msi k8n neo2
90nm 3200+
GSKILL TCCD
air cooler:HYPER 6
It's 0433SPMW 90nm 3200+.
msi k8n neo2
90nm 3200+
GSKILL TCCD
air cooler:HYPER 6
why no sandra benchies ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
nice. almost 3ghz suicide shot on air with 50% overclock. 90um is getting better fast!
WTF ?!
3Ghz on Air.
These new S939 CPU's are hot !
I'm so happy thta I have Birtday in 12days and then X-Mas
WOOHOO
dnb-sets 4tw
Drum n Bass Arena ..
WPO Powerlifting
nice cpu... my doesn't want more than 2,6 @ 1,55v on water..
with high volt even 2,7
Damn I had one of those and gave it away without prior testing
Sandy Bridge incoming.
don't be sad
i've the same stepping and i can't get over 2550MHz doesn't matter with what voltage
but mine can do 2500MHz @ 1,55V primestable.....
so, i think i'll RMA my CPU and hope that i get a "good" 0433SPMW
----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
Thats some nice numbers! Will buy a 3000+ I think.
Intel FTW!
Beanna
What's it run Prime95 stable @ and for how long?
Current system:
Case: Modded Watercooled Jpac
CPU: Intel Q6600 @ 3.5GHz [1.47v] - OCCT stable
Mobo: DFI LanParty Jr T2RS @ 432fsb [1.37v]
RAM: Crucial Ballistix Tracer 4*1GB DDR2 @ DDR1095 (5-4-5-15) [2.2v]
HD: WD 300GB Velociraptor / WD 640GB Caviar
GPU: HD 4850 Crossfire @ (700 | 2200)
PSU: OCZ ModXstream 780w
Peter, was this a retail boxed 3200+ or an OEM?
It's a retail boxOriginally Posted by trans am
That's what I thought. retail boxes will be newer yields, and should oc higher. oem comes out first and don't oc as well. then the retail boxes come out and they rule! Does this sound legit or am I just blowing fvcking smoke?
Here is my 3200+ 90nm result: http://medlem.spray.se/athlons/32.JPG
Its allso on air
Is that also a retail?Originally Posted by Nextro
YepOriginally Posted by trans am
Originally Posted by TEDY
Is that really important? I never seen yours before!
I already planned on buying one... but now I have no doubts left :thumbsup:
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
Just ordered one of those too , with the Asus A8V. I think 3Ghz will be easy with my Mach II :banana4:
DFI Lanparty UT NF4 Ultra-D
AMD 64 3000+ Venice @2.8Ghz
1024Mb G.Skill PC3200 UTT/BH-5 @255
Asus N7800GTX 495/1350
http://members.home.nl/paul.nijpels/Venice@2.8GhzV2.JPG
Thermalright XP-120
This is getting outta hand . I like it
Somebody should PM geforceti4200
"M-I-A"
Looks like my wait for 3GHz is drawing to a close one question: how the heck did you get 300MHz 1:1 on your ram? I know of no such ram thatll do 300fsb, especially in dual channel. If this was bh5, it would be 2-2-2-5 at like 4 volts! could it be some sort of pc4200 ram? then it would be 3-4-4-8 timings! God id love to own 300x9 winchester 1:1 this would get me some VERY good 3dmarks and gaming performance! 300x10 is even better!!!!!!!!!!
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
hey im looking to that screenshots and i see that you cant change multipliers O_o! so you can change the multi between x and 10?
2008 Rig:
Intel Core 2 Extreme QX9650 - 4 GB OCZ Reaper HPC DDR3 1333 - EVGA 9800 GX2 KO 1GB - EVGA 132-CK-NF79-A1 790i Ultra SLI - Cooler Master Cosmos 1000 - Cooler Master Real Power Pro 1250W - WD Caviar SE16 WD6400AAKS - Tuniq Tower 120 - Dell SP2208WFP
2006 Rig:
AMD Athlon 64 3800+ X2 @ 2600 mhz - Asus A8N-SLI Platinum - OCZ 2*1GB Gold GX XTC PC4000 - OCZ Powerstream 520w - Gigabyte 7900GT 256 mb - Western Digital 250 GB Sata-2 16mb - Western Digital 200 GB Sata 8mb - Sound Blaster X-Fi Platinum - Zalman 7000-cu Led - Thermaltake Tsunami Dream - Vantec Nexus NXP-301
geforceti4200:
He´s using Gskill TCCD You might want to consider these along with your next cpu cause you dont need soldering to get in the "higher than normal" speed area.
"M-I-A"
It's not all that great, my 0.13µ Clawhammer does also 2750Mhz on air.
http://kaine.studentenweb.org/superpi1M275.jpg
Not much of a performance gain (if there is) for winchester cores.
