XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 11-01-2004, 01:06 AM   #1
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
Smile DFI 875P-T @ 6.2Ghz WR
6Ghz has been broken on phase change
Intel P4 3.6Ghz SL7Q2 -113c
DFI 875P-T @ 333FSB
Centon Advanced DDR TCCD
OCZ DDR Booster
Chilly1 three stage CPU cascade
Going for more, had to stop and celebrate
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 11-01-2004, 01:08 AM   #2
L0$t Pr0PhEt
Xtreme Cruncher
L0$t Pr0PhEt's Avatar
Send a message via MSN to L0$t Pr0PhEt
VERY NICE!
congratz, these chips go really high
__________________
Core i7-920 @ 3,8GHz 24/7 1,30v watercooled
Gigabyte X58 UD5
3x1GB G.Skill DDR3-1333
MSI 7900GTO
Corsair HX520W
L0$t Pr0PhEt is offline   Reply With Quote
Old 11-01-2004, 01:13 AM   #3
Jupiler
Administrator
Jupiler's Avatar
Awesome.
With only 1.584V ???
Can you bench at that speed?
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman View Post
I've got Supermicro boards that lasted longer than one of my marriages!
Jupiler is offline   Reply With Quote
Old 11-01-2004, 01:14 AM   #4
Naughtyboy
Send a message via ICQ to Naughtyboy
Jezzzez.....thats alsmost silly....6hgz with phasechange..!!!!!!!!!!
Loads of congrats from Sweden
Naughtyboy is offline   Reply With Quote
Old 11-01-2004, 01:31 AM   #5
RootX
RootX's Avatar
Great work Fugger,
guys, actually is phase_change x phase_change x phase_change, :P
__________________
RootX is offline   Reply With Quote
Old 11-01-2004, 01:38 AM   #6
Pejsen
Pejsen's Avatar
Keep em' coming
__________________
30913 @ 3Dmark2001 with X800GT
Pejsen is offline   Reply With Quote
Old 11-01-2004, 01:39 AM   #7
2fink
Xtreme Cruncher
2fink's Avatar
Send a message via ICQ to 2fink
congrats from germany! great work!
__________________
E2160 @ 360x9, max 390x9 watercooled
GA-P35-DS3
Cellshock D9GMH @ 545mhz cl5-5-5-5-15
Palit 7300gt 500/1000 @ 780/1600 watercooled
2fink is offline   Reply With Quote
Old 11-01-2004, 01:39 AM   #8
FUGGER
Xtreme Owner
FUGGER's Avatar
6.1Ghz...
339FSB
__________________
Intel SSD RAID 0
Old 11-01-2004, 01:43 AM   #9
Jansson
Send a message via ICQ to Jansson
looking good
how high is the wr?
Jansson is offline   Reply With Quote
Old 11-01-2004, 01:47 AM   #10
FUGGER
Xtreme Owner
FUGGER's Avatar
Um, kicked up the voltage more 1.875v in bios for this bad boy.
6.212Ghz
__________________
Intel SSD RAID 0
Old 11-01-2004, 01:49 AM   #11
Karnivore
Dats Really Cold
Karnivore's Avatar
Send a message via AIM to Karnivore
6.212Ghz
Congrats FUGGER, I believe that tops the Japanese record, and put you in #1 WR.
Karnivore is offline   Reply With Quote
Old 11-01-2004, 01:52 AM   #12
Detract
Detract's Avatar
436 FSB that's insane, congratulations dude.
Out of interest how have you found mounting your evap to the DFI? Im concerned with the number of caps and mosfets around the socket area.
Cheeers
__________________
MAIN RIG :: CPU: Opteron 146 @ 2.85ghz :: Motherboard: DFI SLI-DR :: Memory: OCZ 1GB Platinum Edition Dual Channel :: Video Card: ATI X1800XL :: Hard-Drive: 2x 250GB WD SATA II RAID-0 :: PSU: OCZ 520W Powerstream :: Case: Coolermaster Praetorian :: Monitor: Sony G420 :: Operating System: Win XP Pro Edition
Detract is offline   Reply With Quote
Old 11-01-2004, 01:53 AM   #13
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
thats definatly the record
those DFI 875-T's are nice.
I got to play with one all weekend
__________________
Kunaak is offline   Reply With Quote
Old 11-01-2004, 01:54 AM   #14
Tek
That's nuts for an Intel CPU, but I guess triple cascade is nuts as well
From an OC standpoint, who said Intel was dead or had trouble?
