Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Sneak Peak at the OCZ memtest86
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Thought you all would like to play with this one.The difference is a few "extra" options
    Load memtest and you see this.
    We are upto ver1 now BTW
    Next up Press C and you will see this.
    Notice option 9 press it and you get this.
    Now there is a disclaimer that pops up to so you know to be careful
    This soon disapears and you left with this.
    If your using A64 you can even play with a few "Alpha Tweaks" if you wish...just press 5
    Setting command rate is just an expmple.
    Now once you set a timing paramiter the test restarts but you will notice it does not exit...so, you can now set and play with timings all within memtest without having to reboot.Only real missing option is fsb change but we may get that working soon
    It work with A64, i875, i865, 915 and 925 and i have an idea nf2 also (although i am unsure)
    you can grab the files here:
    memtest cd iso
    Floppy image
    Full release is next week, source code etc posted on the OCZ site, treat this as a leak to see what you all think of it.
    Thanks to Wee and Eric for this release with a little help from me also .
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Apr 2004
    good stuff, no more waiting for that 10 extra seconds going through the BIOS.
    A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
    Dec 2003
    Louisiana
    That's pretty cool. Going to have to dig up a floppy.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Xtreme Infrastructure Eng
    Feb 2004
    Oh WOW! The ability to modify timings within the program is totally sweet! Does the "modify all" option allow you to change CAS latency?
    OCZ
    Less is more.
    the jedi master
    Jun 2002
    Quote Originally Posted by Gogeta
    OCZ
    A64 cas latency is an issue...all other timings are there an say 4/5 of the alpha tweaks.
    Tony AKA BigToe
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    excellent work guys
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    Nice work Bigtoe and whomever else is involved in this!
    This sure will speedup shaking out new rams a bunch. Thanks a bunch and good luck on future revisons.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
    Xtreme Gentoo User
    Mar 2004
    England
    Nice Looks like I will have to reformat my old MemTest floppy to make way for this version
    the jedi master
    Jun 2002
    One of the bonus's of you using this is that not all board have the extra tweaks for A64, so you can set and play with them in memtest then apply them with the A64 tweaker in windows.
    Tony AKA BigToe
    I am Xtreme
    Dec 2003
    Question Can we get a dos executable?
    Like teh latest versions of memtest so that we can just boot up a usb/dos thumbdrive and run it from there like I do now? PPPPPLLLLLLLEEEEEEAAAASSSSEEEEE!!!
    Sep 2004
    Quote Originally Posted by bigtoe
    It'll be cool if OCZ's ram came with software unlocked EEPROMS (of the first 256bits I think that JEDEC specifys to software lock)...then write a program so users can tweak SPD settings of their own :banana4:
    the jedi master
    Jun 2002
    Quote Originally Posted by Xassius
    Why would we want to do that?
    Tony AKA BigToe
    Oct 2002
    Yep Tony - it's pretty sweet to play with, great to change timings on the fly.
    You guys will love it.
    Sep 2004
    aren't EB enhancements made in SPD?
    the jedi master
    Jun 2002
    They are yes...which is why its best to keep em locked away
    Tony AKA BigToe
    Sep 2004
    ahh....
    so unlocking the SPD would be great for tweakers..but not for OCZ...
    the jedi master
    Jun 2002
    ahh....
    Boards bios allows for most tweaks...i would say its better to ask bios writers to add the timings you see in the DFI bios for example into their files...somethings are better locked away, but some i do agree are fun to tweak...this is why we did memtest86 with the timing options.
    Tony AKA BigToe
  18. #18
    Sep 2004
    My AA8 only allows for the standard timing adjustments and PAT....
  19. #19
    c[_]
    Nov 2002
    Alberta, Canada
    I finally got the darn cd to burn correctly too..
    All along the watchtower the watchmen watch the eternal return.
  20. #20
    Sep 2004
    Samurai Jack and Jess should apply this to the DFI NF3 250Gb board BIOS!
  21. #21
    Xtreme Mentor
    Nov 2003
    Nice mods on a great tool Bigtoe!
  22. #22
    Sep 2004
    Nice..'nuff said.
  23. #23
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    I just burnt memtest 1.27 yesterday... thanks a lot
    I'll give this a try tommorow though, anyone tested out how well it works on i875? (as far as changing timings)
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
  24. #24
    Sep 2004
    I wonder if it will work for DDR2 i925x...
  25. #25
    May 2004
    Perth, Western Australia
    Quote Originally Posted by Catalan
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
