Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 157
Thread: Epox 9nda3+ Test(ddr670 Pass!!!)
    Nov 2004
    1.0
    IO
    K8 939 3000 0.09
    EPOX 9NDA3+
    G-Skill TCCD DDR600 256MBX2
    GeForce256
    TEAC512EB
    300W
    Jun 2004
    greece
    What ram are u using? The bandwidth seems a bit low
    Edit i just saw gskill
    Dec 2004
    @ georgesod its Gskill PC4800, yeah the screenshot is a lil tricky to read...I guess the latency does hurt performance even at these high speeds
    Oct 2004
    Melbourne, Australia
    Yeah, this board can definetely hit high HTTs...
    It does need the new BIOS (10 Nov) though, to properly support some double banked dimms...
    Aug 2003
    orange county
    Quote Originally Posted by jlccarv
    do you guys have any trouble running ldt at x3?? if i set it in the bios i can't get it to post.
    heatware
    ebay feedback
    FX-55
    DFI NF4 Ultra-D
    XFX 7800GTX
    Kingston 2x512mb BH-5
    Vapochill LS
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    I have run 325fsb dual channel DDR650 on this same Epox with 2x512dimms which up's the memory controller load much more than 2x256...but it needs 2T just like we are probably seeing here.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Xtreme Guru
    Jul 2004
    Yeah this is definitely 2T cmd. That should be way over 8k in sandra even with the crap timings.
    Xtreme Mentor
    Apr 2004
    CT, USA!!!
    windwithme can you try 1T for us?
    Banned
    Nov 2004
    so that board doesnt suck as bad as i have bin hearing
    the jedi master
    Jun 2002
    Guys with a vdimm mod the boards pretty sweet, I have mailed Epox suggesting they add a few extra tweaking options to the ram setup and then it would be a lot better.
    Just for jollies I decided to run 2t with some 3200rev2 2x512. Its pretty stable here although i have a driver issue with sandra crashing out but super pi and everest are totally fine.
    See what you think. CPU is a 3800+ running 320fsbx8 2T
    Tony AKA BigToe
    Banned
    Nov 2004
    Quote Originally Posted by bigtoe
    cant you just use a DDR booster other thin hard modding it?
    the jedi master
    Jun 2002
    Quote Originally Posted by confuzzedintel
    the booster kills the board here...so don't try it
    Tony AKA BigToe
    Banned
    Nov 2004
    one last usless post can you post a pick of the vdim mod ?
    Nov 2004
    All Test Use 1t
    Neo 2.85v Run Ddr670
    9nda3+ 2.8v Run Ddr670
    the jedi master
    Jun 2002
    Ok just for you Pot is 50K linear set to max resistance to start. Pin6 to ground (in this case a fan header so i can unplug it)
    Contrast is a little high but its nice an clear for you.
    Tony AKA BigToe
    Banned
    Nov 2004
    that mod dont look as hard as i thought what if other thin soldering the black wire on i just make sure it has contact and hot glue it that way if the board dies i can still RMA it?
    the jedi master
    Jun 2002
    I would solder it m8
    Tony AKA BigToe
  18. #18
    the jedi master
    Jun 2002
    so found the absolute max...seems you need to match the ram to the board well and it really does need the vdimm mod.
    Tony AKA BigToe
  19. #19
    Banned
    Nov 2004
    bummer i suck at soldering owell thanks for the info and i will now quit spaming/hijacking someone els thread
  20. #20
    Jan 2004
    somewhere in Massachusetts
    So where does the Epox fall into it all? Better than the MSI or about the same?
  21. #21
    the jedi master
    Jun 2002
    I think its better although it needs an update to the bios for all the alpha tweaks and the vdimm mod.
    Tony AKA BigToe
  22. #22
    Banned
    Nov 2004
    i have always known epox for there extreme voltages its sad to see they didnt bring it along with this board
  23. #23
    Aug 2003
    orange county
    i have to agree this board is better than the neo2. a better bios would make this board shine even more. cant wait till i get my fx-55 under the LS. hurry up mr fedex man
    heatware
    ebay feedback
    FX-55
    DFI NF4 Ultra-D
    XFX 7800GTX
    Vapochill LS
  24. #24
    Oct 2004
    Bregenz/Austria/Europe
    what are the prices like?
    put your finger in the mouth, laughing crumbs keeps your youth... :banana4:
  25. #25
    Oct 2004
    Much cheaper than the Neo2 Plat...
