Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: Ultimate Ln2 -178c
    HVAC/R Engineer
    Nov 2003
    Ultimate Ln2 -178c
    Ln2 as a phase change:
    The search for the perfect temperature.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    This will change the way many use LN2
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Overclocking Guru
    May 2002
    SoCal, USA
    How long will the stuff run for?
    OPP
    Jun 2002
    Las Vegas
    Not sure yet. thats un-insulated and burning off a lot. Chilly is adding a valve to manually adjust the flow.
    Tonight may be the last run of old faithfull. now reaching a year old, it still has the same charge from Comdex.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Sep 2004
    christ...adjustable temps beyond -150C...wowza..i just noticed somthing..why is their two blocks?..
    HVAC/R Engineer
    Nov 2003
    Are you seeing double?
    There are two identical blocks.
    Sep 2004
    gpu? nb?
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    jeebus... thats insane man.
    Donate to XtremeSystems!
    Workstation: Intel Core i7 4770, Asus Maximus VI Gene, 32GB Corsair Dominator Platinum DDR3-1866, eVGA SC GTX Titan, 256GB Crucial M4, Corsair HX850, Corsair H100i. Corsair Carbide 350D
    Fileserver: 2x AMD Opteron 2425HE, Supermicro H8DME-2, 24GB DDR2-667, Supermicro 846TQ 24bay Chassis, Redundant 920w, 256 Crucial M4 boot, 20TB Storage
    Notebook Asus Zenbook UX32VD-DH71, Intel Core i7 3517u, 10GB DDR3-1600, 256GB Crucial M4, Geforce GT 620M
    Xtreme X.I.P.
    Nov 2002
    Shipai
    i told ya charlie
    Jan 2003
    Dayton Ohio
    So how does this thing work?
    HVAC/R Engineer
    Nov 2003
    Test Run Tonight
    First there is a 1/4 inch diptube in the Ln2 then this splits into two .060 ID tubes 1 foot for the cpu and 1.5 ft for the gpu, then throuh the blocks where the Ln2 is allowed to boil then the Gas (n2 goes through the suction lines to the accumulator ( an old recovery cylinder with two inlets one at the bottom and another at the top. The top outlet will prevent the Ln2 from contacting the pump.
    So this is phase change at the xtreme.
    The dewer lost its vacume so the Ln2 wont last long, but we will have a good run and pics soon..
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    crazy.
    In and awesome and really cool sort of way
    Jun 2002
    Las Vegas
    Here is setting up, we had a bad start with no LN2 in the dewer to do any damage. We test fitted and flow tested the blocks, they need balancing adjustments.
    We only had about a gallon of LN2
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Oct 2002
    Field of Battle
    hahaahahaha....
    science experiments!!!!
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    brings new meaning to Xtreme
    btw is that chilly or fugger in the pic?
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Mar 2004
    So-Cal
    what kind of hoses are you using????
    Banned
    Jul 2003
    A new place
    Quote Originally Posted by blinky
    Chilly
  18. #18
    HVAC/R Engineer
    Nov 2003
    I had some automotive rubber hoses on it.
  19. #19
    Nov 2003
    Olympia, WA
    Oh well.. least I didn't miss anything.
    Did ya get a new tank?
    Imagination is a powerful tool.
  20. #20
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    Chilly is very good looking.
    Level 80 UD Death Knight on Murmur (Beta)
  21. #21
    Mar 2004
    Portugal
    Do you predict how many quantity of ln2 you need to run only one bench
    Those kind of temperatures are very disturbing -300F
    What is te relation with liters = gallons
    cumps
  22. #22
    Banned
    Jul 2003
    A new place
    Quote Originally Posted by bh2k
    Don't make me hunt you down bh2k!
  23. #23
    Xtreme Recruit
    Apr 2003
    Greece
    WooW!
    Insane project i would call it !!
    Good luck there!
    Btw how easy is it to buy some ln2 and how much it costs?
    "If we knew what it was we were doing, it would not be called research, would it?". A.Einstein
  24. #24
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    I hope your a girl or there is a large amount of sarcasm floating around.
    On Topic,
    Can't wait to see it running
    More pics please!
  25. #25
    HVAC/R Engineer
    Nov 2003
    Quote Originally Posted by Samael
    WooW!
    Good luck there!
    Ln2 85.00 for 15 liters. But we had a dewer that had no vacume so it boiled off in 5 hours.... The last 4 or 5 liters we dumped outside looked cool though...
