Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: SuperPi 1MB is now dead ! => what will replace it ?
    Sep 2003
    AB
    Thumbs down SuperPi 1MB is now dead ! => what will replace it ?
    Hi,
    Just some words to say what I think about "the new superpowerfull superpi104" ...
    The new tweak has completely kill superpi. Before it, it was already difficult to make a right comparative between the different realases (japanese superpi ; english release... ), but now there is really no interest to use it...
    I could understand that somebody wants tweak to his own use, but I really don't understand how this "somebody" could use it to run for overclocking results.
    Superpi didn't have any "optimisation" for current cpus so it was a good way to compare each cpu : AMD or Intel ; frequency ; memory ; cache... Each parametre had its own influence.
    I know I'm the only one who find this tweak as poor as s*** and I just want give my thanks to "the superpi killer". I don't want to know who is it, I just hope a way to replace this small bench (with maybe more accuracy in result)
    none
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    I know I personally won't be giving a damn anymore when I see super Pi shots from intel. but Super Pi is still very valid for AMD Xps and A64's, and Intel Northwoods.
    but honestly, I always perferd Hexus Pi-fast myself.
    Mar 2004
    Denmark
    Is it the prescott optimizations???
    The 1 that lets the prescott use all of its powers instead of limiting it???
    A bit lame that a prescott is only faster than the NW-C cuz of the bigger cache... It has ALOT more features that now can be used
    This is like saying that dual channel ram is cheat
    Cuz not every1 has it... Only socket 939 A64 have it ;( *BUHU*
    NOTE: If it is not the prescott optimized thingy then disregard this reply
    P4 3.0C 800@3.64 242FSB 1.625Vcore on Ic7 max3(Watercooled)
    Corsair 2x512@DDR484Mhz PC4000( 3-4-4-8 )2.8V
    X800XT@586/594(Watercooled)
    3*Maxtor 120 GB fluid +9 SATA RAID-0
    3Dmark01: 25250--Aquamark3: 66423--3Dmark03: 13780--3dmark05: 6361
    Mar 2003
    Denmark
    I agree with you zytrahus. Whoever did the patch should take a standing applause. :" Thank you for destroying a great benchmark"
    "M-I-A"
    Mar 2003
    Denmark
    Quote Originally Posted by Mini
    Dude why are you even answering this thread. The reply tends to disagree with your own word. You´re talking about we should stop whining and in the note you´ say its okay. That like I said that you shouldnt answer my reply cause of ignorrence than less its about the reply.
    "M-I-A"
    Sep 2003
    AB
    I don't think Dual Channel and the prescott optimization have a way to be compared
    Saying this optimization is not a bad thing because it works only on prescott, is not looking very far : All future Intel cpus and certainly AMD ones could work with this optimization and so there won't be only one cpu working with the cheat...
    none
    Mar 2003
    Denmark
    I dont even think its the Prescott that have some sort of optimization, I honestly think that its the program thats optimized for a larger cache combined with a longer pipe. But I could be wrong :/
    "M-I-A"
    Feb 2004
    Sweden
    It's a wholly different benchmark.
    Really Mini, do you belive what you post?
    Opteron 165
    Dfi NF4 Expert
    4x1 1GB twinmos PC 3200
    XFX 7900GT 550/1500
    Mar 2004
    Barcelona, Spain
    i agree
    this patch has killed superpi
    Mar 2004
    Denmark
    I think its fine.. Seriously... I dont even have a prescott...
    I have heard that it lets the prescott use some of its instructions and stuff... Thats what i am thinking is ok...
    If this is a cheat identifying the prescott and running another or faster bench by cutting something away then it sux...
    But its like 3dmark... ATI optimizes 3dmark05.. So does Nvidia... If its the same benchmark they run and no quality is lost then its IMO not a cheat...
    Edit: Then again... If Futuremark made a patch that ONLY improved ATI or Nvidia or AMD/intel performance that would suck...
    But 3dmark05 is the same... Nvidia has SM3.0... ATI doesnt...
    Prescott has new instructions... A64 and NW dont?
    Sep 2003
    AB
    Right of 3dmark 2k3 2k5, but CPU influence is not important and these bench are made for GPU now... At the first 3Dmark (2k1 we already found some optimizations.)
    The most important interest of superpi was is "non optimized" way, then :
    - overclocking
    - tweaking mobos
    - killing task in windows to reduce task and memory
    are not cheat, but modding the "code" of the *.EXE is.
    none
    X.I.P.
    Oct 2002
    Australia
    I wonder what the Japanese overclockers think about this prescott cheat?