Is it just me or does phase change have a curse about them? I only have single phase change setup(LS), but I already want a dual cascade setup and I would probably want a triple one if I got 3.2ghz stable. Like I read somewhere, 3ghz AMD64 is so old news
Anyways, awesome Fugger, as always. Nice to see you in the field again
EDIT: Anyone ever hit 2ghz QFSB on an Intel rig? 1.8ghz is like, too close not to think about 2ghz soon
Tek is offline   Reply With Quote
Old 11-01-2004, 01:55 AM   #15
FUGGER
Xtreme Owner
FUGGER's Avatar
Hang on, still not done yet. ripped out the AGP video card and dropped in wimpy PCI one.
6Ghz is about benchable now, Ill do some super pi's when I am done pushing for Ghz
1.9v and I still have more to go...
6.302Ghz @ 350FSB 3:2 @ -121c
__________________
Intel SSD RAID 0
Old 11-01-2004, 01:59 AM   #16
NiCKE^
NiCKE^'s Avatar
Send a message via ICQ to NiCKE^ Send a message via MSN to NiCKE^
Congrats! Insane clocks there man.
__________________
Intel FTW!
Beanna
NiCKE^ is offline   Reply With Quote
Old 11-01-2004, 01:59 AM   #17
derbis
Send a message via ICQ to derbis
awesome fugger
It will take a long time, until other User have 6GHz or more and you got it now...really nice
__________________
AMD Athlon X2 BE-2350 @ 2,88GHz @ 1,25V // ASRock AliveNF7G FSB275 // 2x1GB DDR2 667 @ 722MHz
derbis is offline   Reply With Quote
Old 11-01-2004, 02:07 AM   #18
Xassius
Xassius's Avatar
Insane101
Would LN2 yield higher oc's? probably not a lot...
Xassius is offline   Reply With Quote
Old 11-01-2004, 02:14 AM   #19
cold_ice
cold_ice's Avatar
Send a message via ICQ to cold_ice
Wow thats insane
Looks like the new 3 stage cascade is working very well
cold_ice is offline   Reply With Quote
Old 11-01-2004, 02:15 AM   #20
crotale
Xtreme Legend
crotale's Avatar
Send a message via MSN to crotale
I think Fugger said it was an 18 multi chip, but some kind of error reading it.
Congrats Fugger!
Show us some SuperPi now! Not the patched one please
__________________
"In mild doses, ethylene produces states of euphoria, associated with stimulus
to the pleasure centres of the human brain."
Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
crotale is offline   Reply With Quote
Old 11-01-2004, 02:16 AM   #21
kaze
kaze's Avatar
omfg insane speed! Good work fugger and chilly1! 6ghz
__________________
Opteron 165 270x9
DFI LanParty UT Nf3 Ultra-D
2x TwinMos Winbond BH-5 @ 442Mhz 1.5-2-2-0
X850XT
kaze is offline   Reply With Quote
Old 11-01-2004, 02:20 AM   #22
TEDY
Xtreme Mentor
TEDY's Avatar
Send a message via ICQ to TEDY Send a message via MSN to TEDY
SANDRA benchies please...this has to be 10MB/s :P
__________________
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
TEDY is offline   Reply With Quote
Old 11-01-2004, 02:34 AM   #23
eva2000
Memory Addict
eva2000's Avatar
woah.. i feel 6.6ghz coming
congrats there
eva2000 is offline   Reply With Quote
Old 11-01-2004, 02:38 AM   #24
STEvil
tl;dr
STEvil's Avatar
Send a message via ICQ to STEvil Send a message via MSN to STEvil
Any plans to drop that cascade on an unsuspecting 3ghz on air winchester? lol
Those japanese are gonna have a hard time catching you I think fugger.. should be interesting watching them scramble maddly to try and build something to compete with that lol
__________________
Heatware || 01.01.08; AND 110.9%
Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 14 of 16 (Thats nearly $10,000 in dead motherboards).
All along the watchtower the watchmen watch the eternal return.
Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
LIST OF GAMES WITH ACTIVATION LIMITS/SONY SECUREROM 7: http://knowyourgame.reclaimyourgame....with+SecuROM+7
STEvil is offline   Reply With Quote
Old 11-01-2004, 03:01 AM   #25
Sheik
Sheik's Avatar
This is going too slow ... rather start at 7 GHz and work your way back
75 % overclock so far.
Congrats.
Sheik is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
