And got it working okay?
I know you big guns are so into FXs... but some of us underdogs with phasecooling want to try these 90nm which are more affordable to play with So far, I've had no luck of 2 K8N Neo2 booting up with prommy running when evap temp is below -20 or -30c... I believe Same is true with A8V from some other member questioning recently.
Is there any big dogs that have tried these measly 939 3200+, 3000+ or 90nm 3500+ with phasecooling yet?
Would appreciate any tips, helps, etc.
PS) For MSI I tried 4 diff versions of bios... till I gave up. (that was on 2 boards :P)
PPS) If I just attach the exact same setup with air cooling... it will boot up just fine.