    X800Pro class 3DMark01 : 36670
    X800Pro class 3DMark03 : 16092
    Ti4200 class 3Dmark01 No 1 : 22213
    Super Pi 1M : S754 28 sec, FX53 25 sec
    HEXUS Pifast : S754/Prom 40.55sec, FX53 36.92sec
    Author of A64 Tweaker
    Co-author of NF2 Tweaker
    Sep 2004
    Belgium
    they are probably not thinking, they are just pouring ln2 on their cpu's
    no seriously, i think superpi is still good for some AXP and a64 benching...
    Apr 2004
    Sweden
    I've always liked superpi. I had a hard time to get it stable and it's (was?) a though test for the computer. Is there no way to keep the modified versions apart from the original? So everybody's going to run PiFast now or what?
    AMD Turion MT34 @ 250*9=2250MHz 24/7
    ATI X800PRO
    MSI K8NM FISR BIOS Rev 1.5 My first BIOS modification
    2x80GB Maxtor drives @ RAID-0
    1x160GB Seagate
    Everything in a mATX case.
    Jun 2002
    Bulgaria
    Sorry for the offtopic, but is there a link that I can use to download that prog?? couldn't find it anywhere on the web...
    Mollov,
    Runnin' a 700MHz SlotA Thunderbird...
    HardwareSight.com Owner
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    That patch really sucks!
    @ mini
    I'm sure u can optimize SuperPi for all newer proz. but we dont want that!!
    U get it?
    @zytrahus
    I thin in ur SuperPi-List are two faked nforce2/XP results. Look @ 35sec,
    there are one with 11,5 x 200 2,5 3 3 6 and one with 12 x 202 2 3 2 6,
    thats wont work! U need 11 x 250 2-2-2-11 to get 35sec SuperPI, and i need
    11,5 x 247 2-2-2-11 to get it!
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
    Sep 2003
    AB
    thanks for message.
    The DB was a temp one... I wanted add screen to valid it, but I was out of time.... And now, I think I'm going to find an other bench (maybe pifast) and rewrite a DB directly on http://www.cooling-masters.com
    none
  18. #18
    Mar 2004
    Denmark
    Aha.. Then thats your problem...
    Use the old superpi??? Or pifast???
    I think optimizations are fine
    Its still all about tweaking... Now the prescott can just show its full power in superpi... Before it was limited...
    But hey if its because you want a simple pi calculator that has no difference wether you run it on a celeron or an a64 then i can understand it...
    I just always thought of superpi as another benchmark
    Whatever goes without cheating goes... IMO...
  19. #19
    Jan 2004
    Manchester (UK)
    Yea Super PI looks likes its dead for sure for prescotts.
    A very bad shame as prescotts like the 3.6E's can overclock insanely and could of broke into the 23 sec range but now, we dont know if its going to be correct.
  20. #20
    Aug 2003
    Germany
    Quote Originally Posted by zytrahus
    thanks for message.
    Anyway, thanks for adding so fast
    @ Mini
    U dont get it, but np its ur opinion!
  21. #21
    Sep 2003
    AB
    Exclamation
    The only point is irelevant in using this cheating patch is that teh difference between a prescott using the patch and a A64 has really no meaning because of the benchmark is not running in the same way with a prescott (with patch) and a A64...
    Continue to use it for his own use, why not, but filling a DB with this is simply cheat, that's all... it doesn't sound difficult to understand
    none
  22. #22
    Sep 2003
    AB
    Quote Originally Posted by Bennah
    Yes !
    like all the next Intel processors able to work with the "cheat patch" ...
    none
  23. #23
    Mar 2003
    Denmark
    You really think thats the case? Come on dude - No one in here besides you believes that.. Changeing the code in a simple PI calculator has nothing to do with prescott optimizions. Thats like 3dmurk if you catch my drift.
    And do you honestly think that the prescott should gain the around 2sec with the cheat. Do you think its 2 sec faster than before and therefore rated correctly?
    "M-I-A"
  24. #24
    Mar 2003
    Denmark
    Quote Originally Posted by TodB
    Lardsarse has it posted somewhere in the forums.
    "M-I-A"
  25. #25
    Xtremely Large Member
    Jul 2003
    Britland
    Well then, surely if it's fair to use a Prescott only "optimisation" to enhance performance, there should be some alternative tweak for the Athlon64 platform too, and one for the Northwood, cause I'll guarantee both those CPU's could be optimised to run SuperPi faster too, considering the programs age?
    It's not about the Prescott gaining performance with the patch, the problem is that no other CPU is gaining performance too, which to me, makes it an unfair benchmark now, especially as there's no way to visibly tell the difference between a patched and unpatched score, unless you know exactly what to look for.
    And that, is why the poster is saying SuperPi is dead, and why i agree.
    I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
    DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
    Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
    OCZ PowerStream 520w | Mach II GT Cooled
