxtreme 50z pump
dtek pro 120 heatercore & shroud
fusion HL vga block
swiftech 5.25 res
mcmaster 7/16" tubing
swiftech radbox
hose clamps, swiftech coil sleeves, zalman fanmate
the entire setup fit nicely into a lian li pc-v1000 case that has a vapoLS installed. with the wc i was able to go from a stable overclock on a 6800gt of 405/1050 to 430/1100 with a boost in 3dM05 from 50xx to 54xx.
some notes on the setup that might help other 1st time builders
sanyo denki fans (available from some dude on ebay) are the bomb. they're cheap, move tons of air and are pretty quiet.
the 7/16" ID tubing was great, very flexible and passes through a pci slot hole in the back of my case without noticeable kinking. the tubing fits extremely tightly over 1/2" ID barbs and although i did use hose clamps, they seemed superfluous. it took a lot of effort to get the tubing on the barbs.
the radbox setup was perfect for my needs because of the limited interior space in my case. in addition to space saving, the radbox allows the rad to use cool room temperature air as opposed to air from a warm case.
the zalman fanmate2 was a perfect addition to my wc setup and allows me to control the radiator fan without having to open up the case or use software. i installed an additional fanmate to control the rear case fan.
coil sleeves from swiftech were great in getting rid of the 2 minor kinks i had.
velcro and 24-hour hardware stores are proof that god exists, i used it to secure my pump and it's rock solid. the pump itself is VERY quiet, barely audible with a closed case.
on a negative note, the swiftech reservoir is a bit hard to bleed air from the system. currently i have the res mounted at an angle to keep air from entering the circuit. i could use a few pointers in getting rid of air using the swiftech res.
one last minor negative point is that i waited nearly 3 weeks before i received my silverprop fusion HL. the delay in receiving my vga block wasn't through any fault of the retailer, but due to the fact that the block was shipped from australia.
i ordered my HL about 1-2 weeks ago from frozenmods, doubt ill see it before xmas as they send the order to silverprop, kind of cheek as they dont do anything lol apart from tell silverporp where to send it
