1. download the agent: windows linux mac osX solaris
2. install the agent and register it by entering your email address into the window that pops up after installation.
3. create an account here and check out the teams here and join the team of your preferance by clicking the join button.
(4.) check out the D²OL tweaking guide here to tweak your client and fold harder
(5.) check out this thread about a script that installs D²OL as a service on your system. this means D²OL will run in the background of your system and start with windows and run basically invisible in the background
.:EDIT:. Rodzilla
Install TIP
If you are having problems installing and get a blank screen like THIS
You need to disable forced AA/AF.
Originally Posted by VinnieWeiss
now your ready to fold and cure diseases
if you have any questions or problems just make a new thread and ask for help![]()
_
![Send a message via AIM to =[PULSAR]=](images/misc/im_aim.gif)
![Send a message via Skype™ to =[PULSAR]=](images/misc/im_skype.gif)
If they use the community account installers every step but step one is already done for them (Step 1. would be to install using the easy installer
