Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: K8 939 0441spmw Test
    Nov 2004
    K8 939 3000+ 0.09
    AMD FAN
    MSI K8N NEO2.ABIT AV8
    G-Skill TCCD 256MBX2
    GeForce256
    TEAC512EB
    DELTA 300W
    1.376V,run 2.52G
    1.456~1.472V,run2.62G
    2.7G
    Apr 2004
    Vietnam
    Nice OC, Nice winny ! Really run on Stock Fan ??? Which CPU 4 Which Screen shot ?
    Nov 2004
    London, Ontario, Canada
    Wow that thing OCs like a mofo. 100% stable @ 2.7?
    .:: S939 FX-53 (240x11 1:1) | 2x512 Ballistix DDR400 (2.5-3-2-10) | MSI K8N Neo2 Platinum (1.36b) | x800 Pro VIVO -> XT (575/590) | 21" Viewsonic G220fb | Lian Li PC75b ::.
    Aquamark 3 : 84367
    3DMark 2001 : 31717
    3DMark 2003 : 14313
    3DMark 2005 : 6580
    Coming Soon : Silverprop HL Fusion (GPU), S-TDX (CPU), Weapon 2-302 Heatercore / Shroud, 50Z, Aquatube (special thanks to MaxxxRacer & Ancient_1) | UV / Case organization
    Coming when I can afford it : Vapochill LS or Mach 2 GT for CPU | FX-55
    Xtreme Recruit
    Jul 2004
    300 1:1
    Always nice to see these pop-up every now and then!!!
    Very nice windwithme.
    Quick question... These aren't sSOI winchesters are they? If not has anyone seen any sSOI winchecters??? What week are they?
    "Violence as a way of achieving racial justice is both impractical and immoral. It is impractical because it is a descending spiral ending in destruction for all. The old law of an eye for an eye leaves everybody blind. It is immoral because it seeks to humiliate the opponent rather than win his understanding; it seeks to annihilate rather than to convert. Violence is immoral because it thrives on hatred rather than love. It destroys community and makes brotherhood impossible. It leaves society in monologue rather than dialogue. Violence ends by defeating itself. It creates bitterness in the survivors and brutality in the destroyers."
    Martin Luther King Jr.
    Apr 2004
    Vietnam
    According his Pic, 0441 or 0433 ( ? ) both aren't sSOI.... !
    May 2004
    Sheffield, England
    Which board are these on? The Neo2 or Av8?
    Also, how the hell have you got it to do those speeds, let alone with those volts?
    Cheers
    Oli
    AMD 146 Opteron 280x10
    DFI NF4 Ultra-D
    1024mb Crucial Ballistix 255 3-3-3-6
    Oct 2004
    SC, USA
    Windwithme,
    Great OC there man! Where did you purchase those little beast from? 300MHz WOW. DDR600 was that 1:1 timing? What cooling? Stock cooling or what?
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    XSDCMF
    Nov 2002
    Las Vegas Nevada
    Sweet!
    I have a 0441 TPAW I'll be installing in a few days. Hell, I hope to get clocks like that. Mine is a 3500+ Winchester.
    Oct 2003
    Quote Originally Posted by Zanr Zij
    They are winchesters. All winchesters are strained silicon chips. Just that the process isn't matured yet.
    Nov 2004
    Smile
    k8 939 0441spmw 90nm 1.4V can oc at 2.4~2.7G
    AMD cooling
    AV8 TEST
    1.47V
    1.57V
    VIA KT880PRO...
    MU ROOM...
    DDR590 512MBX2 1T CL2.5 3-3-5 MEMTEST PASS!!!
    Nov 2004
    hey, what memory do you have? Does your winchester undervolt in that via board?
    Apr 2003
    Lousyville KY
    Xtremly nice results !
    Where did you order that 3000+ from Im looking to pick up one but cant decide between the 3000 or the 3200 winchester. From this it looks like a 3000+ will save me some cash and be just as good.
    May 2004
    Sheffield, England
    So from all the we gleem that the newer winchesters do actually seem to run better?
    Oli
    DFI NF4 Ultra-D
    I am Xtreme
    Feb 2003
    Netherlands
    Winchesters seem to have a 200MHz advantage over s754 NewCastle's.
    A winny does 31sec SuperPi 1M at 2650MHz easy, a S754 NC needs 2850MHz to do it.
    Also i see you're getting a score of 326 in CPU mark at 9x300, i'm getting 321 with my NC at 9x316,5.
    What's the difference between those two other than dual channel?
Name:	cpu mark 321.JPG
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Recruit
    Oct 2004
    Nice pic of your "spare parts" pile. Don't let that perfectly good hardware just lie around, get that stuff folding or something.... Nice winnie though, I wish my 3000 would do that...
    Dec 2004
    That 5% performance boost i saw stated about winny compared with NC at same mhz is correct then...
    Jun 2003
    Netherlands
    I have a 3000+ 0441 SPMW batchnr 013 here.
    It does 2600MHz stable @ 1.6v
    At 2700MHz the cpu only boots into windows, but is too unstable to finish any benchmark.
    Not too bad, going to put the cpu under my Mach II r507 next week
    | Core 2 Duo E6600 @ 5304MHz | Biostar TForce P965 Dlx | XFX 7800GT | 1GB Crucial Ballistix PC5300 CL3 |
    SPi 1M: 9.953s
  18. #18
    May 2004
    Sheffield, England
    Quote Originally Posted by SynGroW
    By stable do you mean prime95?
    Seems a lot of people are claiming stability when all it can do is run 3dmark a bit
    Starting to wonder if I'm the only one priming nowadays.
    Oli
    DFI NF4 Ultra-D
  19. #19
    Jun 2003
    Netherlands
    Quote Originally Posted by Ol!ver
    Oli
    It probably runs prime for a hour or something like that.
    Prime95 isn't installed on my bench disk
    SPi 1M: 9.953s
  20. #20
    I am Xtreme
    Feb 2003
    Netherlands
    Oli
    Prime stinks.
    SuperPi 32M is good enough for me.
    I always have to back down at least 100Mhz from my highest benchable speed to get Prime going.
    I hate it, it's off my list.
  21. #21
    May 2004
    Sheffield, England
    Quote Originally Posted by Zeus
    But does that mean that your bench speed isn't stable, or prime is wrong?
    Oli
    DFI NF4 Ultra-D
  22. #22
    Nov 2004
    PRIME95 PASS
    0441SPMW
    NEO2 1.36V
    126=>2.46G
    127=>2.52G
    219=>2.35G
    254=>2.4G
    095=>2.7G(Coolaler test)
  23. #23
    May 2004
    Sheffield, England
    Quote Originally Posted by windwithme
    PRIME95 PASS
    0441SPMW
    NEO2 1.36V
    126=>2.46G
    127=>2.52G
    219=>2.35G
    254=>2.4G
    Blend test and for how long?
    Oli
    DFI NF4 Ultra-D
  24. #24
    May 2004
    Europe, Austria, Vienna 1210
    Nice Test.
    Btw, what is the reason u wrtite on every pic your name ?
    dnb-sets 4tw
    Drum n Bass Arena ..
    WPO Powerlifting
  25. #25
    Nov 2004
    to Ol!ver:
    PRIME95 RUN 1~3 hours more
    to Noktar:
    Custom
