ok guys initial benches , I as usual only had a few moments to get them so forgive the poor quality
these are with 3.1 volts Just FYI
The 875 bench is a P4800 and the NF3 is the DFI.
300Mhz is 1t in case your wondering
OCZ employee and proud of it.
If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
I am overclocked!
"Posted on Mar 30, 2005 at 1:35 AM by StormGod
In soviet Russia memory overvolts you! "
hynix i think, iono tho
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
650 2.5-4-4-10 2T Single channel in the same DFI 250 motherboard.
Very impressive frequencies, although I was hoping to see more bandwidth. Regardless, this RAM looks very promising considering these were your initial benches.
is this the TCCD that did even better than the PC3700EL Platinum?
when will they be on sale?
Looks great anyway, well done OCZ
VX/UTT Voltage Scaling, please contribute...
10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
Mobile 3400+ CG 0437XDPW
DFI LanParty UT
XP120 w/ 120mm Thermaltake Thunderblade
2x512MB OCZ VX
BBATI 9800np w/Infineon
PC Power & Cooling 510w Deluxe
Wow! 275MHz at 2-3-3 on i875P
When will this be available?
Less is more.
Try to remeber the DFI is a single channel motherboard ;-) when looking at the scores. The highest Dual Channel bench we tried was CL 2 @ 550
Later down the line we will install the booster and play more
I am overclocked!
Is this that "voltmaster" memory you posted about ?
Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
Evga GTX285, Raptor 150GB, Corsair HX620
Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
Win Vista Premium X64
Nano , Nope the "voltmaster" is a product thats in early development We will keep you informed though , if we are able to make that product in large enough quantity to keep the price reasonable.
I am overclocked!
wow.... amazing new memory ocs day by day... who said DDR was dead?
That sorta makes me a little upset my 1 week old EL3200 rev2 now look like they are dated .Originally Posted by saaya
So how soon is the voltmaster ram going to come out? I heard PR will be out this week. Does that mean it has been shipped? Or does this mean it's going to be a while. That Mushkin turned out to be crap. SO I need to find a replacement from newegg fast. I want the ocz ram that does 260mhz+ @2-2-2 Tony and you mentioned.Originally Posted by ryanpgroovy
I understand that you were probably going for maximum speed with the above benchmark. Out of curiosity, would you happen to have a screenshot of maximum performance on the DFI NF3 board?Originally Posted by OCZEric
Can you test it with dual channel?
What is the highest 2-2-2 achievable with Dual channel?
4xOpteron 850 + 16 dimms (32GB)
Hail TYAN
*Pats his burning hot BH-5* -"It's ok, i will never replace you"
*Goes to second computer to place order*
Ryan and guys, is the "voltmaster" ever going to be better than BH-5, your initial benches make it seem very voltage hungry.
Warranty at what volts by the way? I've got 4 itching volts and ram watercooling to give them hell with, don't dissapoint me.
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
Tccd ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
Take from the OCZ forums:Link It is using the new Hynix Chips
Edit: Nevermind - Those are 4400EL Chips.
great, some competition for micron and samsung will keep things interesting... probably means they are not voltage lovers tho...
DFI LanParty UT
2x512MB OCZ VX
Guys the DFI bench will probably be low as lots of the tweaks were not applied...im sure if i got my hands on these modules we would be seeing 4700+ easy
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
is this a better choice than the 3700 platinum?
Originally Posted by Sauro
This is 4200 platinum we are talking about. That post at BE was 4400EL copper ram.....big difference
I work for OCZ. If your having a problem with any of our products feel free to PM or email me
Wow man this is getting tricky, just when the choice between 3200 and 3700 seemed hard enough to decide between now comes the 4200. The 3200 defaults at 2.75, 3700 at 2.8, and now the 4200 is back down to 2.75 volts. So which is the best overall? If they are all using the new TCCD then they are all pretty much the same except for the speed bin?
damn, does this ram like volts at all? how will it compare to tccd both at max speed?
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
Originally Posted by Crankster
Yeah the memory market train is certainly reaching higher speeds.. What happend to EB´s
"M-I-A"
