Hello
Many thanks to tictac for sharing the tools in the thread, otherwise the mods would not have been possible
I have modded ABIT IC7 BIOS 26 and unlocked most of the hidden options (check log below)
DISCLAIMER : You will assume 100% responsibility for using these BIOSes. Neither myself or anyone else in these forums are to be blamed if anything goes wrong with your setup after using these modded BIOS. I don't use SATA/RAID so I couldn't test. The hidden options were unlocked from the stock IC7 BIOS 26 from Abit website, no other modules were added or modified.
There are 2 versions of the BIOS 26 that I have modded. I have flashed and use both, it is working. I would suggest that you get familliar with the flashing procedure and prepare corrective actions before you flash. Also try to copy down every BIOS setting in your current setup, you will need to restore the same settings after the flash. Maybe you want to get a BIOS Saviour or another working BIOS chip just to be safe. You shouldn't flash in overclocked-mode. Restore to stock speeds for CPU/RAM/etc before flashing.
To download these BIOS, right-click and select SAVE
IC7_26B.rar - This version includes ALL options described in the Change Log. The only problem is you will need to re-install Windows, most likely due to ACPI Power Management available in this version. Your existing Windows installation will NOT load if you choose to use IC7_26B.rar
IC7_26M.rar - This version includes ALL options described in the Change Log EXCEPT the Power Management options. After flashing, re-apply your previous BIOS options and you should be able to load Windows.
CHANGE LOG (OCT 16 2004)
* Latest Unhidden/Addition
BIOS MESSAGE*
*** ABIT IC7 v1.1 BIOS v26 mod by pokipoki 26/10/2004 ***
BIOS OPTION*
PCI Configuration Display [Enabled]
SOFTMENU SETUP
-Spread Spectrum*
[Disabled] [+/- 0.35 %] [+/- 0.50 %] [+/- 0.75 %] [+/- 1.00 %]
default value [Disabled]
ADVANCED BIOS FEATURES
-CPU L1/L2 Cache*
[Enabled] [Disabled]
default value [Enabled]
-CPU Feature*
Thermal Management --> [Thermal Monitor 1] [Thermal Monitor 2] default value [Thermal Monitor 1]
TM2 Bus Ratio --> default value [0]
TM2 Bus VID --> default value [No value]
Limit CPUID MaxVal --> [Enabled] [Disabled] default value [Disabled]
-Typematic Rate Setting*
-Typematic Rate (Chars/Sec)*
[6] [8] [10] [12] [15] [20] [24] [30]
default value [30]
-Typematic Delay (Msec)*
[250] [500] [750] [1000] default value [250]
ADVANCED CHIPSET FEATURES
CAS Latency Time*
[2] [2.5] [3] [Auto*]
default value [2]
Act to Precharge Delay*
[8] [7] [6] [5] [Auto*]
default value [8]
DRAM RAS# to CAS# Delay*
[4] [3] [2] [0*] [Auto*]
default value [4]
NOTE : Please let me know if value [0] should be disabled in order for [Auto] to work properly?
DRAM RAS# Precharge*
default value [4]
INTEGRATED PERIPHERALS
OnChip IDE Device --> IDE HDD Block Mode* [Enabled] [Disabled] default value [Disabled]
OnChip PCI Device --> AC97 Modem* [Auto] [Disabled] default value [Disabled]
POWER MANAGEMENT
ACPI Function*
Run VGABIOS if S3 Resume*
[Auto] [Yes] [No]
default value [Auto]
Power Management*
[User Define] [Disable*] [Min Saving] [Max Saving]
default value [User Define]
Video Off Method*
[Blank Screen] [V/H SYNC+Blank] [DPMS]
default value [Blank Screen]
Video Off in Suspend*
[Yes] [No]
default value [No]
Suspend Type*
[Stop Grant] [PwrOn Suspend]
default value [Stop Grant]
Modem Use IRQ*
[NA] [3] [4] [5] [7] [9] [10] [11]
default value [3]
Suspend Mode*
[Disabled] [1 Min] [2 Min] [4 Min] [8 Min] [12 Min] [20 Min] [30 Min] [40 Min] [1 Hour]
HDD Power Down*
[Disabled] [1 Min] [2 Min] [3 Min] [4 Min] [5 Min] [6 Min] [7 Min] ...... [15 Min]
CPU THRM-Throttling
[Disabled] [87.5%*] [75.0%] [62.5%] [50.0%] [37.5%*] [25.0%] [12.5%*]
default value [62.5%]
PNP/PCI CONFIGURATION
Force Update ESCD*
[Disabled] [Enabled]
NOTE : If you enable this feature, you must disable it manually at your next reboot
PC HEALTH STATUS
CPU FanEQ Speed
[Disabled] [90% Speed] [80% Speed] [70% Speed] [60% Speed] [50% Speed*] [40% Speed] [30% Speed*]
Best Regards,
pokipoki
