Page 1 of 4 1234 LastLast
Results 1 to 25 of 98
Thread: voltmaster
    Nov 2002
    california or chicago
    voltmaster
    I am curious if there is still a market for memory that loves high voltages ( similar to winbond BH and OCZ EB ).
    Weve been working on the special formula for high voltage lovin product here and I have a few beta samples - check out the benches these are at 3.3 ( 466 CL 2 ) and 4.0 volts ( 540 3-2-2 ) respectively using the DDR booster.
    These are on a beat up Asus P4C800. I just did them at the end of the day when the betas arrived ;-)
    heading home now guys , let me know what you think....
ID:	18164   Click image for larger version.
    OCZ employee and proud of it.
    If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
    I am overclocked!
    "Posted on Mar 30, 2005 at 1:35 AM by StormGod
    In soviet Russia memory overvolts you! "
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    So you are planning on selling off the BH5 chips that fail at stock voltage and say that they require 3.3V? As long as it gets more BH5 chips into the market I guess its not too terrible, just don't charge the same price as you would for normal ram that passes clock tests with nominal volts.
    For those of you about to post:
    Nov 2002
    No , These are not BH-5 ( BH are no longer in production) , they are new OCZ chips that behave like BH-5, or like the Microns we use to use for EB.
    I am overclocked!
    Xtreme Mentor
    Jun 2002
    Sounds like fun Ryan. But you would be hard pressed to get my 3700ELPlats out of my box.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Xtreme Mentor
    Jun 2002
    Only thing I would be concerned about on AMD64 boards is the overvoltage protection on many 939 boards and the memory controller on the cpu die. It's been difficult to run anything over 3v on most A64 boards so far. I guess Intels don't have as much of a problem with that.
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    ryan,
    Am i missing something? Most EB will do 250mhz but not at those timings. Is more voltage required for lower timings? I've always ran mine at the spec'd timings.
    Donate to XtremeSystems!
    Workstation: Intel Core i7 4770, Asus Maximus VI Gene, 32GB Corsair Dominator Platinum DDR3-1866, eVGA SC GTX Titan, 256GB Crucial M4, Corsair HX850, Corsair H100i. Corsair Carbide 350D
    Fileserver: 2x AMD Opteron 2425HE, Supermicro H8DME-2, 24GB DDR2-667, Supermicro 846TQ 24bay Chassis, Redundant 920w, 256 Crucial M4 boot, 20TB Storage
    Notebook Asus Zenbook UX32VD-DH71, Intel Core i7 3517u, 10GB DDR3-1600, 256GB Crucial M4, Geforce GT 620M
    Xtreme Mentor
    Jun 2002
    The EB's (micron) and EL's (tccd) etc. won't normall'y respond well to voltage over 3v.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    how do they perform with 2.85v? do they still run at acceptable speeds but with lower timings and just need the volts to run with lower latency? can they take 4v for a long time?
    Jun 2004
    The Baltics
    Well since we had benches here, BH-5 2-2-2 270 fsb to equal TCCD 2.5-3-3-7 300fsb, if OCZ could came out with something like 300fsb 2.5-2-2 (if that's possible at all with presently available DDR memory), the product would have a bright future... (for serious benchers only, though, because the not-so-xteme guys probably still would opt for TCCD memory.
    away & gone
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Quote Originally Posted by mrlobber
    Everyone want 300fsb 2-2-2 1:1....I don't think we will see that soon with ddr1 but I would love to be proven wrong.
    These modules need juice...they are spec'd to run juiced up so you probably won't like the timings they run with sub3V.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Dec 2003
    texas
    hell i feed em 12 volts if needed bring em on.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hmmmm 270mhz 3-2-2... hmmm are they as fast as bh5 at 270 2-2-2? or eb at 270 2.5-2-2?
    it sounds like they can compete with tccd at 300mhz, but thats right now... in some weeks tccd might run DDR700... who knows? didnt samsung switch to 90nm recently?
    i think this memory could compete with tccd, but its not that much faster than tccd at 300 i guess, so it wont be that successfull. especially since it needs a lot of volts wich kinda requires a ddr booster.
    i dont think it would be very successfull... just get a license from winbond to manufacture bh chips and then send the blueprints to samsung and let them build bh chips in 90nm
    Xtreme Recruit
    Sep 2004
    Helsinki Finland
    Quote Originally Posted by saaya
    no no no
    bh-5 and Sandra shot
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    seems like alot of voltage for a low fsb. would rather pay from bh-5 or tccd. really i dont want to have to push 4.0v thru a a64 mem controller just to get some decent speed. any way to see some good binned TCCD with some EB pcb?
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Nov 2002
    I think these are probably more suited to people who want 2-2-2 in the 420-466 range , than to super high fsb, as they should run in that range with midly high voltages ( 3.1-3.2 ) .
    Dont mind those benches much I was just trying to show that they were benchable and have no tweaks on spent about 15 minutes playing with them only.
    right now the Best of our TCCD are going in to plat 3700 ;-)
    also about EB , EB do respond well to voltage up to about 3.2
    I am overclocked!
    Dec 2003
    Louisiana
    This RAM sounds pretty bizarre, but I wouldn't mind feeding 3.3+ to them.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by ryanpgroovy
    well it's a start... OCZ improvements and tweaks and see 285mhz 3-2-2-6 at 3.3v would be nice heheh ....
    i'm having loads of fun these days with enough vcore/vdimm via DFI NF3 250Gb and OCZ DDR Boosters on my DFI, P4C800-E etc hehe
  18. #18
    Nov 2002
    They certainly are bizarre. Just wondering what we should do with them
    I am overclocked!
  19. #19
    Overclocking Guru
    May 2002
    SoCal, USA
    I have been running my BH-5 at 3.75V alot lately, 6 hours of abuse yesterday.
    So yes, if the Ram does good timings and high MHz there's a market for them.
    Doesn't matter what the voltage
    OPP
  20. #20
    Jun 2004
    The Baltics
    Quote Originally Posted by megahurtz-oc
    A direct 12v mod from the PSU?
    away & gone
  21. #21
    Dec 2003
    Louisiana
    Put em in the mail to me. I can put them to good use.
  22. #22
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    the way I see it is, if theres a way to make fast ram at low voltages, then thats better.
    using high voltages was just a side effect of wanting high speed ram, with good cas latency. it wasn't something people seek out, cause they like it.
    thy do it, cause to get things like DDR 550, cas 2-2-2 ram you just needed tons of voltage.
    but when possible, I'd rather have fast ram, at lower voltages.
  23. #23
    Dec 2003
    texas
    will the 3700 plats run timings like the gskill at 280ish?
  24. #24
    Feb 2003
    Miles from Civilization...
    Hi Ryan...
    Long time no speak my man.
    Sell me a couple of these Beta's and I'll beat 'em up for you and see
    what they will do.
    Got a Booster to torch 'em with.
    DFI 250 UT will only let me have the Booster and 1 stick at a time.
    I didn't jump to A64 soon enough and missed the boat on the EB supply.
    Your TCCD is moving to 3700 Plat.... sounds good. I'll be looking.
    Need a new challenge.
    Cheers.
    .... I spent a Fortune on Booze and Women.... the rest I just wasted.
    My Heatware
  25. #25
    Worst overclocker evar!!
    Oct 2003
    Harrisburg, PA
    do these chips ever stop liking voltage or just get too hot too continue? you go up to 4v, but let's say we have a board with a straight feed from the 5v rail... would they continue to scale well from 4.0v to 4.5v+?
    I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
