softmodding can cause early deaths as it did for many x800pro to xt mod, same with 6800nu to GT
EDIT: this is a split off from another thread where this discussion started.
-saaya
-saaya
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
many sudden deaths? i havent heard of a single card that died like that link?Originally Posted by Geforce4ti4200
check other forums, theres tons of stories of x800pro to xt mod killing their card after a little use. also many 6800s die while trying the mod. ATI really needs low K or they will have a hot, slow card. I dont even expect the clocks to be higher, just cheaper to produce them and greater supply. those with the "old" .13u cards need not bother upgrading till nv50 r500/520(whatever ati calls it)
Basicly everyone because they used dual PSUs. It can kill them you know
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
noononono im not going to look for something that i doubt exists because you told me theres lots of itOriginally Posted by Geforce4ti4200
if there are so many people with dead cards and threads about it should be easy for you to remember at least two or 3 of those theads and post a link to it. i could as well say there are flying blue pigs and if you dont believe me i tell you to travel to tibeth to look for them
That stuff about the x800's dying is balony
You could provide some links though, to prove me/saaya wrong.
-Phenom2 x6 1055 @stock
-8gb ddr3
-Gigabyte UD3
-Geforce 7900Gt 755/1863 1.562v vgpu
-OCZ Powersupply 600w
lalpooo, i only heard this once from ati. they claimed that modded cards would probably die within weeks im 100% sure they said that to stop people from modding their cards.
its the same intel and amd said, "overclocking will kill your cpu in a matter of months if not weeks"
*cough*
lol whole teams of people dedicated to proving them wrong
Asus A7N8X-E Deluxe
Athlon XP 2800+ Barton @ 3200+ (200x11)
Mushkin DDR400 BASIC 2*512mb
Albatron GeForce 6600GT 128mb (Being Repaired)
Samsung SyncMaster 730BF 17" (4ms RT, 600:1 CR)
In another message board:
"Doc I opened the extra pipes on my x800pro and run it at stock pro speeds ..............it lasted 2 weeks........"
This is just one of the many posts. Do you honestly think ati would not sell it as a xt if they could because theres alot of demand for the xt? those vivo pros are xt that failed to make the cut
alot of them musnt be, as the results i see here almost everyday would beg to differ.
Asus A7N8X-E Deluxe
Its still a risk and you know this. It may or may not die, not everyons card dies but I dont have $400 to gamble. When I buy my next card, overclocking is as far as ill go. Ill only mod a card costing less than $100 like this 9500np
I don't even consider it a risk. When the 9500np mod was new I'm sure there were people whining and moaning too. How many of their cards died?
So far you've only shown one single card dying, with no links. When you compare that to the number of cards that mod fine, and are run overclocked 24/7 its not really a risk at all.
If all you want to play with is 9800s and 9700s and 9500nps and ti4200s, go ahead, but don't spread information that will stop others from getting new cards.
-8gb ddr3
-Gigabyte UD3
I really haven't heard about x800's dieing, I have had 2 of them, both modded, neither have died yet, I bought them when x800 came out. If i heard more cards dieing then id believe it, but I haven't seen many cases.
Nergal: Coolermaster Stacker STC-01, Gigabyte 990FXA-UD7 w/ EK Waterblock, AMD Phenom x6 1090T @ (4.1GHz, 2400MHz HT-Link, 3000MHz CPU-NB) w/ Swiftech Apogee XT, G.SKILL Ripjaws X F3-17000CL11Q-16GBXL (4x4GB) @ 7-8-8-24 1600MHz, 3x Radeon 5870 (2 w/ Swiftech MCW-82, 1 w/ Zalman VF3000A), OCZ X3 2000w, 2x Samsung Spinpoint F3 1TB 7200RPM in RAID1, 4x Seagate Barracuda 2TB 5900RPM in RAID10, ASUS Xonar Essence STX, Swiftech MCR320-QP Radiator, Swiftech MCP655-B Pump, Windows Server 2008 R2
Death: Antec One Hundred Ice, Gigabyte 990FXA-UD5, Phenom x4 840 @ 4GHz, G.SKILL Ripjaws F3-10666CL7D-4GBRH (2x2GB), Gigabyte Radeon 5870 under Zalman VF3000A, XFX Radeon 5850, Asus 5850 DirectCU, 1TB Samsung Spinpoint F1 7200RPM(Windows 7 Enterprise), Western Digital Raptor 150GB (CentOS 6.2)
"but don't spread information that will stop others from getting new cards."
I am not trying to stop others from modding but just make them aware of the risks. I will go look for more posts of people killing their cards from the xt mod.
and your making people aware of a risk that does not exist... you could as well make them aware of the risk of slipping in the bathroom after taking a shower, wich is more likely to happen that an x800 dieing from softmodding it.
there are 100 people if not more on this forum who modded their x800 cards and reported back in the poll thread. none of the cards died...
and YES, ati said the same thing back about the 9500s, they said they would die after some time if we mod them. thousands and thousands have been modded, heard of any card that died from a softmod?
and this is off topic, im going to split this off to another thread later, so keep talking off topic but know it will be moved later.
There is NO risk. Show me proof of the mod killing his card and not something else thank you very much.
Opteron 165
Dfi NF4 Expert
XFX 7900GT 550/1500
split this discussion off from the "current videocards" thread
Dunno abut the X800's but my 1st 9500 @440mhz ran for over a year softmodded, and still does when the computer is on.
Oh chit I'm almost to two weeks on mine. Maybee it's too late!
A64 3400 Mobile
DFI 250 UT
2x512 Mushkin Lvl. II
X800pro>X800XT PE
I've had my x800 modded for ages now, it runs at XT speeds and all.
It has never crashed once at the XT cloxk speeds with 16 pipes, and it has been running perfectly for 3 months now
Pentium 4 2.8 @ 3.3ghz
Abit IS7 mobo
1024mb ddr 400 ram
Powercolour X800 pro @ XT
Watch out guys, your cards are all going to die.
ALL OF THEM.
Geforce, you've got to stop making baseless claims without any backup. Saying there are many posts to support your claim and then telling us to go look for them is NOT the way to make your point.
Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
I will keep looking for backups and post them here. Its hard to since old threads in other forums get deleted after a while to save bandwith but ive seen at least 10 threads where their softmodded x800pros died. everytime I see a thread on this, I will link it here now on
So, you've seen 10 threads of people with dead cards.
Ten out of how many?
Seriously, this is not an epidemic, and it's very likely that these x800 deaths are not caused by the softmod but by some other factor.
thxOriginally Posted by Geforce4ti4200
but tbh, i doubt you will find any. i heard of some people who modded their cards and they died later, but that was the hard mod wich involved cutting traces and they also modded their cards... so yeah, im pretty sure that not one single card has died from beeing softmodded... EVER! show me the proof! just one single card that died from beeing softmodded.
If so many cards have died from soft modding i find it very strange that i haven't seen a single thread about it considering i spend like 6-8 hours a day on various hw/oc forums, i've seen people kill the x800 cards by using dual psu and hard modding, but i haven't seen a single one dead coz of soft modding, im pretty damn close to calling this but since im such a nice guy i won't
I5 2500K @ 4.9GHz - 1.45V
Antec H2O Kühler 920
ASRock Extreme 3 Gen 3
2 x 4GB Corsair Vengeance LP
XFX 5850 BE 775/1125
Corsair TX 750W
2 x Raptor 36GB @ Raid 0
2 x Samsung F3 1TB
