Results 1 to 9 of 9
Thread: [ATI]XPress200 Mainboard ALL View
    Mar 2004
    Taiwan
    MSI MS7093 For Socket939
    MSI MS7050 For Socket754
    Shuttle FT91 For Socket939
    TuL A480A7 For Socket754
    ECS RS480M For Socket939
    Gigabyte G-K8A-480P For Socket939
    ASUS A8AE-LA For Socket939
    more
    Apr 2004
    Auckland, New Zealand
    Great thread
    [EDIT] "MSI MS7050 For Socket754"... look at the socket, it seems like 939 not 754
    VX/UTT Voltage Scaling, please contribute...
    10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
    Mobile 3400+ CG 0437XDPW
    DFI LanParty UT
    XP120 w/ 120mm Thermaltake Thunderblade
    2x512MB OCZ VX
    BBATI 9800np w/Infineon
    PC Power & Cooling 510w Deluxe
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Nice selection, the Gigabyte and shuttle boards are minimal config.
    Look in the top right corner of the gigabyte board, whats going on there? front audio connectors? new case standard? You would think that the image was mirrored but the text is correct. Look at location of rear headers and the PCIe is on the top left...
    Tul with the 20 pin power in the worst spot possible
    Good job MSI with the sinks on the mosfets
    Asus and MSI using the new SATA headers
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2004
    Taiwan
    Quote Originally Posted by FUGGER
    BTX?
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    >>BTX?
    Looks like a board for some customs SFF..
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Jun 2002
    Las Vegas
    No BTX is very close to ATX
    I agree some custom FF
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Oct 2004
    Looks like the Gigabyte and Shuttle boards are OEM designs with only one PCI and one PCI Express slot.
    May 2003
    Dundee, UK
    Whats with all the mATX boards :|
    p.s. that Gigabyte board looks a bit of a mess :S
    | 2.4C | IC7-G | G-Skill GH | 6800LE | S12 600W | Viewsonic 171B-2 | 3DMark '03 '05 |
    | MM U2-UFO | Swifttech Storm | DD Maze4 Chrome | DD12V-D5 | Thermochill HE120.3 |
    Nov 2002
    Yeah... I keep angling my head back and forth. Looking at where the placing of the back panel connections and those slots are. The white strip near the cpu's mosfet... whats that for the DPS mer-bob or something. Well, I'm sure as hell confused. Look at where the ATX power connector is. The missing corners of PCB... ALi southbridge in full effect. I'd chalk it up to being proprietary but damn others are frankensteined too. The asus just loks like the designers got a minor case of dyslexia or something. The back panel is along the short side!!!
    Poster->You the guy that posted other board slide shows too? Thanks for that. Taiwanese I suppose
    Ok.... signing off... I'm getting dizzy
