Results 1 to 11 of 11
Thread: D26 NF7/NF7-S Speed Fire by -=Merlin=-
    Jul 2004
    by -=Merlin=-
    D26 Speed Fire 0.1 & 0.2
    - indifikation Mobeil AMD Athlon XP-M
    - Romsip Bios Tables Cpu Interface 133 & 166 & 200 MHz (Romsip Modded by -=Merlin=-)
    -- Speed Fire 0.1 Tables (Optimised 200FSB Register)
    -- Speed Fire 0.2 Tables (Optimised 200FSB Register)
    - L12 mod built-in
    - Bpl 3.02 -- Bpl 3.19 Cpc On
    D26 ver. 2.0.02 Speed Fire 0.1 Bpl 3.19 15.09.04
    D26 ver. 2.0.03 Speed Fire 0.2 Bpl 3.19 15.09.04
    by -=Merlin=-
    Aug 2002
    Pearland, TX
    what does speed fire mean ?
    wolfdale e8400
    Corsair Dominator 6400c4 4x 1gig
    rampage formula
    evga 88000gtx
    x-fi platinum
    ocz powerstream 520
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    It's clearly the pendant to tictacs "splitfire". But, don't try to find any reasonable meaning in these names. I even doubt that the makers of the bios version know it.
    Jul 2004
    by -=Merlin=-
    WoW
    250
    255 :banana4:
    by -=Merlin=-
    Sep 2004
    This is a great bios so far! I gained 300 points on arithm sandra tests. I am waiting for my room temps to drop to see if I can get any higher overclocks (damn hot summer room temp... 85 degrees F
    Watercooling can only do o-so much when your room is HOT.
    May 2004
    Minneapolis
    it got my fsb up to 260, but haven't tested above 9 multi yet.
    Dual 1.6 Xeons @ 3.3ghz | Asus PC-DL | 9800pro | watercooled
    Mobile 2600+ IQYHA: 0351MPMW | Abit NF7-S | 2x256 Mushkin BH6 | 9800 Pro | retired
    3DMark01: 24413 3DMark03: 7993 Aquamark3: 56521 SuperPi 1M: 34s PiFast: 49.16s[/SIZE]
    Jun 2002
    Earth/France/Corrèze
    Merlin, i can't use multi below 9 here
    any idea
    learn A.K.A JP
    May 2004
    Minneapolis
    Learn I have the same issue, gives you the 2tone siren?
    Jun 2002
    yes
    learn A.K.A JP
    Jul 2004
    by -=Merlin=-
    D26 Discovery 0.1
    - Indifikation Mobeil AMD Athlon XP-M
    -- Discovery 0.1 Tables E4 EB (Optimised 200FSB Register) (searches Tables Trats , by -=Merlin=- )
    - L12 mod built-in (Modded by TicTac) TEST !!!
    - Bpl 3.02 -- Bpl 3.19C Cpc Off
    D26 ver. 2.0.04 Discovery 0.1 Bpl 3.19 17.09.04
    D26 ver. 2.0.04 Discovery 0.1 Bpl 3.19C 17.09.04
    by -=Merlin=-
    Aug 2004
    Merlin, please recommend best bios for this ram:
    2x256 kingston valueram which can run on 200 mhz bus with 2-2-2-2 timings under 3.10 voltage on it.
