Just how sensetive are A64s to high VDIMM settings? I never stopped to think it might be an issue for the memory controller. But I just purchased a AV8/3500+ and 1GB OCZ Platinum PC4200, as well as OCZ DDR Booster. The DDR Booster manual mentions something about A64s possibly getting damaged with VDIMM over 2.65v.
Obviously, they can take more than that, they are overclockable afterall, and Im sure the warning is just a cautionary thing. But, are they really more sensetive than your standard Northbridge? Is VDIMM actually even related to the signal paths? I figured it was just some sort of gate voltage that only affected the SDRAM.
Anyway, Im just curious if anyone has actually damaged their CPUs by cranking VDIMM.
Im also curious if the DDR booster works in the AV8 still. Ive heard reports that it does, but not sure which slots to try it in. Any help there would be great as well. Im hoping this thing cranks up.
