Anyone has this ram and know what max volt i can use ?
And what timings..
And what timings..
I run mine with 2.9v ( Haven't tried higher and was able to get 2.5-3-3-6 @ 265 1:1 with my 2.8e and P4C800ED combo. The ram is pretty decent stuff, I've even had it up to DDR584 with slacked timings.
I can't offer any advice on timmings or voltages, but I am curious what you think of the RAM. I'm trying to decide between the Plat rev2 or some 3700 Gold Rev3 for the DFI nf3 I have coming.
My 3200 Plat rev 2.0 1 gig kit will be here on monday or tuesday, I had it RMA'd as a replacement for my 3500EB which wouldn't work with 1T/over 220 HTT on my 939 rig.
From what I hear its special selected Samsung TCCD chips rated for DDR500. I'm expecting atlleast 260 1:1 2.5-3-3-7, these chips probably won't do much more with volts as they would with slacked timings.
I can run it 320 1:1 but not very stable.
Its very good ram, but wonder what max volt i can put on it.
Will try 2.9
That is a nice OC from its standard rating. Thanks for the info, and I hope you can get it stable and still keep an OC near that 320.Originally Posted by Ubermann
Am I dreaming or NOT ?Originally Posted by Cohiba
320 1:1
Please post timmings / CPU multi and SANDRA MEM Screen Shot ....
E8400 4400(Q814A015 Wafer **91)@1.296 Vcore
Q6600 (L733B458)@4054 1.5 Vcore
ASUS P5Q Unmoded - 2X2 GB Corsair Dominator 8500
Blaster AUDIGY 2
Sound Blaster Megaworks Speakers 2.1 250D THX / 300 WRMS
ATI 4850 512MB @750/1150 Stock cooling
LG W2600HP-BF 26" Wide TFT Monitor (S-IPS)
System Cooled by ThermalRight Ultra 120 Extreme
System Powered By OCZ 600W
Limits do NOT exist
Originally Posted by Dagalidis
Heh......if he gets it stable at that speed, then I will join you in 'ing everywhere.
I have this shot, sitting and playing right now.
Will make one with more info later.
Running bios settings that anandtech use and same ram as him.
Some new info.
Got past 5000Meg/sec in Sandra at 320FSB.
And took the board to 340FSB 1:1 for 10-15 secs (Not that i belive it myself yet, has to be something that is wrong!)
This ram is very nice =)
Check pics.
Everything extra is bad!
Managed to run a sandra at 338fsb 1:1
But without 1T it dont make good score.
Wow 5K!!Originally Posted by Ubermann
What did you do to go from 4645 to 5010?
Only thing i see changed is your HTT from 319 to 320.
Did you go from 2t to 1t?
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Jep ... He get from 1T to 2T
greetz
1T worked up to 320 so far.
But im still novice at this.
Volt readings are brooken on this board now it seems..but i continue till fans fall off =)
could you do me a favor and post timings and voltages with those fantastic screenies?
930 @ 4.4 & P5WD2 (vcore + droop, mch vdd, ddr2 vdd)
4x512 Micron D9
7800gtx 600/1470 (vgpu + vdd)
h20
my heat
Timings are 3-4-4-10Originally Posted by CrimeDog
Volts are:
Chipset 1.6
Ram 1.9
CPU 1.550 + 113%
I think i sell this Clawhammer and get a 3400 newcastle.
Seems more fun to play with.
This was for 338:
CPU VID Control: 1.550 V
CPU VID Special control: 110%
Chipset: 1.60 V
AGP Voltage: 1.50 V
DRAM: 2.9 V
DRAM Freq set: 200 1/01
Command per clock: Disabled
Tcl: 3.0
Trcd: 0.4
Tras: 10
Trp: 0.4
Tref: 4708 cycles
Twcl: 01
DQS Skew control :Increase skew
DQS Skew value: 128
Dram drive strength: Level 4
Max Async latency: 09.0 nano
If i remeber correcly, kinda hard to remember stuff when you boot comp every 5 minute =)
Ubermann, these are awesome results. (Especially for PC3200 RAM )
Too bad you can't test 2x 512MB.
What's your highest clock at CL2 - 2 - 2 - 10, 1T ?
thx!
AMD Phenom II 940 black edition, DFI LP DK790FXB-M2RSH @ 240 x 15.5 | 4GB OCZ Platinum CL4 | NexXxos X² Highflow | 2x Eheim 1048 | Enermax EG701 | 2x WD3200AAKS Raid 0 | HD4870 watercooled | Win7 64bit
looking good.. But correct me if I am wrong but you´re using 7.5 multi in the T1 shots?
"M-I-A"
First 2 pics with half multis.
Before i knew that it use some divider.
The rest is "whole" multis..
Havent played much with 2-2-2 but it got to ~225mhz something.
At 2T system is very stable but not good in sandra.
310FSB 1:1 X 6 CPC ON
Volt settings:
Cpu 1.550
Cpu spec 113%
Chipset 1.8
AGP 1.6
Dram 3.0
Dram settings:
200 1/01
CPC ON
Cas latency 2.5
Ras to cas 4
Tras 11
Row precharge 3
Refresh period 4708
Write cas Auto
DQS skew Increase
DQS skew 128
Dram level 3
Max Async 10 nano
Doing prime...
Nice work Uber!
Does the RAM get hot to the touch? (3V )
Is 320 stable enough to run some benches like SuperPi 1M and PiFast?
Ram is cold yet.
Dont think 3.0 really is 3.0.
Cant run any Pi test with 320 CPC on, yet =)
310 was ok in prime for 47 minutes, moving on to 315 now.
Nice man!
Please post a screenie of the highest you achieved with SuperPi 1m.
320 would be da bomb!
Keep us posted, i can't wait to get mine.
