I was testing the limits of this chip. I was running a few instances of SuperPi with 4.2GHz clocks and decided to run higher and pushed it to 4.3GHz and then 4.4GHz but it then showed a BSOD and with a message 'Windows has shutdown due to an unknown error' or something like that... That's the first time I've seen it do that. It usually just reboots whenever I've reached the limit of the overclock.
I rebooted and added a few volts to the vcore. It was doing fine at 4GHz with 1.44v on the bios sensors. So I added a few volts to around 1.48volts. Then exit. When the reboot cycle began, The Abit alarm went off. Signaling that the overclock was not acceptable. So I reset the normal overclocks I used. I put it back to 1.44v and 250 FSB which gives me 4GHz which is my usual startup. But the alarm was still sounding off. To make this short, I have to push the vcore higher than usual to get to 4GHz now. I'm beggining to think this stepping is fragile. Anyone care to share or speculate what could have caused this? too much vcore?
